BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > Tire peeling? Is this normal?
      05-31-2020, 05:22 PM   #1
mattryan
mattryan's Avatar
Drives: 2022 M240i xDrive
Was just cleaning my car today for the first time this year and I noticed that the tire looks like it's peeling a bit around the wheel? Not sure if this is normal just wondering if anyone knew and could chime in. Thanks!
Current: 2022 M240i xDrive
Previous: 2018 440i xDrive, 2012 135i
      05-31-2020, 05:48 PM   #2
fantanas
Greece
112
Drives: F33 435d
Do you have correct pressures? It looks like the rim protect is rubbing on the rim. Maybe you push it too much around the bends?
      05-31-2020, 06:20 PM   #3
mattryan
mattryan's Avatar
I checked the pressure last week so it should be good. I did do some spirited driving last week - is that what it's from? Just don't know if it's anything to be alarmed about
      05-31-2020, 06:22 PM   #4
fantanas
Greece
112
Drives: F33 435d
It is even all around?
Are these run flats?
I personally think that for go flats you need to increase the pressure a bit, but that is just me.
      05-31-2020, 06:36 PM   #5
2000Z3M
Drives: 2016 435i ZHP
do the chalk test
https://www.intercotire.com/using_ch...etermining_psi
Palantir219.00
fantanas112.00
Pauloxxi339.00
      05-31-2020, 07:05 PM   #6
Palantir
Palantir's Avatar
219
Originally Posted by 2000Z3M View Post
Wow. Learned something new and cool! Thank you!
Your life is a book and you are the author. Along the way there are fans, critics, editors etc that influence, change, refine and/or mess up your story. But at the end of the day, YOU are the writer and it is YOUR story.
      06-01-2020, 09:21 AM   #7
mattryan
mattryan's Avatar
They're staggered so the front is 35 and the rear are 38.
Non run flat - Michelin A/S 3+
      06-01-2020, 09:23 AM   #8
fantanas
Greece
112
Drives: F33 435d
Where are you based? A/a tires with all the high temp due to summer and hard driving could get something like that
Edit: I would be running the pressures a bit higher, but don't take my word for it
      06-01-2020, 09:31 AM   #9
mattryan
mattryan's Avatar
Toronto
Just wondering if it's something I need to be concerned about?
      06-01-2020, 09:39 AM   #10
COKen
COKen's Avatar
981
Drives: M Rster / Z4 M40i / X5 M50i
I have seen some peeling in that area caused by the tire install. It shouldn't happen, but if that is what caused it, I don't think it should be a problem unless the bead didn't seal completely and the tire is leaking air. You could take it back to where you purchased it or a tire shop to be sure it isn't a problem. Random answers from the web won't necessary address your issue. I will just give you ideas about various things which may have caused your problem.
2002 M Roadster, Steel Gray Metailic, Gray Nappa Leather, HT, TC Kline DA Shocks & Camber Plates, w/H&R Springs, Stromung Exhaust, SSR Type C. Looking for new home.
2022 Z4 M40i, Misano Blue Metallic, Driver Asst Pkg, Prem Pkg
2023 X5 M50i, Phytonic Blue, Black Extended Merion Leather, Driving Asst Pro Pkg, Park Asst Pkg, Exec Pkg, Climate Comfort Pkg.
