05-17-2019, 08:11 AM | #23 |
Rep 3
Hi, my location is Bulgaria and I do have the base stereo. I am looking for the the easiest upgrade option and there are several direct Plug and play replacements (eg. Match and Ground Zero), but I was worried if there would be any effect with the stock headunit amplification. I do have the NBT navi pro, which I believe has a slightly higher power output than the navi business one.
Any opinions will be appreciated, especially if someone has tried this. |
01-21-2020, 06:48 AM | #24 |
Rep 33
Fantastic thread and really compliments davethefish's thread. I think I will follow what OP has done and go with a 4 channel amp.
Wondering about the crossover. Any advice on good ones to use in a similar setup and where to mount it? It is too bad there isn't a plug in play powered sub that would fit right under the seat with the only need being to run power to it. All in all the sound of the base stereo is adequate, it just lacks decent bass. I don't need to shake the car with crazy boooooooom, but it would be nice to have it pick up more of the lower frequencies without having to turn the volume up so much. |
01-21-2020, 11:02 AM | #25 | |
Rep 298
02-13-2020, 06:45 AM | #26 |
Rep 17
Hi, sorry to bump this thread into 2020 but need some advice please. Great write up Simicz!
I have the base audio setup in my F36 GC and want to upgrade the dead sound system to something a little more respectable. So far; - Bought pair of Rockford Fosgate subs and replaced the stock speakers - Recently bought HK tweeters and grills to add to the system - Bought a LC7i pre-amp to clean up and boost a high level input from subs wiring Need to; - Buy an amp (need help on what to go for please) - Figure out best way to connect tweeters to the mids in the door - Help on how to change the HU from Base to HiFi in the UK please! Can you offer any guidance please? |
02-19-2020, 05:50 AM | #27 | |
Rep 17
Anyone at all?? |
02-19-2020, 12:06 PM | #28 |
Rep 298
I'll try:
-If you already have the HK tweeters then try to get second hand HK mids as well, then it is just plug and play to connect them as long as your tweeters have the original connectors. -Head unit output can be coded with Bimmercode, consider purchasing that and adapters so you can code it yourself. -Amp depends on if you want any DSP capabilities, how much power, will you also run rear speakers with it, etc. Also take into account the impedance of your underseat woofers. If you like to tweak DSP settings then for example Audison Prima series is good for that but since you already have the LC7i you don't need some of the features. |
02-19-2020, 10:22 PM | #29 |
Rep 500
You can reference this post for the equipment list. Should be quite similar.
https://f10.5post.com/forums/showthread.php?t=1692988 |
03-08-2020, 12:09 PM | #30 |
Rep 47
Hello,
What do you think would be a better upgrade to a base stereo: 1) some aftermarket plug and play component speakers (like Helix Match MS 42C-BMW.2) 2) or original BMW HiFi sound system? Thanks |
03-08-2020, 02:45 PM | #31 |
Rep 15,966
Electronics for sure. Contrary to what the advertising says the original BMW speakers are pretty good, and there's no such thing as magic speakers that will instantly make the base stereo better, nor the hi-fi or H-K for that matter.
Even the hi-fi and H-K amps are nothing special, as neither has a really good DSP/EQ. The only reason to go with them is to integrate them with the iDrive. This thread shows an alternate electronics option: https://f30.bimmerpost.com/forums/sh....php?t=1475424 |
04-20-2023, 03:04 AM | #32 | |
Rep 13
A good find
Given that TechnicPNP won't ship to NZ , or AU we tried to get a kit to the UK...he then refunded - OUT of stock. So.....we went on a mission...look what we found https://www.aliexpress.com/item/3270...d=2JO8c6oG8CTJ Easy way to build a look for a fraction of the cost |
base stere upgrade |
