12-06-2020, 09:57 PM | #1 |
Rep 14
Dinan Sport Springs
Just had the Dinan springs installed with 3/4 inch drop. I attached some pictures so others could see how it looks. I love the look!
12-07-2020, 06:56 AM | #3 |
Rep 141
Drives: 2016 BMW 340i RWD
Looks nice. Drop looks perfect
2016 BMW 340i | DINAN Lowering Springs | DINAN Stage 1 v1 Tune | DINAN Mid Pipe | DINAN CAI | DINAN Turbo Inlet Pipe | Koni Sport Dampers | BMS 12/15 mm Spacers | Active Autowerke Exhaust
12-07-2020, 12:00 PM | #6 |
Rep 14
Thanks for the feedback! My wheels are 19 inches 437 M wheels. The ride is surprisingly comfortable. I don't notice a difference between stock springs and the Dinan springs.
I purchased the road handling kit as well but my mechanic told me they weren't needed and did not install them. I am very happy with the overall ride and handling. I do have the M sports line of the 335I so that might be one reason I did not need the road handling kit and drop looking pretty low. |
12-13-2020, 12:51 PM | #8 | |
Rep 150
dthahn17.00 |
12-15-2020, 11:55 AM | #9 | ||
Rep 529
2013 F30 335i xDrive M-Sport 6MT (FBO/BM3 custom tune by HCP, 91 oct, 550i clutch, xDelete)
alohasurftoad3078.00 |
12-15-2020, 12:15 PM | #10 |
M340i
393
Rep 968
Drives: BMW M340i
My F36 is pretty rough on stock msport suspenion. I can't image what losing 3/4" would feel like. Looks good though.
12-15-2020, 01:38 PM | #11 |
Rep 882
The Dinan ride handling kit (or alternate BMW bumpstops) should be used with their lowering springs. On our cars, the bumpstops are designed to closely work with the springs to achieve the targeted suspension characteristics. Our bumpstops actively engage with the springs in normal travel - not like the old independent type that were just there to absorb an extreme bottom-out.
KrampusF304.50 |
12-16-2020, 08:46 PM | #12 | |||
Rep 150
12-17-2020, 11:30 AM | #13 | ||||
Rep 529
12-17-2020, 02:20 PM | #14 | |||||
Rep 150
"Compatible with both conventional and factory electronic shocks" And here is what it says about the Konis: "Koni struts and shocks are the industry leader for user adjustable damping for daily drivers to weekend warriors. Koni's familiar yellow color has for decades meant superior motion control and adjustability for the discerning driving enthusiast. Dinan has pre-adjusted these struts to exacting specifications for use with Dinan springs and handling kit. Struts may be externally adjusted using provided Koni knob." The way I read this is you can use the springs with your OEM struts. If you choose to upgrade to the Konis, they will adjust them to the setting they recommend for use with their springs. Of interest to me, they dont sell the rear shocks (I know you can get them elsewhere). I have read that Dinan has said they few the OEM rear shocks are sufficient even if you choose to upgrade to the Koni struts. In my case, the shocks and struts had very low miles and I went with the recommendations to just use them. I had Konis on a previous car and they were much too firm for my taste. The ride quality with the OEMs is perfect for me right now. When it's time to replace my current shocks and struts, I will make a decision on whether I want to upgrade to the Koni yellows. Alternatively, I am hoping someone has tried the red FSDs by then with Dinan lowering springs and can tell if they will work with them. |
12-17-2020, 06:10 PM | #15 | ||||||
Rep 529
12-17-2020, 06:21 PM | #16 | |||||||
Rep 150
12-21-2020, 03:00 PM | #18 |
Rep 14
It looks like some owners have had ride handling issues with just getting lowering springs without new shocks or struts.
I have stock shocks and struts and am pleasantly surprised with how comfortable the ride is as I have previously stated. I barely notice any difference between the Dinan springs and the stock springs. My mechanic mentioned that having the M sport model helps with that but he did not say anything about longer term ride handling issues. If the ride quality starts to deteriorate then I will have to look into replacing the shocks and struts. I do not know enough about these cars to understand what could be causing other owners to have ride handling issues. I strongly recommend the Dinan sport springs though!! |
Stlblues68.50 |
01-06-2021, 09:10 PM | #19 |
Rep 17
Another option is Eibach. Especially, if you have xDrive, Dinan does not drop enough, while Eibach offers two different spring options. I went with the RWD Eibach option on my xDrive F30, because it offers the most drop. I did use Dinan bump stops though.
01-09-2021, 02:46 AM | #20 |
Rep 20
Just finished mine earlier tonight... She looks a bit lower in the rear to me. But I love the improved feel of the car!! Dinan sport springs
