06-20-2019, 04:50 PM | #442 |
Rep 63
where are you applying the rubber? I bought some gorilla water proof tape and tried to tape off the tail lights... its better, but i recently washed my car and it actually happened again... there must be an area that is exposed somewhere that is letting water in
06-20-2019, 10:57 PM | #443 |
Blocked from G80/G82 for having an opinion
3497
Rep 3,729
06-21-2019, 03:33 PM | #444 | |
Rep 62
regarding the depo lights, I returned mine, I couldn't stand them, the condensation never improved over time, I'm sure there is a leak somewhere near the edge on the pointed corner towards the side of the car, you can see the pinched weld is very narrow |
06-21-2019, 05:54 PM | #445 |
Rep 1,953
Drives: 2013 328i xDrive
Yeah I've never heard of any OEM owners having condensation. If there is I'd imagine it's a manufacturing defect and affects a small percentage of owners. Meanwhile it seems like every Depo owner has condensation. I can't imagine any OEM part having condensation. Can you imagine if the car you bought had condensation? You'd complain to the dealer, and rightly so!
06-22-2019, 12:42 PM | #446 | |
///M SubDriver
1832
Rep 2,782
Drives: 2017 M3, 2020 X7 40i
The OEM ones can and do have condensation and the BMW factory maintenance procedures cover it. If the condensation is too bad, they can be replaced under warranty. However, I speculate that the criteria for warranty replacement will vary depending on your location. I also speculate that the cause of the condensation in the OEM ones has to do with where they are stored (at the factory, vendor storage, etc). The more humid/cool the storage environment, the more likely moisture can get trapped inside the light assemblies. The good news is that the light assemblies are designed to take care of condensation (i.e. they are not completely sealed) which is why light to moderate condensation should dissipate over a short period of time - like what happened to my lights. Now as far as non-OEM lights are concerned, quality control is another factor as typically non-OEM quality control is not always the same as OEM (but it can be YMMV)....
///M3 COMPETITION 6MT - 2017 F80 Smoked Topaz Metallic
BM3 / MP-HAS / GC Camber Plates / Carbonstructure Interior X7 XDrive 40i ///M-SPORT - 2020 G07 Arctic Grey Metallic X3 XDrive 30i - 2019 G01 Mineral White (wife's) / 128i 6MT - 2009 E82 Jet Black (son's) Last edited by jmciver; 06-22-2019 at 12:50 PM.. |
06-22-2019, 06:32 PM | #448 |
///M SubDriver
1832
Rep 2,782
Good point, considering they are not DOT approved in the US due to the lack of integrated side reflectors. However, you should at least have a chance if they were purchased from a reputable vendor.... YMMV of course...
BM3 / MP-HAS / GC Camber Plates / Carbonstructure Interior X7 XDrive 40i ///M-SPORT - 2020 G07 Arctic Grey Metallic X3 XDrive 30i - 2019 G01 Mineral White (wife's) / 128i 6MT - 2009 E82 Jet Black (son's) |
06-22-2019, 06:37 PM | #449 | |
Rep 10,473
07-02-2019, 12:16 AM | #450 |
Rep 552
Finally got mine installed last week. Took a bit more coding than just changing everything to LED and disabling the monitoring checks. Needed to make quite a few changes in the advanced section of BimmerCode REM to get the full combined inner+outer amber signals and a few other things to function as intended. Specific coding here: https://f30.bimmerpost.com/forums/sh...2&postcount=47
I was initially on the fence but I'm really happy with how they look in person. Compliments my other black/CF accents. Not a daytime pic but here's a shot. Last edited by mlev; 07-02-2019 at 12:22 AM.. |
07-17-2019, 02:55 AM | #451 |
Rep 1,407
selling mine, locally in los angeles. (that means will not ship)
ceramic coated with opti-coat pro 1 month ago. DM me IG @340i_bsm_cr
Diligentia Vis Celeritas
10-09-2019, 04:49 PM | #453 |
Rep 63
I have a rear tail turn signal malfunction and noticed that there is condensation in my taillights again anyone have this issue?
Where do I get usr turn signal bulbs from? It's not listed on their site |
10-09-2019, 09:22 PM | #454 | |
Rep 358
You're just getting a replacement bulb if there is something wrong with one of them, the bulbs aren't manufacturer specific to the company who makes the lights. And if you think you are having a malfunction with the turn signal, check the connections, not the bulb. Or just swap out the bulb from the other side to eliminate 1 possibility.
10-16-2019, 01:38 AM | #455 |
Rep 177
My prelci tail lights have LED turn bulbs, LED brake light bulbs, and LED reverse bulbs. Can I swap those out and put them in these / are the bulb sizes the same?
Does the black line depot require only one LED brake light bulb for the inner and outer portions? |
02-01-2020, 12:33 PM | #456 | |
Rep 19
As for the rest of the bulbs in the tail lights, all are built in (on the OEMs and Depos) so you don't need bulbs. Only the reverse are changeable. |
02-01-2020, 12:39 PM | #457 |
Rep 19
My Blackline Upgrade: US 2014 F30
OEM's a bit more work in terms of connectors and coding, but so glad I used them. Last pic is mine next to my neighbor's '18. I recommend the OEM Blackline and the OEM harness with Bimmercode coding. No plastic resister boxes!
I added the OEM Harness instructions as it tells you how to wire everything as well. |
03-13-2020, 11:16 PM | #459 |
Rep 1,171
So for the people who did the retrofit, is this the right lights to retrofit onto my 2015 pre LCI? https://www.schmiedmann.com/en/bmw-f...3212450105BMWT
2020 X3 M40i
2015 328i - Sold @ 104,000 miles |
03-07-2021, 10:22 PM | #461 |
1038
Rep 729
I have 7 of these in stock in Michigan with the wiring harness. I can ship anywhere in the world. My fellow Canadian neighbors don't have to pay any crazy customs since we can ship from our Windsor location. That's a huge added saving for you guys. PM me if you're interested. I don't even have LCI taillights listed on my website because the demand is too high and supply is too low.
