10-23-2024, 11:29 AM | #1 |
Rep 135
Low mileage F80 Calipers/Rotor/Pads
Up for sale are my F80 Rotor/Caliper/Pad set. They were removed from the car at 25k Miles so barely used. Never tracked or done a burn out on these brakes so the calipers are still deep blue with visible metal flakes. If you’re looking for pristine brakes, these are it. Calipers were dry ice cleaned and ceramic coated about 2yrs ago. Ceramic coating still appears to be holding up as I all I did was rinse them off under the hose before taking these pics. Brake pads and Rotors still have a ton of life left. Depending on your driving style you can probably pull another 25-30k out of them. Front Pads are 9.82mm thick from backing plate. (Starting thickness 10mm) Rear Pads are 9.60mm thick from backing plate. (Starting thickness 10mm) Front Rotors are 29.47mm (starting thickness 30mm) Rear Rotors are 23.67mm (starting thickness 24mm) Willing to ship at buyers expense but would prefer local pickup in the Central FL area. Feel free to PM with any questions. |
12-16-2024, 07:15 PM | #9 |
Rep 135
Sorry, thought I responded. These have been sold a while ago. I marked it as sold but for some reason it’s not showing in the listing that’s why it has $0.
