05-08-2017, 11:13 AM | #89 | |
Rep 1,291
2017 M550i | Sophistograu
Previous cars: 2014 F30 ActiveHybrid 3 | 2012 f20 M135i |
05-08-2017, 11:18 AM | #90 | |
Rep 276
All with +95% battery. |
05-08-2017, 12:14 PM | #91 | |
Rep 488
I'll ask for the graphs, but they aren't much to look at from what I recall.
2013 ActiveHybrid 3 (335ih) • N55 PWG • Meisterschaft GT catback • Wagner tuning catless DP and Stage 2 Evo Comp Intercooler • ER chargepipes • CTS intake • io2V3 O2 simulator • Pure Stage 2 turbo with high-flow inlet and DV upgrade • Fuel-It Stage 2 LPFP • JB4 ISO firmware • Fuel-It DIY PI Kit • bootmod3 •
05-08-2017, 12:16 PM | #92 |
Rep 488
That's a good point, and I honestly wasn't paying attention, but in my time with the AH3 I've never seen the battery drop below 80%. I don't think a dyno would change it, but who knows for sure. I'll keep an eye on that next time.
05-08-2017, 01:22 PM | #93 | |
Rep 276
Their will certainly be a difference on the dyno between a full and empty battery. |
05-08-2017, 01:29 PM | #94 | |
Rep 276
Does the BMS blocker work well? I just ordered it. It's so frustrating when pulling against a car and suddenly there is a kickdown. When you pull your lever to the left, does it show S1/S2/S3? Or just DS? And I believe 5th Gear is always recommended on the dyno. Right Darkiedm4? |
05-08-2017, 02:10 PM | #95 | ||
Rep 488
05-08-2017, 02:31 PM | #96 |
Rep 488
OK, here's the dyno graphs (let me know if I formatted them incorrectly or am missing some information):
With OTS Tune after driving around with it for awhile Stock Tune Back to OTS Tune
frackje51.50 |
05-08-2017, 08:43 PM | #97 |
Rep 2,357
Dyno is in 5th gear manual (M5) for the 8AT and DSC OFF!!! Car will not kick-down in M5 - mine doesn't...
(A Dane in China) |
frackje51.50 |
05-08-2017, 10:30 PM | #98 |
Rep 122
Why would the alternator be constantly charging in Sport+? Isn't that the one mode you'd want max performance, which would equate to minimal parasitic draw on the engine?
05-09-2017, 12:55 AM | #99 | ||
Rep 1,349
Drives: BMW F80 M3
frackje51.50 |
05-09-2017, 02:05 AM | #100 | ||
Rep 1,291
Check this post here: http://f30.bimmerpost.com/forums/sho...d.php?t=791178 Also in the manual: http://afvsafetytraining.com/downloa...brid3-2013.pdf Quote:
Previous cars: 2014 F30 ActiveHybrid 3 | 2012 f20 M135i Last edited by Lancelot; 05-09-2017 at 02:11 AM.. |
05-09-2017, 04:28 AM | #101 | |||
Rep 276
Oops. Quote:
05-09-2017, 08:55 AM | #102 |
Rep 488
I'm glad it's not just me then. I swear the non-AH3 doesn't do that. In my experience, Manual mode is only very just slightly manual. It seems to hold the gear just a little bit longer before it decides you have no idea what you're doing and need a different gear.
05-09-2017, 09:27 AM | #103 | |
Rep 276
05-09-2017, 09:46 AM | #104 |
Rep 1,291
I got a software update last year, before it was DS now it's S1/S2/...
05-09-2017, 10:06 AM | #105 |
Rep 276
05-10-2017, 01:35 AM | #106 |
Rep 931
After a Dyno my 335iH full stock have 295WHP
With a tmcmotorsport (+5psi settings) same day same Dyno table car show 330WHP
BMW F82 M4 Black MHD CS Map - GTS DKG - Navi -Performance Brake RSL1 Pads - USB - DivX-DVD - Bluetooth - VoiceControl - Connect - Apps - Online - H&K - TrafficInfo - SpLimInfo - WhiteMerino- PDC - Cam - Adaptive Led - Antitheft - CP Steering- Performance ST - Adaptive CP Setup - GarageDoorOpen - Pipercross - Stock Exhaust - Mdrivers Pack - 437M Wheels
05-10-2017, 01:44 AM | #107 |
Rep 488
Got graphs? Do you know what kind of dyno and what correction factor was being used?
05-10-2017, 01:59 AM | #108 |
Rep 931
Try to put a printscreen soon......
4th gear, DSC OFF, "start roller on secret menu ON" http://f30.bimmerpost.com/forums/sho....php?t=1178920
05-10-2017, 02:06 AM | #109 |
Rep 931
05-10-2017, 04:16 AM | #110 |
Rep 276
