02-17-2020, 04:12 PM | #1 |
Rep 10,249
What F3x components failed after the warranty expired: please post your updates here
Dedicated thread with components failing after the warrant expiration will help the community to keep an eye on these components and visit the dealer before the expiration date.
My warranty is still active with 7 months remaining. 2017 440i GC with 27K miles. |
03-03-2020, 11:10 AM | #6 |
Rep 115
My battery was replaced at around 35k. I wasn't experiencing any issues but the dealer replaced it when I got an oil change.
IG: @tanzanitem4
03-06-2020, 09:11 AM | #7 |
Rep 387
No failures, but my warranty expired in January. First week of February I get an intermittent suspension squeak. Figures.
03-06-2020, 09:19 PM | #8 |
Rep 10,249
03-06-2020, 11:50 PM | #9 |
Rep 118
03-22-2020, 09:10 AM | #11 |
Rep 10,346
58k miles
Oil filter housing gasket (seeping but not leaking. I'm OC about this stuff) Valve cover gasket. Started to seep @53k miles. Because plug swap requires removal of components which also get removed when the VCG is replaced I held off until now. Valve cover and PCV vent tube replaced as well. Why? I'm keeping the car and don't want to crack open everything again if the PCV failed or the cover cracks.
"Drive more, worry less. "
03-22-2020, 02:34 PM | #12 |
Rep 5,457
Drives: F30
2014 328i w/ 92k miles.
- coolant thermostat (under warranty) |
04-01-2020, 01:54 AM | #13 |
Rep 1,827
Gaskets. All the gaskets. If they're not leaking now, they will. Not saying you should do this, but if you don't have a leak yet, you could try dribbling some used motor oil around the main suspect areas and try to get them to replace them for you.
2013 F30 335i RWD ZF Melbourne Red
~Remus Sport Axleback~VRSF Chargepipe~VRSF Catless Downpipe~GPlus FMIC~HR Sport Springs~Active Autowerke OBD Flash Tune Stage 2~ |
04-06-2020, 12:56 PM | #15 |
Rep 1,804
On my M235i, the valve cover gasket started seeping around 70K
On my current 435i, the charge pipe cracked at 40K. As for under warranty repairs, the 2er had the charge pipe, oil filter gasket and drive belt tensioner all replaced under warranty.
-Nick
2018 BMW 440i - M Sport, Exec Glacier Silver Metallic/Coral Red Dakota Retired: '00 323i, '06 325Ci, '09 135i, '06 Z4M Roadster, '93 525i, '76 2002, '14 X1, '14 M235i, '16 X4, '16 435i |
04-26-2020, 11:00 AM | #16 |
Rep 367
What spots may that be? OFHG and VCG? Where does the oil typically go (google wasnt that helpful)?
04-26-2020, 07:12 PM | #17 | |
Rep 1,827
04-27-2020, 11:12 AM | #18 |
BMW CCA Member
488
Rep 808
2015 435i 65k miles...
1. GPS went dead - antenna OK, head unit ok... mid-wiring from antenna connector to head unit connector was the culprit. Fix was run OEM EBAY GPS antenna mounted in dash. $15. (I'm not chasing a GPS cable through the body!) 2. ACC - automatic collision control malfunction... around town it's fine, highway it acts up. Just needs "realignment" because it gets bumped around A LOT. Dealer wants $600 to fix. (My fix, pull off bumper, nudge unit up/down as the bracket is aluminum.) 3. Low-Frequency horn died - replaced/fixed using Hella horn from Amazon, $38. Eyeballing coolant breather line... although at 65k ... it's still solid. (EDIT 24 hours later) 4. Coolant breather line, I had the part so decided to swap it now before it leaks. As soon as I went to un-install it, it snapped. Brittle as heck. Last edited by exE36M3; 05-01-2020 at 12:30 AM.. |
04-27-2020, 03:30 PM | #19 |
Rep 1,235
2013 328i sport line. Oil cooler gasket at 50400 ish. Discovered just after I bought the car and covered under my used car warranty. Outside of BMW's 50k warranty though. I added a 3rd party warranty after that for safe keeping.
2023 M2. ZB. Manual.
2024 m235i |
04-30-2020, 12:32 PM | #21 |
Rep 10,249
04-30-2020, 01:34 PM | #22 | |
Rep 118
