BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > B58 Turbo Engine / Drivetrain / Exhaust Modifications > Transmission Upgrade?
      01-21-2021, 03:31 PM   #1
msk340i
Drives: 340i M sport
So my transmission died and now I have to either replace it or rebuild it. If I rebuild it can the clutch packs be upgraded? If I change it, is there a direct fit replacement that can handle more abuse? It’s a 340i so it’s a 8hp50
Thanks
      01-21-2021, 04:05 PM   #2
pwaf13
“M”ing
pwaf13's Avatar
53
Drives: W205 C63
Thanks
Damn sorry to hear that, HP70 is becoming a common and cost effective replacement, might be worth thinking about
      01-21-2021, 04:05 PM   #3
msk340i
Is itA direct fit?
      01-21-2021, 04:19 PM   #4
tallestmex
Slow Poke
tallestmex's Avatar
Drives: BMW 340i
Do you know how it died? What stg XHP tune were you running and how much power were you putting down?
There's 2 details threads in this forum on swapping over the HP70, not a full direct fit - requires some modifications/different flywheel and some recoding of the ECUs but certainly do-able.
      01-21-2021, 04:23 PM   #5
pwaf13
“M”ing
pwaf13's Avatar
53
Drives: W205 C63
Is itA direct fit?
Not really, but adds a lot of strength https://f30.bimmerpost.com/forums/sh....php?t=1785998
      01-21-2021, 04:36 PM   #6
msk340i
I think my mistake was not flashing xHP. Idk how much power it was only a stage 2 bm3.
      01-21-2021, 05:29 PM   #7
dmanb2b
Drives: G07, F97, F30, E90, E46, E30
These guys have been doing good work...it's not cheap though. Chris Miller on Facebook is contact
https://www.puredrivetrainsolutions.com/zf-8p
      01-21-2021, 05:37 PM   #8
msk340i
$5,999?!?!?!!!!?!!?!!?!!
      01-21-2021, 09:20 PM   #9
G.Newt
Drives: CT4-V Blackwing 6MT
*$6,999 with their torque converter, which you probably want.
2022 CT4-V Blackwing 6-speed
SOLD: 2016 340i xDrive 6-speed
DAW v2.5 turbo E40 | Dorch S2 | VRSF DP | MST intake | AWE catback | 335is clutch | CSF heat exchanger | RK Autowerks intake manifold | Orange M Perf Brake Kit | KW Street Comfort coilovers | GTS taillights V2
dmanb2b2124.50
      01-21-2021, 11:33 PM   #10
weehe126
Drives: 2017 340i
Check these guys out. I know it says Supra, but should be the same trans. Much more affordable
https://www.jackstransmissions.com/t...supra-services
      01-22-2021, 08:15 AM   #11
dmanb2b
Yeah...pay to play. 8HP70 is another option. The reality tho is that your stock trans should be able to handle stage 2.
      01-22-2021, 08:46 AM   #12
TheFanatic
TheFanatic's Avatar
Drives: BMW 340i
the pure drivetrain transmission costs alot but can handle a ton of hp. their stage 2 guys are regularly launching near 1000hp with no issues
dmanb2b2124.50
      01-24-2021, 07:29 AM   #13
msk340i
Does anyone know of the clutch packs from a Supra transmission (51) fits the 50?
      01-24-2021, 04:31 PM   #14
///Madgreek1
///Madgreek1's Avatar
Drives: BMW 340i
I sent an email to jacks transmissions to see if their rebuild is compatible. If it is I'm sure that will be because the clutch.packs are interchangeable. Ill update when I hear back from them.
      01-25-2021, 10:57 AM   #15
msk340i
I appreciate your help. Thank you
      01-25-2021, 11:03 AM   #16
msk340i
https://www.ebay.com/itm/Automatic-T....m46890.l49292
Is this the “upgrade”?
      01-25-2021, 11:12 AM   #17
weehe126
Drives: 2017 340i
      01-25-2021, 11:24 AM   #18
msk340i
Originally Posted by weehe126 View Post
Do you know of any of those fit my car? Thanks
https://www.ebay.com/itm/8-Speed-Aut....m46890.l49292
https://www.ebay.com/itm/8-Speed-Auo....m46890.l49292
      01-25-2021, 04:16 PM   #19
weehe126
Drives: 2017 340i
Would be better to ask the person that did the swap.
      01-25-2021, 06:19 PM   #20
Glemm1970
Glemm1970's Avatar
Russia
316
Drives: BMW M140IX.
This box will not work. She is from V8.
You need from N57. From diesel engine 3.0l. 330D, 335D, 430D, 435D, 530D, 535D. F body.
M140IX. Turbo Pure 800 Cast.
      01-25-2021, 06:21 PM   #21
Glemm1970
Glemm1970's Avatar
Russia
316
Drives: BMW M140IX.
This one fits.
      01-25-2021, 09:14 PM   #22
msk340i
Originally Posted by Glemm1970 View Post
This one fits.
Which one?
