07-23-2020, 02:59 AM | #1 |
M Enthusiast
438
Rep 624
Drives: 2018 F80 M3 ZCP
Dorch Stage 2 HPFP + E85 expectations?
So I've been doing lots of research on this but can't seem to find an answer.
I'm planning on picking up the Dorch Stage 2 hpfp this week and want to get a full e85 tune. Currently on stock turbos but have all the supporting mods done i.e. catless dp, full exhaust, intake. (Planning to get bigger turbos down the line but not atm) What kind of whp numbers should I expect from this? Reached out to different tuners but they're not seeming to respond back so Got a few buddies telling me it should easily be over 500whp but currently coming from an mhd stage 2 map running like 390whp, I'm a bit skeptical. Any feedback would be appreciated.
2018 F80 M3 ZCP - CCB - MPE - BBS RI-D - Pure Turbos Stage 2+ - 3D Design Bumper - KW Clubsport 3 Way - Cary Jordan E85 Tuned
2021 F97 X3MC 2017 F30 340i (SOLD) 2015 F82 M4 (SOLD) |
07-23-2020, 03:04 AM | #2 | |
Rep 585
I don't think a custom tune will do much more with the stock turbo
Tesla Model 3 Performance 0 - 60mph 3.1s
M140i LCI Mineral Grey Dorch Stage 2 HPFP, CG Precision DS-1, XHP, MHD Stage 2 HPFP E30 @ E42 100 - 200 6.96s Quarter mile 10.93@127mph |
theone197360.50 s55jesus438.00 |
07-23-2020, 03:24 AM | #3 |
M Enthusiast
438
Rep 624
Hm I see. I just didn't want to go through the hassle of mixing e85 with pump gas. Seems like a headache to me to try and get real close to E30.
07-23-2020, 04:00 AM | #4 | |
Rep 585
As long as your pump E85 is consistently E80 - E85 a 50/50 mix gets you between E40 and E42. Even if the E85 pump goes down to E60 in winter and you mix 50/50 you'll still end up at minimum E30. It's been proven that 90% of the benefits of ethanol in SI DI petrol engines are realised by E40 (charge cooling and anti-knock) Increasing ethanol % further only provides marginal benefit with poorer tank range/mpg and harder cold weather starting. I think you could also safely run straight E85 with the E30 OTS tunes, stock turbo and Dorch Stage 2 HPFP if you want to.
07-23-2020, 04:39 AM | #5 |
Rep 106
Oz seems Dorch is much better than "supra" pump due to whp!
I get approx 460 in your dyno, so another 40-50 would be welcome This ethanol is like gold..
M140 Sunset Orange 2018. M719 Jet Black. Maxton sideskirts and spoiler, Ksb front splitter, RK Tuning diffuser, TPI spacers, MHD Stage 2, Xhp stage 3 , Wagner 300 cell cat, MPE silencer , Quaife LSD.
Supra pump and OTS E30, Spool ethanol analyzer (E35) https://theone1973.imgbb.com/ |
07-23-2020, 06:18 AM | #6 | |
Rep 519
2017 340i M Sport Alpine White / Coral
Dorch Stg2, CTS catless, xHP, Custom E50 Tuned by Shoup |
540iSUP703.00 |
07-24-2020, 12:11 PM | #7 | |
Rep 458
Now I'm on the fence about getting a custom tune with the stock turbo or waiting until I get a turbo upgrade. Most of Paul's customers usually get a custom E50 tune. I asked him if there was any reason to go above E50 and he said E70 would be the cut off. He states that he usually can get 2 degree more timing. As others have mentioned, running full E85 is just a convenience thing so that you dont have to measure at the pump or if you fill up at your house through jugs/drums. So currently I'm detriming if I want to do an E70 + 100% Meth custom tune or just hold off until I get a VTT GC+.
