01-08-2019, 08:39 PM | #1651 | |
Rep 47
Have you searched 'Bluetooth' on this thread? Can you tell us more about your setup... What versions of the firmware and software do you have at present? Are they the same versions you had when Bluetooth did initialize? Last edited by Geoken; 01-08-2019 at 08:54 PM.. |
01-09-2019, 03:03 AM | #1652 |
Rep 116
I've got an issue with CarPlay, I'm not sure if I'm the only one..
With the latest update everything works perfectly, BUT when I receive calls it switches to the OEM interface.. Does anybody know how to solve this issue? Note: I'm connected to the OEM system with bluetooth because of the microphone (which works great with CarPlay since the last update). |
01-09-2019, 11:29 AM | #1653 | |
Rep 7
Trying to attach a screen showing the version as well as the bluetooth stuck in the initialising state. I think I found other references to bluetooth stuck in this initialising state (can't remember if on this thread or from a google search) with no resolution/response. Does the app updates allow you to downgrade as well? Was wondering if I could do a downgrade back to the earlier version, pair my phone, then upgrade back. But that won't help if the newer version does not get past init. I assume bluetooth is working for most on the latest app version? |
01-09-2019, 11:42 AM | #1654 | |
Rep 102
01-09-2019, 12:13 PM | #1655 | |
Rep 206
Any help? |
01-09-2019, 12:55 PM | #1656 | |
Rep 219
Drives: MINI Cooper, 2020 X1
01-09-2019, 01:07 PM | #1657 | ||
Rep 206
01-09-2019, 01:19 PM | #1658 |
Rep 219
01-09-2019, 01:21 PM | #1659 |
Rep 206
01-09-2019, 03:17 PM | #1660 |
Rep 206
After creating the folder and placing the file inside when I select update config and nothing happens...
01-09-2019, 11:35 PM | #1662 |
Rep 33
01-10-2019, 05:18 AM | #1663 | |
Rep 116
01-10-2019, 01:46 PM | #1665 | |
Rep 7
Can someone confirm the ability to downgrade the app version to an older version just by doing the usual update but with the img file of the older version? I may try downgrading to see if I can figure out at which version BT broke. |
01-10-2019, 01:49 PM | #1666 |
Rep 219
hopefully it will help
01-10-2019, 06:02 PM | #1667 |
Rep 7
Help !!!
New here, although in the shade. I have read everything you could. To the subject Yesterday I received the screen I asked for. Today when it came to riding, I had two problems The screen on the BMW side says "no signal". You hear everything, the radio, the navigation, the hard disk etc, but the screen is not activated. On the Android side you can not hear it in any application and what you have selected in the BMW part still sounds. |
01-11-2019, 05:26 AM | #1668 |
Rep 26
Here is an update from the supplier of my stereo, PX3 7.1, not tested yet
https://www.aliexpress.com/item/10-2...20384c4dlul78T Update https://drive.google.com/file/d/1fRY...zxongBfXz/view Last edited by Werra2006; 01-11-2019 at 05:44 AM.. |
01-11-2019, 06:51 AM | #1669 |
Rep 206
01-11-2019, 08:48 AM | #1670 |
Rep 33
It would be great to hear how people are doing with Carplay after latest updates indeed.
I was myself positively surprised that I was able to communicate with Carplay simply saying "Hey Siri" when phone is connected with cable to the device and also bt connection to the BMW original bluetooth. However, I am getting a bit lost that I can talk to Siri and ask for example navigation guidance, but when trying to make phone call, it is just dead silent (unless I select from phone that the speaker is car bluetooth). Is it working fine with phone calls with rest of us? |
01-11-2019, 08:56 AM | #1671 | |
Rep 33
However as you seem to be able to get to Android side, perhaps you should start by checking from factory settings and try an another display size? |
01-11-2019, 09:09 AM | #1672 | |
Rep 116
The only thing that bothers me is that when i RECEIVE calls it switches back to the OEM system.. Does it happen also to you? |
