BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Mechanical Maintenance and TSBs: Break-in / Oil & Fluids / Servicing / TSBs and Service Bulletin > Oil Change Now Car Won't Shift out of Park?
      09-16-2018, 03:02 PM   #1
dorkiedoode
dorkiedoode's Avatar
Drives: 2018 BMW 340i M Performance
Angry Oil Change Now Car Won't Shift out of Park?
I changed the oil on my 16' 428i GC and now the car won't shift out of park. Would anyone have any ideas on why?
It was a fairly simple process.. drain the oil and torque the plug back to 8Nm. Filled the car back to 5 quarts of genuine bmw 0-20w oil and change the oil filter/orings torqued to 25Nm. Car starts fine and shows the oil level is good...
I'm stumped. When shifting out of park to D or R, it would automatically go back to P.
      09-16-2018, 05:22 PM   #2
F30RiK
Drives: 13' 335 xdrive M-sport 6 Speed
close the door
      09-16-2018, 06:54 PM   #3
Billfitz
Billfitz's Avatar
Drives: '15 328iX GT
It takes 5 liters, not 5 quarts, but that shouldn't cause it to stay in park.
      09-16-2018, 08:01 PM   #4
Savageenterprise
Drives: 2018 340i xdrive
I don't know how car savvy you are but I have to put it out there. Did you drain your transmission fluid by accident instead of your oil?
      09-16-2018, 11:42 PM   #5
dorkiedoode
sigh... yepp that's exactly what happened. I guess coming from Japanese cars the drain plug for ATF and oil is noticeable different. When I was under the car, I saw "Oil" mentioned in two different locations while the Japanese cars would say "ATF" or "transmission fluid" or "fluid." I guess it should have registered in my head that the pan was way too far back.....
Fixed now but lesson learned. Ahhh first time owning a german car obliviously..
Thanks everyone.
Good thing the 340 is my secondary
      09-17-2018, 12:13 AM   #6
bavarianride
Drives: bimmer
Did u refill transmission with drained oil? ZF has a delicate process to refill, but as long the same amount drained is then refilled it should be OK.
      09-17-2018, 06:23 AM   #7
Savageenterprise
Thanks everyone.
Hey man, things happen. At least it was something simple, cheap and easy to rectify
"You can't deposit excuses"
2018 340ix 6MT//BSM//Coral Red int//Alum Dark Carbon//19 in 704M double spoke Orbit Grey OEM wheels//CF side mirror caps//CF trunk lid spoiler//Dinan mid pipe res delete//BMS intake//Active Autowerke A8//Gloss Black M style grills//IND BSM Reflectors
      09-17-2018, 07:22 AM   #8
Billfitz
Billfitz's Avatar
This points out why it's a good idea to check a service manual before doing anything on these cars. They're not 57 Chevys.
https://www.newtis.info/tisv2/a/en/
      09-17-2018, 10:37 AM   #9
_bdiddyb_
Drives: 2013 335i
OMG !
      09-17-2018, 10:43 AM   #10
montr
Drives: 2010 335d, 2018 430i G-Coupe
To prevent contamination, I would not re-use the drained ATF.
I did recently an ATF and oil pan/filter change on my 2010 335d. You have to follow carefully the ZF transmission instructions. If you fill the transmission up to the neck of filling hole without engine running, the transmission will be under filled.
      09-19-2018, 07:56 AM   #11
jh_f30
jh_f30's Avatar
608
Wait. What about the EXTRA 5qts of oil now in your car??
~Remus Sport Axleback~VRSF Chargepipe~VRSF Catless Downpipe~HR Sport Springs~CF Rear Lip Spoiler~Active Autowerke OBD Flash Tune Stage 2~
rjdnyy2241421.00
      09-19-2018, 08:10 AM   #12
bimmer456
Drives: 340i
Is this a CPO car you should get free oil changes if you brought it new. Also like previous poster said you may have too much oil in your engine now. I though the ZF was a sealed transmission I guess I'm wrong. Messing with ATF can be sketchy at best. If you do it wrong you could ruin the transmission.
      09-20-2018, 01:41 AM   #13
jv004
Drives: F32 435i, E70 X5D
2014 435i Coupe  [0.00]
I would be worry about that extra 5 quartz. Hopefully it was drained and refilled.
Wagner Evo II FMIC /// VRSF CP // CTS Turbo CAI // Wagner Catted DP // Dinan Exhaust // GFB DV+ // H&R Super Sport Springs // BM3 Stg 2 93oct Tuned // Future PS2 Upgrade
      09-20-2018, 06:49 AM   #14
rjdnyy224
rjdnyy224's Avatar
Drives: 2013 328i xDrive
OP, these things happen to the best of us lol. But just re-cap: you've got to re-fill the trans with the proper amount of new ATF (not sure how much that is) and then I assume you drained all the oil from the engine and refilled with 5 liters of that 0W-20? Hopefully you didn't run the engine too much with nearly 10 liters of oil in it.
Also, curious as to why you chose 0W-20 for the N20, I always use BMW branded 0W-40.
2013 328i xDrive N20 8AT | Bootmod3 Stage 2 OTS 93oct AGG | Bootmod3 8AT TCU flash | VRSF Street 5" HD Front-Mount Intercooler | VRSF Catless Downpipe | M Performance Exhaust | NGK L/I Spark Plugs | K&N Drop-in | Dinan 20" Wheels Wearing Michelin PS4S's | Dinan Springs and Bumpstops | F80 Style Decklid Spoiler | Debadged | F80 Style Grille | Various Interior Bits |
      09-20-2018, 07:04 AM   #15
Billfitz
Billfitz's Avatar
Newer models are rated to use 0W-20, though I wouldn't use that light a grade where the OP lives.
      09-20-2018, 07:15 AM   #16
rjdnyy224
rjdnyy224's Avatar
I see. I wasn't aware of that... But yah, I would use a thicker oil in a warmer climate like SoCal.
      09-26-2018, 09:52 AM   #17
madmortar
Drives: 2013 BMW 328i M-Sport
wtf this thread.
Anyone have a pic of where the transmission is drained?
I have changed my oil a number of times and dont recall seeing anything for the transmission
      11-02-2018, 12:47 AM   #18
dorkiedoode
Ah forgot to update you guys.
Yes, brand new Lifeguard ZF8 transmission fluid was used to refill the car. I used ISTA/D to measure the oil temp for the correct fill.
All 10 quarts of the oil were drained and refilled with new oil.. that was the easiest part!
Easy fix guys no sweat
madmortar it's under the plastic cover that the exhaust runs parallel to..
rjdnyy2241421.00
