04-22-2020, 04:42 PM | #1 |
Rep 112
f30 M2 style bumper conversion
Hi all,
As the title states I have an aftermarket f30 m2 style bumper and it's at my autobody shop currently getting prepped. My guys are afraid to put the PDC sensor holes in the wrong spot understandably. The ideal way to go about this would be to bring my car in, remove my bumper, and line up the pdc sensors on the new bumper and mark it, correct? This is a longshot but has anyone seen a template possibly? I tried searching around with no luck. This is a newer bumper on the f30 market so that's probably why. I test fitted the bumper before dropping it off but did not even think about the pdc sensors being an issue like a dumba**. Too excited to get going I guess. The pdc sensor holes are not marked on the aftermarket bumper unfortunately. Thanks in advance
Follow my build on instagram! @the340iguy
04-22-2020, 06:25 PM | #2 |
Rep 3,539
If you or the shop knows a clear-bra guy they can probably print a template with the PDC hole locations of the OE bumper since they print the clear bra pattern and cut it out of bulk material.
04-23-2020, 12:37 PM | #3 |
Rep 112
thanks for the tip just worried that since this is a f30 bumper but with m2 design that none of the templates will line up right.
04-23-2020, 12:46 PM | #4 |
Rep 112
Does anyone know if there is leeway in placing the pdc sensors? I'm wondering if I can just approximate where the holes should go. Looking at some aftermarket* f30 bumpers online, the holes don't seem to be in the exact same places.
04-23-2020, 02:17 PM | #5 |
M Enthusiast
438
Rep 624
Drives: 2018 F80 M3 ZCP
This is going to be a tough one as of right now. Kies Motorsport just announced their M2 style F30 bumper but its only pre-orders as of now and not shipping out till May 20th. I pre-ordered mine already. Wish I can help but can't at least till my bumper comes in and mine will have the pre-drilled holes for PDC. However, Kies Motorsports was saying their bumper is pretty much a F30 upper and M2 lower combined which is why M2 lips will fit. Not sure where you got yours from but I'm assuming you can just use the PDC locations from the M2 competition since the regular M2 with the N55 did not have front PDC. So ultimately, if you'd like to wait a month, I will gladly help with finding your PDC locations since my bumper will come with them pre-drilled but I doubt you'd want to wait that long. So I'd say, just wing it by looking at PDC locations of the M2 competition online.
2018 F80 M3 ZCP - CCB - MPE - BBS RI-D - Pure Turbos Stage 2+ - 3D Design Bumper - KW Clubsport 3 Way - Cary Jordan E85 Tuned
2021 F97 X3MC 2017 F30 340i (SOLD) 2015 F82 M4 (SOLD) |
04-23-2020, 08:12 PM | #6 | |
Rep 112
05-14-2020, 09:11 AM | #7 | |
Rep 353
Also, i talked to kies about the fog light vents. Seems if you have an f30 with fogs, because this bumper doesn't have pre cut holes, you'll have to unplug them and code out the fog light check at startup so you wont have a code thrown. Do you have fog light? And if so, have you figured out what your doing with them for the install? |
05-14-2020, 02:53 PM | #8 | |
M Enthusiast
438
Rep 624
Not sure how I feel about that to be honest. My car came with the non-adaptive LED headlights so they're the standard version. A lot dimmer than the adaptive ones so I use my fog light pretty much everytime I drive at night as it does help with visibility. Depending on the vent design and the room I have behind the bumper, I'll try to have my body shop make a custom vent in order to incorporate the OEM fogs but not sure how it will turn out. Won't know for sure till my body shop has the bumper in hand.
05-14-2020, 03:53 PM | #9 | ||
Rep 353
Now im only concerned with fitment. The shop doing my install says it almost a guarantee there will be a fitment issue/gap with an aftermarket bumper. Dont know enough about PhaseOne to comment, so i can only hope its as close to oem as possible. |
05-14-2020, 04:02 PM | #10 | |
M Enthusiast
438
Rep 624
I know there can be fitment issues on other aftermarket bumpers but don't think we'll have any issues with this one.
MAKH 588.50 |
05-14-2020, 04:12 PM | #11 | ||
Rep 353
Didn't know the two halves were essentially OEM. |
05-16-2020, 08:48 AM | #12 |
They like my Swag...
433
Rep 3,762
Drives: 15 GSM 435i GC
Once you get the bumper off you will see how much slack you have in the sensor harnesses. I would guess there should be more than enough. I think the harnesses are a shared part number across BMW and so there is slack for that reason.
2015 435i Gran Coupe - Current 2008 AW 135i - Sold |
gfa325.50 |
05-25-2020, 12:53 PM | #14 |
Rep 112
should be done painting any day now, very excited.
To anyone who for some reason has to drill the PDC holes (you can just save yourself the burden and get a bumper with them pre-drilled) You will most likely need to order a 30 mm stepped drill bit online. My shop did not have one. Autozone did not have one. Home depot did not have one. One of those weird European car things I guess... Amazon carries them for cheap and the reviews are from people doing exactly this lol. Not sure if we can post links, but DM me if you need it. Or just google 30 mm stepped drill.
06-04-2020, 10:50 AM | #16 |
Rep 353
Bumper was painted and installed today. Unfortunately its not a spot on exact color match. Its a slight shade darker in the sun which i was told was to be expected.
Fitment will be absolutely perfect for most. Im sort of a perfectionist so the slight space between the hood and bumper wont bother most but it triggers my OCD if i stare long enough. Nothing spacers cant fix. Note: the space is not nearly as big as the one left after installing a GTS hood(I dont have a GTS hood). It looks really good! Coming from a sport line bumper, this was needed to get proper flow to my larger after-market intercooler and it definitely looks 10x more aggressive but im not sure im in love with it just yet. It'll have to grow on me for sure. May have it repainted ... I'll post pics sometime later today! |
06-04-2020, 04:48 PM | #18 |
Rep 353
A few more ...
AddictedTo///M217.00 rcaso26331.00 |
06-08-2020, 05:17 PM | #21 |
M Enthusiast
438
Rep 624
Are you having any issues with the PDC on your bumper? I'm having some issue with the location of the PDC holes on the fangs towards the outer end of the bumper on both sides.
06-08-2020, 10:36 PM | #22 | |
Rep 112
I actually could not complete my bumper project before my FBO install and custom tuning. Need to make a whole thread about that, vargas GC turbo, dorch stage 2 hpfp, vader solutions LPFP, port injection kit from EOS. It's gonna be sweeeet. But this bumper swap is the first thing I'm doing when it gets back this week or next week. I actually chose to put the holes more in the middle of the fangs because I had heard of issues of the PDC sensors going crazy from being too close to the edge of the fangs. (read it on the M2 forum from somebody retrofitting PDC sensors onto their bumper).
