03-22-2018, 09:02 PM | #23 |
Rep 6,037
I don't have the LSD so can't speak to how much better it improves cornering, but I have the P-Zero run flats which do pretty well even in the rain. I normally run in sport+ but in the rain I do have to use sport, but that still give me plenty of performance and the tires grip well in this mode to take corners in a confidence inspiring manner. I imagine an LSD would help with a rear drive car at the limit when the drive wheels slip, though.
Aberle74.00 |
03-22-2018, 10:34 PM | #24 | |
Rep 808
No experience with the murder rate but I hear that's quite bad as well! |
Aberle74.00 |
03-23-2018, 07:34 AM | #25 |
Rep 28
I have Quaife LSD 3.08 on my M240i, with the electronic differential disabled.
Tested it in both ways (LSD with eLSD ON and OFF) and I prefer it with eLSD OFF. Everything is smoother and the traction control only comes on when necessary. |
03-23-2018, 09:33 AM | #26 |
Rep 9,709
03-23-2018, 09:44 AM | #28 | |
Rep 73
So I'm thinking that when they wear out I´ll upgrade. |
03-23-2018, 03:53 PM | #29 |
Rep 28
03-23-2018, 09:11 PM | #30 | |
Rep 162
03-24-2018, 01:42 AM | #31 |
2JZ-GTE
3064
Rep 4,010
Nice, I am still waiting for mine to wear out.
03-24-2018, 05:32 AM | #32 |
Rep 9,709
I have been thinking about this as a viable upgrade. 3.08. But wasn't sure what electronic 'issues' it would bring up......if any. Speedo still ok? Traction control issues? Etc?
03-24-2018, 08:42 AM | #35 |
Rep 162
Yeah, that's why i had asked the question as someone in the thread mentioned they installed a Quaife LSD so not sure how that integrates with the coding question and points you raised above.
03-24-2018, 08:33 PM | #36 | |
Rep 28
After making the adjustment everything works well again. Speedo ok, DSC ok, no limp mode or power cut. Sorry for my English, but I think you understand me. |
03-29-2018, 09:20 AM | #37 | ||
Rep 603
I mostly drive the car in comfort/sport mode with DSC activated.
03-29-2018, 09:57 AM | #38 |
Cheapskate
4455
Rep 4,995
What about cruise control? On a previous car, I found that cruise control was disabled and threw a soft code because the car saw too much of a variation between engine rpm and the speedometer compared to what it would expect to see with stock gearing. It was the only thing affected and not much of a deal breaker for most, but I use it on longer trips.
Also curious if there are any issues with automatic rev matching for 6MT guys. I don't see why any traction control settings would need to be adjusted. The car doesn't intervene unless it sees slip, and the LSD isn't working anymore after wheels slip. There are a ton of people with aftermarket units that haven't reported any issues. |
03-29-2018, 05:44 PM | #40 | |
Cheapskate
4455
Rep 4,995
Traction control is looking for wheel slip and intervenes at that point. When would traction control interfere with an LSD's operation if the wheels aren't slipping? |
03-29-2018, 05:48 PM | #41 |
Rep 162
Honestly, not sure but I know the dealer had to do coding on the install. Someone mentioned above it was linked to traction control but not sure how the computer needs to adjust.
03-30-2018, 06:35 AM | #42 | |
Cheapskate
4455
Rep 4,995
Then again, people have commented on needing coding for big brake kits. That just baffles me. |
03-30-2018, 08:10 AM | #43 | |
Rep 162
kern4174454.50 |
03-30-2018, 11:31 AM | #44 | |
Cheapskate
4455
Rep 4,995
the thing about our diff is nothing's electronically controlled. with an aftermarket diff you won't have any electronics either. but maybe someone that knows more than us will stumble on the thread and explain. |
