03-18-2020, 12:31 PM | #1365 | |
Rep 22
kern4174449.50 |
03-18-2020, 01:29 PM | #1366 |
Cheapskate
4450
Rep 4,993
yes
03-19-2020, 12:39 PM | #1367 |
Rep 242
Can someone read and comment my logs pls.This is st2 93 https://www.bootmod3.net/log?id=5e73...0b43508e6f9303 https://www.bootmod3.net/log?id=5e73...0b43508e6f92fc
03-19-2020, 01:05 PM | #1368 | |
Rep 1,454
03-19-2020, 01:08 PM | #1369 | ||
Rep 242
03-19-2020, 02:09 PM | #1370 | ||
Rep 151
To get adequate measures of load simple and fast, select corresponding parameters in the RAM tab in BM3 logging section. That's my set of parameters that I log time to time (stock tune): https://www.bootmod3.net/log?id=5e72...0b43508e6f84ef
Kirill @ OdinTuned
03-19-2020, 02:34 PM | #1371 | |
Rep 242
03-20-2020, 08:59 AM | #1372 | |
Cheapskate
4450
Rep 4,993
03-22-2020, 06:28 PM | #1374 |
Rep 1,862
Drives: powered by bootmod3
YouTube Channel [NEW] | Facebook User Group (20,000+ members) | Tech Support Website | Wiki | FAQ | iOS App | Android App | bootmod3 Web
Sales Support Email: sales@protuningfreaks.com | Tech Support Email: support@protuningfreaks.com |
kern4174449.50 |
03-27-2020, 06:31 AM | #1375 |
Rep 69
Wondering if someone could have a look on my datalogs. I got a '17 340i xdrive with MPPSK
I get the knock detected (1) value with the stage 1 91 or 93 tunes. I have not changed my plugs/coils or gapped them (45.000 km on the clock). My tuner told the OTS maps are safe without chaging plugs or gapping them. So I ran a log with the stock tune but still the knock gets detected. Now I'm wondered if something wrong with my plugs in the beginning or is this normal behavior for my car? My tuner told me to try different types of gas but that did not help. Log with stock stune https://www.bootmod3.net/log?id=5e7d...0b43508e701215 Log with stage 1 91 https://www.bootmod3.net/log?id=5e54...0b43233e40a9af Log with stage 1 93 https://www.bootmod3.net/log?id=5e70...0b43508e6f7477 Ofcourse for each log was the right fuel used. |
03-27-2020, 07:05 AM | #1376 | |
Rep 585
The Stage 1 93 where you held 100% accelerator 2nd, 3rd and 4th you only had a single knock count in 2nd gear at low RPM. At 6400 RPM in 4th you've got perfect 12 degrees of timing across all cylinders at 15.8 PSI and an AFR of 12.6 which is nice. You should try Stage 2 93 now Enjoy
Tesla Model 3 Performance 0 - 60mph 3.1s
M140i LCI Mineral Grey Dorch Stage 2 HPFP, CG Precision DS-1, XHP, MHD Stage 2 HPFP E30 @ E42 100 - 200 6.96s Quarter mile 10.93@127mph |
03-27-2020, 12:43 PM | #1377 | |
Rep 69
I do expect some minor rough idling on the OTS maps compared to the stock tune. But my G12 m760li got a much rougher idle than my 340i stock... so I don't really think that's a big issue. So why would people use colder plugs or gap the original then, because it's maximum optimized to get more power out of the engine? Yeah, I would like to get stage 2 someday. My only worry is that it's a little bit too loud hehe. |
03-28-2020, 12:09 AM | #1378 | |
Rep 585
You should put in a new set of NGK 94201 spark plugs. 45.000km is quite a lot for plugs. I changed mine at 42,000km.
03-28-2020, 08:04 PM | #1379 |
Rep 1,369
^^ Man, I still don't know how you trapped 121 on an OTS E30 map on stock DP. That's impressive.
2017 M240i/ ZF8 Pure Drivetrain Solutions Stage 1 & torque converter/xHP/ DAW Ultra Flow/ DS2/ Nostrum injectors/ E40 Doug Newton tuned/ ER DP/ Remus axle back/ BMS intake/ FTP CP/ M Perf LSD
03-28-2020, 11:31 PM | #1380 | |
Rep 585
The 95 octane map has higher Torque/Load target, so higher boost than the E30 map. I'm not sure why my HPFP is hanging in there, maybe because of the 93 base fuel, or just because I've run E30 for 6 months plus and it's adapted? |
04-21-2020, 04:09 PM | #1382 | |
Rep 1,597
05-08-2020, 06:04 AM | #1383 |
Rep 69
05-08-2020, 07:51 AM | #1384 |
Cheapskate
4450
Rep 4,993
opposite. only does it when the engine is already warm. normally the first start in the morning won't do it, but it will starting the car after a drive.
05-16-2020, 06:18 PM | #1385 |
Rep 1
Question on tuning
Just purchased the bootmod3 stage 1 93 tune on my b58.
Does anyone know if you can configure the other sport modes (sport+, sport individual)? I adjusted the burbles for sport mode, but when I put the car in sport+ it doesn't seem to make as much noise. Was curious to know if there's a way to adjust the sets for the different types of sport modes the car has. |
05-17-2020, 12:08 PM | #1386 | |
Rep 242
bm3, bootmod3 |
