02-03-2019, 07:33 AM | #1783 |
Rep 1
Hi, I bought the Android 7.1 for a BMW E60. I have a problem. When the device is cold, after the night, the device does not start correctly. The screen is black and there are white stripes. I must turn off the radio and turn it on several times. After a few turns on the ignition/radio the CCC Android works ok.
View post on imgur.com Anybody knows what's going on? Sorry for my English. |
02-03-2019, 08:18 AM | #1785 |
Rep 190
02-03-2019, 12:33 PM | #1786 | |
Rep 6
Since that trip i had shorter journeys and it din`t blacksceen on me any more .I changed the position of the antenna near the top of windshield in the tinted area (i took out the antenna from the housing , is much smaller without housing and oriented the ceramic part towards the sky) and routed the cable on the right pillar( the gps signal is more stable it doesn't jump around allover the map ) .I stopped using google maps ( very slow) and waze ( auto shuts down ) . I`m using here maps but i miss police nad radar reporting on waze . |
02-04-2019, 02:27 AM | #1787 | |
Rep 102
02-04-2019, 10:56 AM | #1788 | |
Rep 19
02-04-2019, 01:25 PM | #1791 |
Rep 19
This is impossible because the ccc system works when you switch the menu button. When I switch back to android it does not work.
02-04-2019, 01:27 PM | #1792 |
Rep 19
02-04-2019, 02:57 PM | #1793 |
Rep 6
Here is a picture, unfortunately the cable is not long enough to be routed in the glove box to be hidden and i also couldn't remove the right pillar (the cap that is covering the screw is too fixed i dint want to insert something sharp) i just forced the cable more or less under the pillar .For me is kind of a temporary fix , i need to buy a fakra splitter to get the signal from the car antenna , the problem is that my unit that has external box has SMA connector for GPS so i have to buy a fakra splitter + a fakra to SMA addapter ( i think for me there should be no problem with splitter being a CIC , i herd people having problems with splitters with NBT , someone correct me if i`m wrong ) ...the antenna without housing looks like bellow .
02-05-2019, 04:44 AM | #1795 |
Rep 47
Hi Druw, GPS splitter works fine on my Android 7.1 and CIC units. I split from the standard BMW GPS cable not from the supplied GPS antenna. Never had any issues with it from day one. Might be different with NTB?
02-05-2019, 12:39 PM | #1796 |
Rep 19
I have both GPS antennas connected. The original one is connected to the original radio, in the sense where there is room for a CD, and an additional antenna is connected to the android screen. Could this be a problem with "no signal" on android?
02-06-2019, 01:23 AM | #1797 | |
Rep 102
02-06-2019, 01:27 AM | #1798 | |
Rep 297
This is on an F30. |
02-06-2019, 11:16 PM | #1799 |
Rep 102
Interesting, but I don't see how the antenna can fit there. Have you removed the casing? If you have any images from the assembly, it will be very helpful.
02-07-2019, 01:26 AM | #1800 |
Rep 297
02-07-2019, 01:53 AM | #1801 |
Rep 19
Does anyone have a link to download the "FM radio" application like it is shown in this video at 1:00 on the right side of the screen? Link to the movie
www.youtube.com/watch?v=WWBF9TCuvOM |
02-07-2019, 08:22 AM | #1802 | |
Rep 6
02-07-2019, 12:23 PM | #1803 |
Rep 606
Ok, this is weird...
Today Waze keeps crashing at startup and also all apps are directly killed when closed. The multi screen button on top doesn't show anything. And GM suddenly works?????? I am going to upload the latest firmware to see if that fixes it but this is very strange all of a sudden.... |
