03-13-2018, 03:04 PM | #243 |
Rep 57
04-19-2018, 02:14 PM | #244 |
Rep 74
I am also looking to get a tune for my active hybrid 3. I have the following mods:
pure stage 2 turbo jb4 bms meth kit BMS intake Fuel it LPFP kit straight through exhuast no cat ER charge pipes wagner evo 2 intercooler I like the JB4 alot but also want to add the Burble which the jb4 cannot. Can I get a BM3 back end flash and use the JB4 on top of it to switch maps and run the meth kit. Who is the most experiences custom tuner for the AH3 |
04-20-2018, 12:59 AM | #245 |
Rep 1,290
@afranke was running a similar setup, on the european side a few of us went with BR performance custom tuner, we're happy with the tune, except i ran into fueling issues with hpfp apparently, which wouldn't be an issue for you with meth and/or port injection, i need to keep it simple.
I also have a bm3 license and will see if they can take me any further than current tune + add burbles
2017 M550i | Sophistograu
Previous cars: 2014 F30 ActiveHybrid 3 | 2012 f20 M135i |
04-20-2018, 05:58 AM | #246 | |
Rep 74
by fueling issues you mean you maxed out the HPFP or was it a tune issue? |
05-10-2018, 01:14 AM | #247 |
Rep 1,065
Hi! I hope that someone can help me, I have opened a support ticket but I am not sure when they are going to reply. In short...
I flashed my F86 X6M to stage 2. I got a drivetrain malfunction once successful (took a few tries) and was then unable to online recode. I unplugged the battery for several minutes and that cleared the code. I felt the power, cold start was removed, car was flashed. Today I wanted to adjust the burble so I went ahead and re-flashed. During the flash, the log in BM3 agent said coding not applied. It proceeded through the process and said flash successful but continued to throw the drivetrain malfunction. Once again, I was unable to online recode and kept getting the drivetrain malfunction, even after unplugging the batteries again. Since I kept getting this malfunction, I tried to stock and lock. It went through successfully, but still throws the drivetrain malfunction. I am still unable to clear this code, I have spent several hours trying everything. |
12-19-2019, 11:01 PM | #248 | |
Petrolhead
1942
Rep 3,521
Anybody have any ideas? Currently, I've removed the negative terminal but I'm afraid to reconnect it to find the error still present. |
