05-09-2019, 11:48 PM | #23 |
Mr. Clutch
91
Rep 245
Drives: 2015 M235i
Stage 2.5 on there website is plenty for a stock turbo car. Only 2 versions of that kit for our car. Both universal. Only difference is one has stainless steel lines and the other has nylon
Quiet M235i
05-10-2019, 01:31 AM | #24 |
Rep 373
'14 F20 M135i EWG FBO:// INJEN INTAKE // PURE INLET// TURBOSMART BOV DUAL PORT // //CSF INTERCOOLER // ER CP // SNOW S2.5 METH KIT // B58TU HPFP // NGK 97506 // ER DP // TMSS MID PIPE //MPE // MPBBK // UR STRUT BRACE // BM3 CUSTOM JORDAN E85 TUNE // XHP STAGE 3 // |
Jpup26.00 |
05-10-2019, 02:52 AM | #25 |
Rep 303
05-10-2019, 05:42 AM | #26 |
Rep 373
My charge pipe has two bungs so going to be using one for meth and one for the boost tap for the gauge
05-10-2019, 06:39 AM | #27 |
IG: AndrewRodriiguez_
86
Rep 281
Drives: 2013 335i x Drive Sport 6M/T
Garage List 2013 BMW 335xi [0.00]
2002 Lexus IS300 [0.00] 2004 Subaru WRX (SOLD) [0.00] 2010 Honda Civic Si ... [0.00] |
So what happens when you run out of meth in the tank? Does it harm the car? Does the tune adjust accordingly? or do i have to keep it filled. Looking to go Meth very soon and just need simple questions hopefully answered! Thanks in advanced!
[COLOR="Black"]M4 Style Spoiler, M Style Black Kidney Grills, ER CP, VRSF DP, MPE, BMC Drop-In Oiled Filter tuned by RK-Tunes. BC Racing Coilovers
13blk335ix74.50 |
05-10-2019, 07:30 AM | #28 |
Rep 303
05-10-2019, 11:06 AM | #29 |
86
Rep 281
I also purchased my charge pipe about a year ago with no meth bung. Would it be smarter to purchase a new pipe with bungs made or take mine off and get a bung cut and welded on my current charge pipe? decisions decisions...
05-10-2019, 11:53 AM | #30 |
Rep 303
The one bung I do have will be used for a single injector. What I need is an alternate tap to measure boost psi.
05-10-2019, 11:56 AM | #31 |
Rep 73
05-10-2019, 01:11 PM | #32 |
Rep 303
08-01-2019, 08:35 AM | #33 |
Rep 1,499
Hey, guys, I'm bumping this as I'm going to pull the trigger in the AEM WMI kit for MAP 0-5V and have a couple of questions.
1. Which map sensor (intake or charge pipe) should I tap in to and which wire specifically? 2. What are you setting your start and stop dials to for injection? I've like to start injection at 7PSI and stop at 17PSI as the controller is progressive and I'm peaking around 16.5PSI on the bm3 OTS E30 map and I've seen boost spikes up to 17PSI right after letting off the throttle on a WOT run. The diverter valve does a really good job dumping boost quickly. I did some logging via bm3 and plotted a graph of MAP sensor voltage vs boost and found the voltage range to be quite short. For example, 2.5V=4.1PSI, 2.V- 4.8PSI, 2.8V=6.1PSI, 2.9V=7.6PSI and 3.1V=8.9PSI. I also plotted this in Excel and used a 4th order polynomial fit to get a bit more granular and found 2.85V=7PSI and 4.1V=17PSI. Based on the data I was thinking of setting the AEM controller start at 57% (2.85V/5V) and end at 82% (4.1V/5V). Just wondering if my thinking is correct here. 3. Where did you tap into 12V switched power? I've seen people tapping into the fuse box. How is this done? Do you just find the right fuse and stick the wire in the fuse slot then plug the fuse in? This doesn't seem to be a robust method. I was thinking about tapping into the cigarette lighter wires found under the panel in front of the cup holders. Thanks!!
08-01-2019, 10:43 AM | #34 | |
Rep 86
2) Depending on how you drive and your tune you can adjust it accordingly. I have my AEM kit coming on at 5 psi and spraying 100% at 20 psi. I am running it on the safe side. 3) I tapped my 12 volt power switch as you indicated. To the cigarette lighter near the cup holders. The reason I did this is just in case I forget to turn the switch to off the car automatically cuts power to all power outlets/cigarette lights after around 5 to 10 minutes once the car is shut off. That way you do not put excess drain on your battery. Hope this helps. I have been spraying for over 1 year with no issues and the car is still running strong.
2013 F30 335i PWG
VRSF DP/ VRSF FMIC/ ER CP/ AFE Intake Filter/ PowerStop Brakes/ Custom Exhaust/ BM3 Stg 2/ AEM Water Methanol Injection/ MotorSports Hardware Studs, Locks and Spacers |
08-01-2019, 10:49 AM | #35 | |
Rep 86
If you are tuned for meth and your tank goes empty you could have fuel and knock problems.
2013 F30 335i PWG
08-01-2019, 12:01 PM | #36 | |
Rep 1,499
Hey man thanks for the response. I do have two bung on my FTP charge pipe, so I can run the vacuum (well in this case would it be a boost line...lol) line there. This sounds much easier.
What nozzle are you running? Quote:
08-01-2019, 05:07 PM | #37 | |
Rep 86
I would just start off with the 250 hp nozzle and if your car likes it and you feel the need for more speed then jump up to the 500 hp nozzle. I do suggest though if you want to fully maximize your car at the 500 hp nozzle you would need to get a custom tune for it. Hope that helps.
2013 F30 335i PWG
08-01-2019, 06:51 PM | #38 | |
Rep 1,499
Thanks man appreciate it!!
bootmod3, meth kit |
