02-08-2019, 02:52 PM | #1 |
Rep 7
F31 retrofit nav system - disappointment
Hi all,
I just got my car back from the EGR recall - and while it was there I got them to install the retrofit nav (the glovebox "thing"). So I knew it was never going to match the Pro system. I knew I wouldn't have a Nav option in the main menu. But I *was* led to believe that beyond that, it was basically the same as the business nav. Seemingly, it really, really isn't. 2 days after getting the car back it's gone back in for some bodywork, so I've not had long to play with the nav. However... From what I can make out, switching between day/night mode is a manual thing only. That is ridiculous! Any modern nav can switch either by a trigger on the headlights, or based on date/time. So I either leave it on day mode (and get dazzled at night) leave it on night mode (which is naff), or faff around with the controls as I drive - arguably dangerous. My wife's mondeo is 12 years old nearly - the nav on that switches automatically! Not once did it pick up any TMC information. I even set a route up to Glasgow - it found nothing. Audio alerts are barely comprehensible. Even just visually it's disappointing - the UI isn't "like for like" with the rest of the iDrive system, and it lacks the... "finesse" of the factory fit business nav It came with 2017 maps. I assume if nothing else I should be able to get at least 1 free update?!? What about firmware? Does anyone else have experience of these retrofit units? Any hints on how I could make things more bearable? If (as I suspect I will) I decide I really have wasted my money - what are my rights as a consumer, given that it's a fully installed purchase? Given that it's BMW, and the cost - surely it should be on a par with most modern navs - even the cheapest Tom Tom? Cheers! |
02-10-2019, 03:58 AM | #3 |
Rep 7
I'm sure the maps are reasonably accurate... it's the functionality of the box itself I'm annoyed by.... hoping someone here can advise me of my rights with such a hardwired / installed solution.... I mean obviously a "Halfords bought cigarette lighter" nav unit can just be returned.... but this?
nav, retrofit |
