10-31-2018, 01:25 AM | #23 | |
2020 Z4 M40i - 2022 M4C Convt
3127
Rep 5,264
Drives: 2020 Z4 M40i - 2022 M4C Convrt
Garage List 1965 COBRA (FFR rep ... [8.57]
2023 Jeep Wrangler ... [9.50] 2009 Yamaha V-Star [0.00] Cars 2-BMW, 2-FORD, ... [0.00] 2023 Ford Expeditio ... [0.00] 2020 Z4 M40i [10.00] 2022 BMW M4C [7.25] 1998 FORD Ranger 4X4 [0.00] |
The flip side of that with actual less throttle movement to reach 1/3 throttle at the engine your imprecise ankle will lose fine power control not unlike steering that is too quick being darty. Might not make a difference if the car is not putting down much power & can't slip the tires but if it is its not a good plan. Like you said earlier in dialing yours down.
Kevin
Dravit Gray, Black Leather, Moonlight Roof, Red Calipers 2022 M4C - 2020 Z4 M40i - 2023 FORD Expedition XLT Max 4X4 400BHP - 2009 V-Star - 1998 Ranger 4X4 5MT - 1965 Cobra (R) 5MT - 2023 Jeep Wrangler Sport S 6MT Last edited by BEAR-AvHistory; 10-31-2018 at 01:36 AM.. |
10-31-2018, 06:14 AM | #24 |
Rep 5,989
Anyone use a sprint booster with a manual? I find the response with the B58 is improved over 335 and also shift with the paddles and console shifter to grab lower gears or be in the gear I want. I can pick a lower gear when coasting and have power on demand even faster than with any software solution as I know what I want to do before the car does given road and traffic conditions.
10-31-2018, 06:59 AM | #25 |
Rep 3,679
It's definitely a cool product if you are in the same boat as OP, and like the front-loaded throttle mapping, but I'd rather have a more linear and accurate throttle, i.e. 20% pedal opens the throttle 20% (I know that's not how the stock mapping works, but the closer to that the better) as opposed to 20% pedal opens the throttle 50%. In the latter option you have less variability when you're deeper into the pedal. Different strokes for different folks
10-31-2018, 10:56 AM | #27 | |
Rep 245
You may disagree on theory of operation, but I drove it for 2 years like that and it helped the car drive smoother and more predictably. The B58 doesn't need it. The SB ramps the throttle more than useful on the B58, and there is no hesitation to be solved like on my 335. |
oneBIGtoe17.50 |
10-31-2018, 11:39 AM | #28 | |
Rep 11
oneBIGtoe17.50 |
10-31-2018, 12:03 PM | #29 | |
Rep 11
10-31-2018, 12:08 PM | #30 | |
Rep 11
10-31-2018, 03:12 PM | #31 | |
3127
Rep 5,264
Would also say the same with my 135is JB4 6MT. Good balance between throttle & clutch engagement. Might have a numb butt but the 440MPPSK feels the same as the others just quicker then the 435 & a little slower then the 335is. As I said in the 335is I actually dialed it back to slow the throttle input because a short quick hit of the pedal would spin the 19X30X275 Conti DW's. At the drag strip launched in 2nd gear under flappy paddle control.
Kevin
Dravit Gray, Black Leather, Moonlight Roof, Red Calipers 2022 M4C - 2020 Z4 M40i - 2023 FORD Expedition XLT Max 4X4 400BHP - 2009 V-Star - 1998 Ranger 4X4 5MT - 1965 Cobra (R) 5MT - 2023 Jeep Wrangler Sport S 6MT Last edited by BEAR-AvHistory; 10-31-2018 at 03:24 PM.. |
11-01-2018, 07:49 AM | #32 |
Rep 41
sprint booster v3
Hello All,
A lot of people in this thread are knowledgeable. Until you try the v3 on your own car your theories on why you dont need it and how it technically works etc....are just that... theories. Try the product and then you can comment from experience. It comes with a return policy and installs in 10 minutes. |
11-01-2018, 09:58 AM | #33 |
3127
Rep 5,264
Be interesting to see someone with access to a Vbox do a before & after 0-30 & 0-60 run comparison.
