BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > B58 Turbo Engine / Drivetrain / Exhaust Modifications > *** bootmod3 for BMW B58 - Now Available ***
      05-19-2020, 02:30 AM   #1387
2rbolag
Drives: Too many to list
Are your ots maps free of charge?
And is your stage 2+ for ethanol blend?
      05-19-2020, 08:04 AM   #1388
kern417
Cheapskate
4450
You get 1 map for free when purchasing the license + OEM MPPSK tune.
To get additional maps, you need to buy the $50 map pack to unlock all the tunes.
      05-23-2020, 04:10 AM   #1389
340iNL
Drives: G81 M3 Competition '23
Weird things going on in v2.1
When I flash the car, start engine and put in D mode, the car starts in 3th gear. After once switching off on the car this issue is gone
      05-23-2020, 07:12 AM   #1390
2013mingrey335i
Drives: 2016 340i
I have also had some issues with 2.1 after starting my car I get a rough idle for a little bit then it will clear
Also on the up shift it will hesitate
I’m on stage 1 93
      05-25-2020, 03:21 PM   #1391
340ix17
340ix17's Avatar
43
Drives: '17 340i xdrive w/ MPPSK, BM3
I haven't noticed the gear issues (yet) on 2.1, but I have noticed a dramatic change in the 'startup roar'. The car startup now sounds more like the MPPSK standard startup, and drones loud for about 20-25 seconds.
In map 2.0, the startup roar came on right away (loud) but died down just as fast (few seconds). I've tried every variation available on the 2.1 map and it just does not sound the same.
*Edit* this was my fault- I failed to turn off the 'Cold Start' option when configuring the map. It's now fixed and sounds great again!
      05-26-2020, 08:03 AM   #1392
2013mingrey335i
Drives: 2016 340i
I’m probably just going to flash version 1 back but I’m not driving for a bit now anyway
      05-29-2020, 11:09 AM   #1393
340iNL
Here a short vid of changing the gears after flashing. This was in parking mode. Even when driving it won't shift down to gear 1 or 2. Only above 50 kmh I can downshift. So weird. First time I almost launched myself to the ISS in 3rd gear because I got no response like the first gear lol. Still happening! https://youtu.be/KJ2i9XkmnKg
      06-10-2020, 02:07 PM   #1394
vinzcast21
vinzcast21's Avatar
161
Drives: F30 340i MY2017
What are the hardware requirements for stage2+ 93 octane?
Mod bug will bite you if you buy a BMW
      06-10-2020, 02:36 PM   #1395
yokata
yokata's Avatar
Bulgaria
156
Drives: Bmw F30 340xi
Downpipe and upgraded hpfp like dorch st1 or TU etc.
kern4174449.50
      06-11-2020, 01:59 AM   #1396
arvi604
Drives: F30 328xi SPORT
About 70km into having a CTS turbo catless DP and bm3 stg 2 91 OTS map I have to say I am incredibly impressed. The difference going from stock to stage 2 is immense.
      06-17-2020, 08:20 AM   #1397
proTUNING Freaks's Avatar
4496
Drives: powered by bootmod3
UPDATE:
https://f30.bimmerpost.com/forums/sh....php?t=1731093
kern4174449.50
      06-25-2020, 12:22 PM   #1398
BuffaloSoldierH
Drives: 2016 340i 6MT
Oh shoot I didn't know that. So you can't run stock HPFP on stage 2 tune at all?
      06-25-2020, 12:25 PM   #1399
jackstrath
Scotland
659
Drives: 16' F31 340i & 03' Focus RS
Stage 2 yes, Not Stage 2+ tho
      06-27-2020, 06:10 AM   #1400
MTWO
Drives: M2
+1
      06-28-2020, 12:07 PM   #1401
dinan5m3
dinan5m3's Avatar
4264
Drives: e39 m5 e46 m3 g01 x3m40i
Hello,
Can someone help with few questions below?