2019 M240i M Performance Edition / xDrive / ZF8 / BM3 Stg 2+ E30 / xHP Stg 3 / Dorch Stg 2 HPFP / Evolution Racewerks Catless Downpipe / MPPSK Exhaust / FTP Drop in Filter / FTP Intake Pipe / FTP Chargepipe / NGK 94201 Spark Plugs .022 / Michelin PS4S - 225/35/19 + 245/30/19
07-25-2020, 01:56 PM | #8 | |
Rep 8
How much boost would be the most out of the Gen 1 B58 stock turbo? Is not in the max with stage 2+ with BM3 or MHD?? |
07-25-2020, 11:54 PM | #9 | |
Rep 1,368
2017 M240i/ ZF8 Pure Drivetrain Solutions Stage 1 & torque converter/xHP/ Pure 800 cast/ DS2/ E40 Doug Newton tuned/ ER catless DP/ Remus axle back/ BMS intake/ FTP CP/ M Performance LSD
OzBMR574.50 |
07-26-2020, 12:09 AM | #10 | |
Rep 585
Fingers crossed for a good 60ft
07-26-2020, 02:43 PM | #11 |
Rep 9
I'm on the same boat. Currently running BM3 Stage2+ with Dorch Stage 2 pump and supporting mods (catless DP, Intake).
Reached out to a tuner to get a full E85 map, he mentioned the pump may not be enough to get the most of the stock turbo as there is an injector size limit too. On running mixes, are you guys using an ethanol content sensor? I've been looking at the fuel-it kits. The one for the F30 needs to be installed under the car which I'd really like to avoid. I'm trying to see if the Supra kit can work with the fuel line that came with the Dorch HPFP. |
540iSUP703.00 |
07-26-2020, 03:01 PM | #12 | |
Rep 458
I have the Fuel It kit on my car and its been working fine for over a year now. However, its on the pricey side and you can get an ECA for way cheaper like Spool or putting one together yourself.
kern4174445.00 |
07-27-2020, 07:48 AM | #13 |
Cheapskate
4445
Rep 4,993
https://f30.bimmerpost.com/forums/sh....php?t=1679367
I've been running full E85 for 4 months now on the TU pump. It works well, but a Dorch stage 2 will get you more midrange. My boost is limited 3k-5k to work around the pumps limits, where the Dorch Stage 2 should be able to take full advantage of all the boost you can run. |
07-28-2020, 12:27 AM | #14 | |
Rep 9
07-28-2020, 07:33 AM | #15 |
Rep 458
Port injection is only needed when you are going 700whp and above. The Dorch Stg 2 can handle full E85 on the stock turbo, so again I would like to know which tuner told you otherwise because they are wrong.
07-28-2020, 12:57 PM | #16 |
Rep 9
He said we'll make more power on E50 and the pump can support E85 but we'd have to limit power.
I'm working with Jeff Payn. He has more experience on Ecutek and Supras. Is the Supra stock turbo bigger than ours? That may explain his reasoning. |
07-28-2020, 01:01 PM | #17 |
Cheapskate
4445
Rep 4,993
The supras don't have the upgraded hpfp options we do. He may be referring to the TU pump.
01-21-2021, 06:47 PM | #18 | |
Rep 7
I'm looking at Supra TU or possibly Dorsch stg1 pump. Would either be able to do a 50/50 mix (because thats so much easier!) do you reckon? I mean i'd err on the TU side for OEM durability, but also would prefer a little headroom if that's possible. BM3 and would run a stage 2+ E30 OTS tune. Would likely only run it at test n tune events as ive previously run E15ish to clear up my BM3 91 Stg2 logs and the economy drops off a cliff when running E mix fuels.
2018 Estoril Blue M140i - BM3 Stage 2+, xHP Stage 3, ER 200 Cell Catted DP, TU HPFP, Mid Muffler gone, M3 UCA/LCA, Hot Climate mod, Silicone intake pipe, UR Strut Brace, Rear under body brace, MCA Red Coil overs /w Camber tops, Super pro rear sub frame bushes, OS Giken Superlock LSD, HEL Braided lines, DS2500 Pads, SRF Fluid, Full Maxton Body kit, Rockford 10" Powered Sub /w Tekniks loom, Cognac interior
09-29-2021, 08:09 AM | #19 |
Rep 10
Did anyone ever find an accurate answer for this? I'm tempted to get a custom E85 tune until I decide on a turbo upgrade.
2016 BMW 340i xDrive
BM3 Stage 2+ E30 VRSF Catless DP Dorch Stage 2 HPFP xHP Stage 3 |
08-24-2023, 09:30 AM | #20 | |
Rep 4
08-24-2023, 11:34 AM | #21 |
Rep 1,368
I know it's the thought that counts, but considering this thread is three years old, and OP has since sold his B58....