White Paper on SprintBooster of independent test. 10 pages. http://www.crosslake.net/~dbipes/spr...intBooster.pdf "Conclusions: The Sprint Booster is a simple amplifier that multiplies the accelerator pedal sensor signal, making the accelerator pedal more sensitive. It does not eliminate any significant delay in throttle response, nor does it greatly improve acceleration figures. It does not change the adaptive throttle control programming of electronic throttle control vehicles. It does change pedal “feel”. This change in feel is interpreted by some as improved throttle response, acceleration, and a change in adaptive throttle control programming. Considering what it actually does, it is expensive."
Kevin
Dravit Gray, Black Leather, Moonlight Roof, Red Calipers 2022 M4C - 2020 Z4 M40i - 2023 FORD Expedition XLT Max 4X4 400BHP - 2009 V-Star - 1998 Ranger 4X4 5MT - 1965 Cobra (R) 5MT - 2023 Jeep Wrangler Sport S 6MT Last edited by BEAR-AvHistory; 11-01-2018 at 10:43 AM.. |
11-01-2018, 04:15 PM | #34 | |
Rep 5,989
BEAR-AvHistory3127.00 |
11-01-2018, 07:05 PM | #36 |
Rep 190,687
We will be posting a thread about throttle response modules comparing the different options available
11-01-2018, 07:44 PM | #37 | |
3127
Rep 5,264
Sprint Booster's own web page says this: makes your car "feel" more powerful And this: Sprint Booster does not increase horsepower your car feels peppier and more powerful. Why would I spend $300 for a feel good item that does not increase power when I could spend $200 for a bottom end tuner that will actually increase power? Or $379 for one with more power then a base unit depending on which engine you have. As mentioned by WIRES your stock ECU will change the throttle map to a more aggressive one by going to Sport from Comfort.
Kevin
Dravit Gray, Black Leather, Moonlight Roof, Red Calipers 2022 M4C - 2020 Z4 M40i - 2023 FORD Expedition XLT Max 4X4 400BHP - 2009 V-Star - 1998 Ranger 4X4 5MT - 1965 Cobra (R) 5MT - 2023 Jeep Wrangler Sport S 6MT Last edited by BEAR-AvHistory; 11-01-2018 at 08:33 PM.. |
bimmer4562958.50 |
11-01-2018, 07:52 PM | #38 |
Rep 4,876
Just push the drive mode from "normal" to "sport". Does almost the same for free, and your mileage doesn't got out the window from the SB not telling the ECU that you are perpetually jabbing the throttle on the highway.
bimmer4562958.50 |
11-05-2018, 11:16 AM | #39 |
Rep 11
For the people that think the company claims its a performance enhancer it says this on SprintBoosterSales.com
"PERFORMANCE QUESTIONS Q: How much horsepower gain can I expect from Sprint Booster? A: Sprint Booster does not increase horsepower. Sprint Booster changes the throttle response in the low to mid rpm range where cars spend a majority of their time. As a result, your car FEELS peppier and more powerful." https://www.sprintboostersales.com/FAQ.cfm It's making your car feel more enjoyable to drive. That's what most people want when they spend a good amount of dollars on a car that they drive everyday. |
11-07-2018, 06:55 AM | #40 |
Rep 325
It's very interesting to see how many people claimed they don't want SB or don't think SB is a good product because SB only changes how your car feels while they don't even really know how it feels because they never had one installed on their cars...
11-07-2018, 10:09 AM | #41 | |
Rep 190,687
Users were very skeptical and 90% of the posts were negative until one of them tried it. Then it became our most popular product with 13 5-star review and 2 4-star reviews.
11-07-2018, 10:30 AM | #42 | |
Sedan Driver
389
Rep 1,018
And even Op mentions you don't need it as much in the newer F30s. Maybe it's a placebo or maybe it actually does something but for almost $300, it's not worth it to me.
Slapping on M Performance parts, ZHP, badges, and stickers does not ///M car make
ZCP | ZHP | ZTR | ZE0 | MSport | ZMP | DHP | MStickerPack | THP | MPPSK | MPPK BMW MSP Lightweight Jacket | DTM Motorsport Team Cap| BMW M Drift Cat 5 | BMW M Thermo Mug |
11-07-2018, 10:35 AM | #43 | ||
Rep 5,989
