07-26-2016, 09:16 AM | #23 | |
Rep 266
07-26-2016, 11:38 AM | #24 |
Schmollbraten
12512
Rep 1,985
Dude, I ride a 4 series with a 11/13 build, dont connect me with a 3! Nevertheless its one of the F3x series, which should have similar software.
Citizen of ///M - Town, where too much is just right Some say, that my scrotum has its own small gravity field and when Im slowing down that brake lights come on at my buttox |
07-26-2016, 01:47 PM | #25 | |
Rep 2,302
Weil, eigentlich wurde die Reifendruckkontrolle erst 03/2014 eingeführt. Is it a US-Import? Because the tpms was introduced in 03/2014. |
07-26-2016, 10:09 PM | #26 |
Schmollbraten
12512
Rep 1,985
It is and it was bought only with the tri-color spec for press condition. I dont care since when the system was final implemented as long ay it works like shown
07-30-2016, 04:06 PM | #27 |
Rep 303
Interesting thread.
I have the TPMS on my 435i. You'd think BMW would add the temperature info in iDrive and not require folks to use coding to get this information. I'll admit, I'm too nervous to try and code my car. Knowing me, I'd screw it all up - lol! |
07-31-2016, 01:54 AM | #28 | |
Rep 252
07-31-2016, 01:18 PM | #29 |
Schmollbraten
12512
Rep 1,985
I second that, the more you learn, the more you'll code
08-05-2016, 07:33 AM | #30 |
Rep 1,479
Drives: 2020 M340Xi (G20)
+1
08-05-2016, 09:32 AM | #31 | |
Rep 303
08-11-2016, 08:52 PM | #32 |
Rep 1,066
Greetings all. I hope someone can offer some insight to an issue I am having. I just recently coded my 16 428i convertible and was mostly successful. The problem I am having though is that I tried to code the car to show the temp of the tires. This car uses NBT2 and I made the changes to rdc safety to try and enable the feature but now the tires are not registering (no color just grey) and the system will not let me perform a reset in idrive because it is greyed out. This sounds similar to a previous poster but I just want to get this fixed before I screw up something else. Can someone help me?
Aria970.00 |
02-07-2017, 11:39 AM | #33 | |
Rep 353
It might have been mentioned. I am new to the F series. I setup E-sys can someone tell me what to use to code an F06 (2015 640i). Right now I do show the presure on the tires would like to add the temperature. Can you please tell me or guide me what u did Thanks RB |
02-07-2017, 11:52 AM | #34 | |
Rep 40,765
1004ron20.50 |
02-07-2017, 11:43 PM | #35 |
Schmollbraten
12512
Rep 1,985
02-11-2017, 11:42 AM | #36 |
Rep 353
Just coded and added the temperature. My first coding lol without messing anything.
Question though might have been asked and answere, I want to code other stuff like lets say showing full text messages which I think is in HU_NBT will I loose the temp or I have to recode both.....or when I read FA and SVT it will take everything coded and I just add to it |
02-11-2017, 12:15 PM | #37 | |
Rep 40,765
02-11-2017, 01:47 PM | #38 |
Rep 353
Got ya so as long as I am fdl coding I am ok. Once I do a VO then I have to recode all the customs I had to that point
05-16-2017, 07:49 AM | #39 |
Noob
Rep 13
Hi guys.
I also tried activating the pressure/temp as I was only scanning the topic and only looked for the topics. It seems I do not actually have a sensor, and it just uses the ABS sensors. And can anyone confirm please that if I do not have S2VBA I am probably using the ABS sensors? Stems look like rubber to me. Does anyone know how accurate this is? I would like to order normal tires (not the expensive RFT) and a mobility kit. I am planning to keep the only rims I got for winter, but I would like to order the tyres in the next month or so to get a better price. I would not like to order some tires, and then realize I have the sensors in the stems and can't use the mobility kit or that the tires deflate and it is not detected and then I need to sell the normal tires and order RFT Thanks. |
Aria970.00 |
05-09-2018, 05:18 AM | #41 |
Rep 3,875
I am not sure about what the latter 2 do, but I don't see anything (apart from RDC) in common about the three so not sure why you are asking for the difference
The last one looks like the generic coding whtether the system is active or not (just guessing).
05-09-2018, 07:09 AM | #42 |
Schmollbraten
12512
Rep 1,985
The first line is to activate afterwards for retrofit coding TPMS. The others dunno.
02-22-2019, 08:01 AM | #44 |
Rep 42
