11-05-2019, 03:32 PM | #1167 | |
Cheapskate
4450
Rep 4,993
AlexM240i101.50 |
11-06-2019, 02:08 AM | #1168 | |
Rep 205
18? 340 XDRIVE
#BM3TUNING |
11-06-2019, 12:10 PM | #1169 |
Rep 446
I set everything to OEM but notices that there are more burbles in sport+, is it supposed to be like that or I need to reflash? I dont want to destroy my CAT
Mod bug will bite you if you buy a BMW ================================= |
11-06-2019, 12:47 PM | #1170 |
Rep 1,369
You're right. I was thinking it was Cary.
2017 M240i/ ZF8 Pure Drivetrain Solutions Stage 1 & torque converter/xHP/ DAW Ultra Flow/ DS2/ Nostrum injectors/ E40 Doug Newton tuned/ ER DP/ Remus axle back/ BMS intake/ FTP CP/ M Perf LSD
11-06-2019, 06:42 PM | #1171 |
Rep 775
I'm getting a very odd almost slippage. I'm stage 2 with catless downpipes and it seems that whenever i get on the gas hard in second or third at 3-4K RPM the car kind of shakes/shudders a little bit. any ideas? car is a six speed if that has anything to do with it
2016 340i xDrive 6MT (regretfully sold)
2020 M340i xDrive |
11-06-2019, 07:04 PM | #1172 | |
Rep 1,454
11-06-2019, 07:19 PM | #1173 |
Rep 775
I rarely ever launch from a stop. It happens when I give it like 75% throttle, gets up to about 3-4K RPMs, then the RPMs shoot up to like 5-6K, simultaneous with the shaking, and then drop back down to 3-4K as I'm letting off the gas. Happened in 2nd and 3rd, haven't tried in any higher gears yet
2020 M340i xDrive |
11-06-2019, 07:21 PM | #1174 | |
Rep 1,454
2022 CT4-V Blackwing 6-speed
11-06-2019, 07:22 PM | #1175 | |
Cheapskate
4450
Rep 4,993
11-06-2019, 07:25 PM | #1176 |
Rep 775
You think it's the clutch? I wasn't sure if that's what it was. Even though I'm not on the clutch when this happens?
2020 M340i xDrive |
11-08-2019, 01:13 AM | #1178 | |
IG @bmwF9xG80
3813
Rep 7,593
PS. Congrats on your STG1 E30 Accomplishments! 0-60 3.60s! 1/4 mile 11.61s@118mph
60-130mph 6.5s X4M #HCP
11-08-2019, 03:06 PM | #1179 |
Rep 43
Maybe I've missed it, but are there any updates for the BM3 transmission flash for the B58 (auto 8hp50, not manual)?
I know they were working on one, and had testers out there using it. I was looking at xHP, but where I already have a BM3 tune (stage 1), would prefer to "keep it in the family" if possible |
11-09-2019, 09:19 AM | #1180 |
Rep 775
I forgot my laptop at work so I haven't been able to get a log yet...but would clutch slippage cause the drivetrain malfunction light to come on? Happened again last night. Few pulls in 4th gear, got a little slippage, and on the last one the drivetrain malfunction light came on. I'm hoping it's just the clutch and nothing serious
2020 M340i xDrive |
11-09-2019, 11:27 AM | #1181 | |
Rep 171
340ix1743.00 |
11-09-2019, 12:57 PM | #1182 | |
Rep 775
Guess it's time for a new clutch. Really strange because the car only has 22,500 miles. And I've had 4 other manual BMW's before this so it's not my driving that's the issue
2020 M340i xDrive |
11-09-2019, 01:53 PM | #1183 | ||
Cheapskate
4450
Rep 4,993
The good news is you can probably do a torque reduction in the config menu and flash that map. At least then you can put the power down without errors until you get a new clutch. Did you get a chance to log at all, or just check the error codes? I wonder if it's from a boost spike. It seems like some stage 2 people get boost spikes/throttle closures that'll increase the torque that your clutch sees. Can you add your experience here? Just to keep the info in one place. https://f30.bimmerpost.com/forums/sh....php?t=1628178 |
11-11-2019, 07:49 AM | #1184 | |
Rep 775
I'm wondering if my new commute is bad for the clutch, I bought this car at 19K miles in June and now I'm at 22,500k, my commute Monday-Friday is very short, .8 miles one way. So when I get to work, the car is still cold. Then I turn it on after work, drive .8 miles home and shut it off cold again. I wonder if this is causing pre mature wear on the clutch
2020 M340i xDrive |
kern4174449.50 |
11-11-2019, 08:52 AM | #1185 |
Rep 248
Just flashed stage 1 and WOW! This thing pulls like a freight train in all gears.
Does anybody know when the GTS Roar engages? I started it up this morning and it didn't do it, maybe because it was cold outside (40f)? Also, did anybody else's Sports Display change to absurd numbers? My car definitely isn't making 580 lb/ft |
janea120728.50 |
11-13-2019, 09:24 PM | #1187 |
IG @bmwF9xG80
3813
Rep 7,593
That is current
bm3, bootmod3 |
