12-12-2018, 09:24 AM | #309 | |
Rep 74
I will revert regarding the DME tamper code tomorrow. |
12-14-2018, 12:43 AM | #310 | |
Rep 1,290
Yep still getting DME tamper code too. And absolutely no burbles, but that's not a big point, not looking forward to being pulled over by police.
2017 M550i | Sophistograu
Previous cars: 2014 F30 ActiveHybrid 3 | 2012 f20 M135i |
12-14-2018, 01:34 AM | #311 |
Rep 74
The perfect solution for burbles is to get a valvetronic exhaust.. If you see the police go into the silent mode and no burbles
2013 M5, Bootmod 3 stage 2 91 octane, Evolve Catless downpipes
2013 Activehybrid 3, Pure stage 2 turbo with High flow inlet and Dv upgrade, Wagner Evo 2 comp intercooler, ER charge pipes, BMS JB4, BMS intake, BMS Meth kit with a single cm7 nozzle, Fuel it Port injection in 550cc injectors platinum kit with Ethanol analyzer, Fuel it stage 2 LPFP, ER oil cooler kit, Mach v Valvetronic exhaust, Bootmod 3 and running E20 |
12-14-2018, 03:22 PM | #312 |
Rep 488
Odd, I get lots and lots of burbles. And they can be quite loud given my exhaust setup. I think if it weren't for the hybrid motor my neighbors would have killed me by now.
2013 ActiveHybrid 3 (335ih) • N55 PWG • Meisterschaft GT catback • Wagner tuning catless DP and Stage 2 Evo Comp Intercooler • ER chargepipes • CTS intake • io2V3 O2 simulator • Pure Stage 2 turbo with high-flow inlet and DV upgrade • Fuel-It Stage 2 LPFP • JB4 ISO firmware • Fuel-It DIY PI Kit • bootmod3 •
12-16-2018, 02:22 AM | #313 | |
Rep 1,290
EDIT: we want video
Previous cars: 2014 F30 ActiveHybrid 3 | 2012 f20 M135i Last edited by Lancelot; 12-16-2018 at 02:37 AM.. |
12-16-2018, 02:25 AM | #314 | |
Rep 1,290
Still feels a bit hesitant at very slow speed sometimes (when you let the car roll forward in D mode with zero throttle) To be confirmed but it also seems to have got rid of half-throttle hesitations I had with previous version, where there would be micro-traction cuts at 3-5k rpm, though full throttle seemed fine, could have sth to do with the gearbox torque limit that was removed. That hard limp mode happened to me once with the V1 map, totally unexpectedly, and indeed you must have some place to pull over otherwise can be a saftey risk, wouldn't like this to happen in a tunnel, on a bridge, or any kind of dense traffic. I found myself flashing back to stock+online recode on the side of the road, not an easy moment.
Previous cars: 2014 F30 ActiveHybrid 3 | 2012 f20 M135i Last edited by Lancelot; 12-16-2018 at 02:36 AM.. |
12-16-2018, 02:38 AM | #315 |
Rep 1,290
It does go away when you flash back to stock and lock at least.
12-16-2018, 07:20 AM | #316 | |
Rep 20
[QUOTE=Lancelot;24120708]
I had to revert back to stock as I don't trust the car to not fail when I want to push it a bit ( 3 hard limp modes with 60-70% throttle). Also, it did not happen with the v1 map in the summer - maybe it's the cold weather now ?
2013 ActiveHybrid 3 Mineral Grey Bootmod3 Stage1 93Oct
12-17-2018, 07:57 PM | #317 |
Rep 488
Looks like the maps were updated today, gonna flash tomorrow and see what we get.
12-18-2018, 09:35 AM | #318 | |
Rep 20
The torque limit exceeded seems to be fixed, but idle RPM is all over the place, jumping up 100-200 and accelerating by itself when in gear (!) from 1200 to easily 1400-1500 rpm. Car is all jerky and driving it is a pain (gentle steering in a narrow carpark almost impossible). When I turned on the sport dials, the torque seems to be right around the 50 mark when idle.
12-18-2018, 10:26 AM | #319 | |
Rep 488
My "maximum total torque exceeded" ticket was opened 11/Apr/17 and the driving itself thing was included in that ticket and reported 12/Apr/17. All of it fixed by 17/Apr/17. I wonder who did what to bring all these issues back.
Lancelot567.50 |
12-18-2018, 04:11 PM | #320 |
Rep 488
Alright, flashed V4 took a 20 minute drive to lunch and 20 minute back. Had some minor stumbles immediately after the flash, but that's pretty normal in my experience. It went away after a minute or two of slow driving. No unintended acceleration that I could tell.
The first 20 minute drive was SOLID. Car felt great, felt like it had tons of power. The Sport gauges show me hitting 560+ ft. lb of torque and around 340HP when I'm at like 60% throttle which is were the max torque error was coming form before. Not sure if that's actually true, but it looks nasty and feels great. On the 20 minute drive back, I hit some fuel system issues. 481B01 Fuel Pump motor voltage too low. To be clear, THIS IS UNRELATED TO THE TUNE ITSELF. This is a common issue in these cars, the EKP overheats. Mine is an EKPM2 and the recommendation I am seeing is to replace it with an EKPM3 which I now get to research.
12-18-2018, 06:14 PM | #321 | ||
Rep 10,473
Are you saying this is common? |
12-18-2018, 07:53 PM | #322 | |||
Rep 488
I found a few threads on N54Tech about it (most notably this one: https://www.n54tech.com/forums/showthread.php?t=39023). It seems the upgraded LPFP pulls more current and overheats the fuel pump control module. Guess I'll find out for sure when I get back.
12-18-2018, 08:01 PM | #323 | |
Rep 10,473
https://f30.bimmerpost.com/forums/sh....php?t=1478682 I guess $30 is clearly cheaper than $900 though. You have a link to eBay device? |
12-18-2018, 08:19 PM | #324 | |
Rep 488
https://www.ebay.com/itm/14-15-BMW-F...M/183368286419
12-18-2018, 08:22 PM | #325 |
Rep 1,805
Got my stage 3 fuel pump installed and everything seems to be fixed... cars in storage for winter... I'll mess with it again in spring...
2014 F30 335i / 2014 F31 328d / 2014 F22 m235i
2019 G05 5.0 / 2012 E70 X5 50i / 2007 X5 3.0is 2011 e93 M3 / 2009 E60 M5 / 2004 E46 M3 2017 Alpina B6 22 Ram Trx / 22 M5 CS |
12-18-2018, 08:25 PM | #326 | |
Rep 488
12-18-2018, 08:27 PM | #327 | ||
Rep 1,805
Not sure about that part.. how do I find out?
12-18-2018, 08:31 PM | #328 |
Rep 488
Well, I just went out to the car and pulled off the passenger side rear bolster, and to throw a wrench in everything my module is labeled EKPM3 with part number 16147301554. Now, that PN has been superseded four times, so maybe it is just an old bad one. Welp, back to the drawing board I suppose. Still gonna try that $50 and see what we get.
12-18-2018, 08:35 PM | #329 | |
Rep 10,473
Looks like a new 16147411596 would be most logical. Actually wonder if one of the newer B58 models would work. |
12-18-2018, 08:38 PM | #330 |
Rep 488
Yeah, after looking at my module and PN, I'm gonna cancel that one and look for a 16147411596.
