05-28-2019, 10:29 AM | #89 |
Rep 68
Is anyone other than BMW (the revised chain kit) making an beefier aftermarket timing chain kit for the N20/26? If not, I'm surprised considering how many N20/26 engines were sold.
05-28-2019, 12:01 PM | #91 |
Rep 891
The conclusion here is that someone bought a car from someone else who promised they changed the oil regularly. (They were lying)
328i RWD | MW on CRed Slick Top | 6MT | BM3 | MPE | GPlus FMIC | CSF Radiator | Millway Street Camber Plates & Monoballs | KW V2 6k/18k Swift Springs | F80 LCA/TS | SPL Bump Steer Kit | APEX SM-10 | R-S4 | DS2500 | RBF600 | SS Lines | Past: E36 328is & E38 740i Last edited by MacklinUSOB; 05-28-2019 at 03:41 PM.. |
05-28-2019, 12:14 PM | #92 |
Rep 230
It is not important for this thread. Important that the chain did NOT fail, even with that "lubrication". This makes me think that oil changes have very little correlation with probability of chain failure.
05-28-2019, 03:30 PM | #93 | |
Rep 191
My grandmother smoked a pack of cigarettes a day until she died at 98 years old. Doesn't mean you won't get cancer from smoking at half that age... Nothing in this thread is in guaranteed terms. It's all probabilities and suggestions to reduce probabilities. One example doesn't unequivocally disprove the potential for low OCI to reduce the probability of failure.
IG: @derringerF10
2016 550i RWD N63TU 8AT | Catless Downpipes | BaskiSpeedworks STOCK TURBO RECORDS 1/4: 10.90@128 60-130: 7.43 |
sspade2466.00 CandyRedRC46242.00 |
05-28-2019, 03:44 PM | #94 | |
Rep 230
- Disable ASS - Change oil every 5,000 miles - Visit church every Sunday and pray diligently Amen. Last edited by F30ed; 05-28-2019 at 03:49 PM.. |
05-28-2019, 03:51 PM | #95 |
Rep 891
The person who owned this car was going to have a motor failure with or without help from the chain guide. This thread is about prematurely replacing TC components and what it costs, not about stupid car owners who don't change their oil.
328i RWD | MW on CRed Slick Top | 6MT | BM3 | MPE | GPlus FMIC | CSF Radiator | Millway Street Camber Plates & Monoballs | KW V2 6k/18k Swift Springs | F80 LCA/TS | SPL Bump Steer Kit | APEX SM-10 | R-S4 | DS2500 | RBF600 | SS Lines | Past: E36 328is & E38 740i |
05-29-2019, 11:09 AM | #96 | |
Rep 785
Would be great if the aftermarket got behind this issue and helped us out. As someone mentioned above, developed a fix of some sort.. Seen it happen in the VW world where aftermarket comes out with beefier cam followers, stronger HPFPs, etc |
sspade2466.00 |
05-29-2019, 11:18 AM | #97 |
Rep 5,457
Drives: F30
On the whole note of an aftermarket fix...
Im not sure where we/they would start? Considering that the only part number I can find that BMW has changed is the Timing Chain itself... not the guides, tensioner, etc. This is going purely off realoem and I realize that it is possible more was changed (though unlikely). If the chain is the only than that actually fails/stretches... and leads to guide failure... then there are already plenty of aftermarket choice chains available. Guides were never a problem, only failed because of a stretched chain. Id still choose the OEM if and when I have this done on my car. Can someone prove otherwise? Im all about learning this motor and how to make it run forever. Currently sitting at 75k with no issues to speak of other than coolant thermostat failure that was covered under warranty. |
kahnfucious32.00 |
05-29-2019, 11:24 AM | #98 |
Rep 5,457
Drives: F30
Edit:
Looks like the tensioner was updated in 2016. Maybe this is a good preventative measure for most of us? I believe it can be accessed externally. |
05-29-2019, 11:25 AM | #99 |
Rep 5,457
Drives: F30
Timing Chain part numbers:
05-29-2019, 11:27 AM | #100 |
Rep 5,457
Drives: F30
Guide rails never changed! Not sure why so much focus has been placed here?!?
