12-09-2020, 10:54 PM | #1 | |
Rep 906
N47 fuel injector warranty extension
I just got a letter from BMWNA, saying they are extending the warranty on the fuel injectors to 10 years or 120K from original in-service date. Covers N47T engines installed in these cars:
2017 F30 328d Sedan produced September 2016 to June 2017 2017 F30 328d xDrive Sedan produced September 2016 to June 2017 2017 F31 328d xDrive Sports Wagon produced September 2016 to June 2017 Quote:
2017 328d xDrive Sports Wagon: Estoril Blue, Black Sensatec, M-Sport Pkg
2020 i3 Rex: Capparis White, Giga World |
12-10-2020, 09:16 AM | #2 |
Rep 1,803
Lucky!!
12-10-2020, 11:19 AM | #3 |
Rep 3,539
Looks like you got your notice a day before I did. I see I'm supposed to receive a letter from BMW warranty today in the mail.
I've had two injectors replaced under warranty thus far, but they were much earlier on. Time to run some smooth idle tests and see if we might be close to needing more injectors changed via warranty? haha.
12-10-2020, 12:06 PM | #4 |
Rep 906
How did you get them to replace it? My factory warranty expires end of month and I want to abuse it as much as I can.
12-10-2020, 03:30 PM | #6 | |
Rep 3,539
I had another one throw a CEL once last year when I was out of warranty, but it went away and I haven't seen it come close to exceeding limits again. That one was a bit strange.
12-10-2020, 11:53 PM | #7 | |
Rep 906
EGR valve open (normal) Injector 1:0.25mg/Hub Injector 2:1.00mg/Hub Injector 3:-1.75mg/Hub Injector 4:0.4mg/Hub EGR valve closed Injector 1:0.30mg/Hub Injector 2:1mg/Hub Injector 3:-2.0mg/Hub Injector 4:0.5mg/Hub If I'm reading ISTA right, it says +/- 1.2 mg at idle is normal. So injector 2 is borderline while injector 3 is out of spec? Also, any way to get ISTA to spit out a number vs. the chart?
12-11-2020, 07:29 AM | #8 |
Rep 1,803
I believe the cutoff values were +-4 or 5. You'd get a CEL if it was out of spec.
A good test to see if it's getting worse would be to put some load, such as A/C and put the car in drive while holding the brakes. So far your numbers are within spec.
12-11-2020, 12:42 PM | #9 | ||
Rep 906
12-11-2020, 02:58 PM | #10 |
Rep 3,539
The fault threshold varies based upon fuel injection rate, but is within +/-3 to 6mg/stroke (per ISTA).
In my case where it threw CELs, the smooth operating test showed everything within spec, but since I had the CEL, I used the corrections in the smooth operating test to show how it was failing. One other "gotcha" about reading ISTA is the way the plots are listed and then later where the injectors are listed aren't necessarily in the same order. On the results page it lists in firing order (1, 3, 4, 2) so you need to make sure you're not reading it as 1, 2, 3, 4.
12-11-2020, 11:50 PM | #11 | |
Rep 906
EDIT: Nevermind. I found it. Ran the test with the engine revving up to 3000rpm, min/max for each cylinder: Cylinder 1: -0.4/0.5 Cylinder 2: -1.0/0.1 Cylinder 3: -0.2/0.7 Cylinder 2: 0.0/0.5
2020 i3 Rex: Capparis White, Giga World Last edited by capt_slow; 12-12-2020 at 08:48 PM.. |