If one has say non-stock flash tune before flashing with bootmod3, how does the reverting back to stock performance map will work? Does bootmod3 allow saving off the current stock map(s)?
My B58 DME is locked (due to recent software update campaign for rear camera fix that i end up doing, urgh...), so had to be bench unlocked first.
Does re-locking the DME to stock programming by bootmod3 cause DME to revert to that same locked state, and subsequent unlock will then again require bench unlocking?
Lastly, say one already has non-stock flash tune, eg. from Carbahn. Can bootmod3 flash on top of that non-stock maps? And also save off that non-stock maps to say ping pong between bootmod3 and Carbahn tunes?
Thannks much!
ocdx30.00
      07-05-2020, 05:08 PM   #1402
BuffaloSoldierH
Drivetrain Malfunction on Stage 1 93 Octane
Tuned to stage 1 93 octane on 2016 340i just yesterday and today after some spirited driving I got a code popping up on idrive saying Drivetrain Malfunction, max power output not available. Is this common? What do I do to troubleshoot?
      07-05-2020, 09:45 PM   #1403
G.Newt
Drives: CT4-V Blackwing 6MT
Read the codes.
2022 CT4-V Blackwing 6-speed
SOLD: 2016 340i xDrive 6-speed
DAW v2.5 turbo E40 | Dorch S2 | VRSF DP | MST intake | AWE catback | 335is clutch | CSF heat exchanger | RK Autowerks intake manifold | Orange M Perf Brake Kit | KW Street Comfort coilovers | GTS taillights V2
kern4174449.50
      07-06-2020, 07:45 AM   #1404
kern417
Cheapskate
4450
Originally Posted by dinan5m3 View Post
Hello,
Thannks much!
Bench unlock can't be fully reverted over OBD until an exploit is found. It will "lock" it in the same sense that other DMEs are locked prior to the update you received.
The stock file that is backed up by bootmod3 is whatever you are running when you do the unlock. So if you have stock, MPPSK, or another aftermarket tune, it will back that up as the stock file. If your stock DME programming is ever updated, PTF can clear your stock file so you can backup the new one (I did this later year after a recall DME Update).
      07-07-2020, 09:00 PM   #1405
hoyas490
Drives: '21 M550i
Hey all, just acquired a BM3 license for my 2018 440xi 6MT. Waiting on cables to arrive Thursday to get things started, but before they arrived I wanted to sort out which tune I should be using.
Currently has about half a tank of midgrade (89) from Ny but I'll be putting premium in moving forward (93). No performance mods (just exhaust valves unplugged and dinan mid pipes) and the car has 16,7xx miles on it.
What tune should I be using? Can I safely do a Stage 2 91/93 octane tune? Or should I stick to a stage 1 tune?
Am I safe selecting Stage 2 93 with AGG or OTS burbles using stock cats/pipes?
And which B58-T0-x OTS tune should I use? I see a lot of T0-B/C/D in the BM3 web index right now.
Appreciate any guidance as I'm a bit of a newbie at this!
      07-07-2020, 10:10 PM   #1406
Jay5k
Jay5k's Avatar
88
Drives: 2017 BMW 340i
Stage 1 93 with stock cat.
Stage 2 93 with high flow cat or catless.
Stage 2 93 AGG with catless.
      07-08-2020, 08:11 PM   #1407
hoyas490
Drives: '21 M550i
Thank you!
Any guidance on if there is a difference in the different B58-XX-Xx OTS tunes I see? Or are they all the same?
      07-10-2020, 09:51 PM   #1408
BuffaloSoldierH
Read the codes.
The codes were for clutch damage but since this happened literally one day into the tune I assumed it wasn't an actual issue but a result of the flash. Turns out BM3 has a "recode" option that will clear the code and they specifically call out that the drivetrain malfunction that pops up sometimes after a successful flash. Hope this helps anyone else freaked out by the same issue
bm3, bootmod3