05-29-2019, 11:30 AM | #101 |
Rep 5,457
Drives: F30
Someone should buy this and do a DIY for the group... I do not have access to a garage currently
https://www.ebay.com/itm/For-BMW-F10...wAAOSwEFNZnBFc |
05-29-2019, 12:01 PM | #102 |
Rep 891
This whole topic has been a debate on the chicken or the egg, nobody really knows one way or another. BMW probably does since they have lots of data but they obviously aren't very forthcoming. The only "information" they give us is the part catalog changes and their TSB which points to the "oil pump chain drive sprokets". The oil pump sprokets haven't been updated but the oil pump chain has been twice, it's all really mismatched information wherever you look. Whichever way, if you're going to crack open the motor suspecting one, it would be silly not to replace the whole assembly.
sspade2466.00 |
05-29-2019, 12:14 PM | #103 | |
Rep 5,457
Drives: F30
I agree, if you are going inside - replace everything associated. There are three different level kits I've seen on eBay with the cheapest including the bare bones and the most expensive including oil pump and chain. These are all from the same seller as well. So it seems some have/will change only failed components and some will go for it all. If and when I have an issue, Ill be getting the tits kit and replacing everything. For a few hundred dollar delta, you'd almost be crazy not to. But still, some do! Dealers included. Wonder what the deciding factor is for them? |
05-29-2019, 01:27 PM | #104 |
Rep 298
I don't know if the rails truly changed or not but I think you are putting too much emphasis on the part numbers being same. For example, the EGR cooler of the diesel engines that is under recall right now has same part number for several years but there are more than 10 revisions of it. In that case it is indicated in the part number sticker with a two digit number, for example 7 810 751 - 06 means it is revision 6.
05-29-2019, 02:16 PM | #105 | |
Rep 5,457
Drives: F30
So BMW decided to chain the part number for revisions on chain and tensioner but not guide rails? That would mean that the rails have not changed. Of course, it's possible that they change a part behind the scenes and dont tell anybody. But thats pure speculation. To reiterate: The chain and tensioner have been revised but the guide rails have not. |
05-29-2019, 04:30 PM | #106 | |
Rep 298
From FCP Euro blog: "Index Number = Revisions or changes done to the part under the current number (not all parts have an index number printed on them)" https://blog.fcpeuro.com/understandi...mbering-system The EGR cooler is just one example where the part has definitely changed but the part number has not. In the case of the EGR cooler recall they check from the sticker which revision is in your car and that dictates the recall actions so there is definitely a difference between them. In the EGR discussion threads guys who work at dealership garages claim this is common that the part changes but the part number does not. Of course none of this is evidence that the rails have changed, I just mean you cannot say for sure that they have not because they have same part number. |
05-29-2019, 06:53 PM | #107 |
Rep 5,457
Drives: F30
@zeikei fair enough, I understand what you are saying and can see that it is done by BMW in certain circumstances. Wonder if there is any rhyme or reason to why they would change some part numbers and leave others alone (for revised parts).
05-30-2019, 03:45 AM | #108 |
Rep 298
Yes I was trying to find that information myself but so far no luck. Some parts like steering rack has a new part number all the time while others have just the index / revision number change.
06-03-2019, 10:43 AM | #109 |
Rep 482
Drives: 2014 Glacier Silver F30 328i
Sub'd!
2014 GLACIER SILVER F30 328i * Wheels:18" VMR V801 Titanium Black Shadow * Springs: DINAN 1" Lowering Springs * Tune: BM3 OTS E30/93 OCT * Engine: Evolution Racewerks Catless DP/CP/FMIC * Intake: AWE S-Flo Carbon Fiber Intake * Exhaust: AWE Exhaust Suite + Mid Pipe * Go Fast Bits DV+ Diverter Valve * Plugs: NGK LI Plugs * Lights: Depo Angel Eyes W/ Morimoto HID's * Hood: Seibon Carbon Fiber Hood
