BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > B58 Turbo Engine / Drivetrain / Exhaust Modifications > Anyone else see these MP stage 2 engine & tranny tune numbers on stock car? WOW!!
      01-15-2019, 03:06 PM   #1
chenry
Drives: BMWs
I follow MP on IG and just came across this from earlier today...
David0ff1059.00
      01-15-2019, 03:22 PM   #2
B58togo
Drives: M240i
I got stoked. Then I saw it was uncorrected.
      01-15-2019, 03:32 PM   #3
chenry
Drives: BMWs
Good eye
      01-15-2019, 04:46 PM   #4
MissionPerformance
MissionPerformance's Avatar
Drives: '17 F31 340xi US Spec
Here you go, WinPep8 manually sets correction:
      01-15-2019, 05:30 PM   #5
StockLOL
Drives: 2018 340i MPPSK
So it’s safe to run the stage 2 flash on a stock downpipe? No issue with too much back pressure? I have the less restrictive MPPSK exhaust so maybe that would help in my case?
      01-15-2019, 05:55 PM   #6
grassy_91
Drives: '18 340i
Is there any room for more power with meth or no?
      01-15-2019, 06:39 PM   #7
cobra2814
cobra2814's Avatar
Drives: 2018 BMW M4 Competition
Wow, that's insane. I want to get this but having to throw in E85 all the time is a real pain. Is there a Stage 2 tune that can be safely run with just 91 octane?
Also, this car must be a monster to drive on the street! Heck, even with my stock MPPSK, I can get significant wheelspin shifting into 2nd under WOT. This thing must lay rubber for days lol
      01-16-2019, 11:52 AM   #8
B58
B58's Avatar
558
Drives: 922 Turbo
Of course meth is just another power adder I’m expecting the B58 to be close to or over 500whp with meth, bolt ons, and more E85.
      01-18-2019, 12:42 PM   #9
kern417
Cheapskate
4447
Maybe it's just me, but these stage packages make no sense if all of them can be run on a stock car. It would eliminate a lot of confusion and question if they consolidated everything.
      01-18-2019, 12:53 PM   #10
CruzM3
CruzM3's Avatar
Drives: 2018 M3 "Velocity Edition"
Just because you can doesnt mean you should. Like the original post said you have adequate fueling for Stage 2 & 3 which is why the E85 is added. In another thread they are recommending that you be FBO or at least have a downpipe
2018 M3 ZCP "Edition Velocity"
2018 X3 30i (wife’s)
2017 340i w/ MPPSK & Many M Performance Parts (sold)
2016 328i (sold)
      01-18-2019, 02:17 PM   #11
GT500R
Drives: BMW X3M
Well the way I see it.
Engine Tune | Trans Tune
Stage 1 - 91 octane minimum | Stock Trans Flash
Stage 2 - 93 octane minimum | Stock Trans Flash OR Stage 1 Trans Flash
Stage 3 - 93 octane minimum | Stage 1 Trans Flash OR Stage 2 Trans Flash
I don't think there are huge benefits of a trans flash with Stage 1 engine flash as gains aren't as aggressive.
Stage 2 engine flash definitely benefits from a Trans flash but not required.
Stage 3 needs a trans flash.
I think that clarifies it...
X3M Alpine White - SOLD
Fastest Tune Only Record - Mission Performance
10.84@127.43 / +1912 DA NH Dragway |
10.6@130 Dragy / +820 DA The Streets |
NOW: Tesla Model Y Performance
      01-19-2019, 01:55 PM   #12
kern417
Cheapskate
4447
So if you shouldn't, then why are they saying it's ok? What's the point of having multiple stages that can be run on a stock car? Why publish an uncorrected dyno graph with a car running compensation measures for a tune that isn't ideal for it's setup?
Every other platform I have experience with has a stock tune, a downpipe/bolt on tune, and then tunes for upgraded turbos. I understand having different grades for different fuels but now you have a bunch of people asking how high of a "stage" can they run with random combinations of parts (or little to none). It doesn't make sense to even present it as an option if it's not safe.
Not really. I mean i understand a need for both 91/93 tunes, but the trans flash shouldn't have anything to do with the tune. Especially when a lot of people, like me, can't flash our transmissions. And a lot of people just want a transflash to wake up the driving experience without an engine tune.
      01-19-2019, 02:56 PM   #13
GT500R
Drives: BMW X3M
But the trans is the limiting factor when it comes to hitting higher torque numbers (torque reductions) and shift speed. No point in hitting huge boost levels or high torque targets with the ECU when your trans is going to shut you down anyway. They need to play nice together. Not sure how else to explain.
      01-19-2019, 07:55 PM   #14
B58togo
Drives: M240i
Wonder what a catless downpipe and 93 with a couple gallons e85 would make. Probably break 450!
      01-19-2019, 08:51 PM   #15
RTPenland
Drives: Many BMWs
Maybe it's just me
yup just you....
      01-20-2019, 10:31 AM   #16
kern417
Cheapskate
4447
I have a manual transmission. It has no bearings on my decision.
And if that is the case, then they should set clear requirements for each stage. That's not too much to ask. All of the overlap makes no sense.
Originally Posted by RTPenland View Post
yup just you....
If you say so. But every other major tuner says otherwise. How many maps does JB4 have for a stock engine with the same fueling? Cobb? BM3? I could reference tuners on other platforms too.
eluded3038.00
      01-20-2019, 01:05 PM   #17
GT500R
Drives: BMW X3M
JB4 Map 1 and Map 2 can use 91 octane. Map 2 and Map 3 can use 93 octane
But don't forget Map 6 can be used for custom tuning so you can use that also with either 91 or 93... and if you have bolt ons then you can probably use either Map 3 or Map 5, so all this above is quite clear I'm sure...
How about just calling Alex and asking instead of continuing to waste time on this?
B58togo808.50
chenry2357.50
      01-20-2019, 01:08 PM   #18
RTPenland
Drives: Many BMWs
you referencing how other tuners market their products has nothing to do with your admitted confusion over what MP is doing - so again yes you seem to be the only one that doesn't get it -
DigiSage143.00
      01-20-2019, 01:16 PM   #19
chenry
Drives: BMWs
yes please - that is a great suggestion. Kern417, would you kindly start your own thread on the knowledge you are seeking relative to MP's marketing and offerings....I'd appreciate getting back on topic - thanks
B58togo808.50
      01-20-2019, 03:43 PM   #20
B58togo
Drives: M240i
Yes, let's keep this thread on track. Alex, can you please throw a catless DP on this car and re-dyno?
      01-20-2019, 09:04 PM   #21
kern417
Cheapskate
4447
I'm off topic? First few posts pretty much solved the mystery. Posts 5, 6, and 7 are asking what's needed for various maps. 3 posts in a row of unsure potential customers. And it's the same sort of questions in all of their threads. I mean now it's not even stage 1 and 2, they're advertising stage 2+? But you guys got it.
      01-20-2019, 09:10 PM   #22
chenry
Drives: BMWs
okay guys - like I posted in my other thread off to MP tomorrow to see what the next stage and trans flash will get me - will post results soon / may have another forum member joining me / anyhoo - good times ahead
eksigned139.00
