01-24-2022, 02:23 PM | #23 | |
Rep 7,597
01-28-2022, 09:23 AM | #24 |
Rep 1,381
Just got word back from my handling/tuning garage that they've finished doing the work I took it in for and a few dyno pulls.
IAT's sat below 15c for the entire session and they're really happy with how clean it performed for an N55. I think even they're amazed by the 6.5" IC - ambient temp is 9c outside.
2015 435i - 401whp
Scorpion catless dp, VRSF 6.5" HD FMIC, MST V2 inlet, NGK 97506, MHD Stage 2+ 102, xHP Stage 3, M Performance Exhaust (modified for valved straight thru) |
01-28-2022, 12:41 PM | #25 | |
Rep 7,597
01-28-2022, 01:10 PM | #26 |
Rep 1,381
Just picked the car back up - graph below, power is to the hub so I'm not entirely sure what it converts for crank if anyone was wondering.
The faint graph underneath is from the previous run back in October with stock intercooler. Setup: straight pipe catless exhaust, NGK plugs, VRSF 6.5" intercooler, stock intake, MHD stage 2+ 95 octane running roughly 97/98 octane fuel (race gas concentrate).
2015 435i - 401whp
01-28-2022, 06:47 PM | #27 | |
Rep 7,597
01-28-2022, 08:29 PM | #28 | |
Rep 183
so the faint graph is with the same setup, same gas mixture, but without the IC? you gained roughly 25whp only by adding the IC? |
01-28-2022, 08:53 PM | #29 |
Rep 706
Probably the faint graph is stock everything and regular gas as he said the new setup is with vrsf intercooler and mhd tune. No way he run mhd stage 2 with stock intercooler.
01-29-2022, 07:16 AM | #30 | |
Rep 1,381
IAT’s never went above 32c on the stock IC because it’s hardly ever warm in the UK Glad I finally got one in though, worth the wait as it’s unlocked me the full potential of the map. Thinking about it I should have asked them to flick it onto the 93 map as I have it setup on multi-map. I’m intrigued to see how different the two fuel maps are Last edited by fortythirtyfive; 01-29-2022 at 01:14 PM.. |
01-29-2022, 01:50 PM | #31 |
Rep 7,597
02-02-2022, 11:50 AM | #32 |
Rep 22
I had a similar issue. Car usually was punchy and then out of nowhere i got a drivetrain malfunction message. It ended up the the charge pipe turbo side was off. Clamp was installed backwards. I reinstalled and car back to normal.
Good luck.
IG: @Matty1k
02-14-2022, 05:47 PM | #34 |
Rep 1,381
2015 435i - 401whp
