05-31-2021, 07:23 AM | #1079 | ||
Rep 660
Drives: 2014-320Xi / 2017-330Xi
Trouble free appears to be 2016 and beyond. Please correct me if wrong... Thanks. |
05-31-2021, 08:09 AM | #1080 |
Rep 16,082
The chain was changed as of 2/15, the tensioner as of 12/2016. The focus has been on the chain, but there's good reason to think that the tensioner is as much at fault, if not more so, as the chain.
05-31-2021, 09:48 AM | #1081 |
Rep 145
The court documents have been slow. I check ever day or two and post them as soon as they appear. Not too sure if they will reopen the original case now that the appeals case is coming to an end. We will see. My opinion is its done now and the claims will start to be processed.
05-31-2021, 11:13 AM | #1082 |
Rep 660
Good to know. That's great that I got a 2017 last year, while wife's 2014 I need to keep watching.
05-31-2021, 01:20 PM | #1083 | |
Rep 5,089
For sure BMWNA agrees that 2016 N26 is trouble free, as that model year's timing chain is covered by PZEV emission warranty(but not 2012-2015). |
Pauloxxi339.00 |
05-31-2021, 03:54 PM | #1084 |
Rep 16,082
05-31-2021, 07:45 PM | #1085 |
Rep 5,089
05-31-2021, 08:34 PM | #1086 |
Rep 388
I have a 2015 n20 with 45k my warranty through Bmw expires in 5 months. Should I try to see if my dealer will replace or check the timing chain ?
05-31-2021, 08:42 PM | #1087 | |
Rep 5,089
BMWNA then needs to check the collected evidence before authorizing the fix. |
06-01-2021, 09:38 AM | #1088 | |
Rep 97
If you get a similarly underwhelming response, and if they don't offer to do this without you asking, tell them to perform the chain elongation check procedure (it's 11 31 540, using tool 83 30 411 399). I think it's your best chance of a measurable "OK / NOT OK" parameter that would require (?) them to do the chain service at BMW's expense instead of yours. IMHO there's no way to "measure" the noise unless it's really bad AND you've heard enough of them that you think you can tell the difference. I gave up on my dealer and had a qualified indy do the job for less $$. They didn't have the elongation tool, so I don't know if mine would have passed or failed that particular test, but we did find that the chain had begun rubbing on the guide at the intake cam sprocket (photo attached), indicating the chain elongation had surpassed the ability of the tensioner to keep up, which is an "the end is near" piece of evidence in my book. |
bavarianride1509.00 hollovoid746.50 |
06-01-2021, 12:17 PM | #1089 | |
Rep 5,089
How much did ur indy charge for the job? Our local ones charge $3k-ish. That is the math I did before selling my F30 at 41.5%(phenomenal) of OTD paid 8+ years ago. I figure holding the car to 12 years(e.g.) require $5k-$6k to refresh(TC, brakes, cooling, bushings, AT service, etc, etc), plus $10k drop in resale, for a net cost of $15k to $16k. That $15k to $16k can be repurposed for depreciation of a brand new G20 330i in the first 3-4 years. |
06-01-2021, 08:53 PM | #1091 |
Rep 97
my indy cost me close to $4k, but that was with some "extras" like an X1 front diff service, VANOS bolts, accessory belt, and front thrust arms (bushings were shot). would have been closer to $3k for just the TC/oil pump drive job.
06-02-2021, 07:14 AM | #1092 |
Rep 145
There is none. It was a screenshot of someone posting on a BMW page. There is zero mention of any type of recall in all of the court documents. Besides, why would they have a recall after going through all the trouble denying wrongdoing or failure in this court case(s)...
06-02-2021, 07:20 AM | #1093 |
Rep 145
Original case Docket 176:
You do not have access to this transcript. Transcript of Zoom Status Conference held on April 28, 2021, before Magistrate Judge Cathy L. Waldor. Transcriber: King Transcription Services (973-237-6080). NOTICE REGARDING (1) REDACTION OF PERSONAL IDENTIFIERS IN TRANSCRIPTS AND (2) MOTION TO REDACT AND SEAL: The parties have seven (7) calendar days to file with the Court a Notice of Intent to Request Redaction of this Transcript to comply with Fed.R.Civ.P.5.2(a) (personal identifiers). Parties seeking to redact and seal this Transcript, or portions thereof, pursuant to L.Civ.R. 5.3(g) must e-file a Motion to Redact and Seal utilizing the event `Redact and Seal Transcript/Digital Recording`. Redaction Request to Transcription Agency due, but not filed, by 6/3/20 21. Redacted Transcript Deadline set for 6/14/2021. Release of Transcript Restriction set for 8/11/2021. (wh) |
06-02-2021, 08:23 AM | #1094 |
Rep 146
Bill - curious about what's involved in just changing the tensioner. Is it accessible with just the valve cover removed when it (inevitably) leaks?
06-02-2021, 10:23 AM | #1096 | ||
Rep 147
Thank you sjbender for keeping this thread active with latest factual info. EM3 |
06-02-2021, 11:05 AM | #1097 | |
I can haz cheezburger?
6799
Rep 3,677
Drives: 14 Sahara/08 335xi/22 Maverick
Maybe I was lucky but that luck didn’t last long. As I’ve mentioned several times here but I’ll mention it again for the new members, a month later after the repairs I got caught in a flash flood. Engine gave up the ghost. So far I’ve been fortunate with my replacement engine with no idea on the build date of my insurance installed n20. Still no symptoms/slack. |
06-02-2021, 11:11 AM | #1098 | |
Rep 5,089
I did hear BMWNA good willed repairs at $0 cost to owners that exceeded 70k miles, but it is likely your SA/tech was able to collect some evidence that BMWNA accepted(e.g. plastic snap-on tabs were already cracked with borescope pictures or something) |
06-02-2021, 10:10 PM | #1099 | |
Rep 97
The timing chain was changed for 2013 models, and then again in 3/2015. So if you've got the latest tensioner, I'd bet you also have the latest chain and guides too (though I don't recall when the guides were changed) Last edited by dave14x28; 06-02-2021 at 10:13 PM.. Reason: pointing out raised surface on new tensioner head |
06-02-2021, 10:20 PM | #1100 | |
6799
Rep 3,677
Haven’t tried to look/find the tensioner as of yet but if my current N20 has a total of about 191k miles and it has the original pre-updated chains/guides I’m putting my finger in the dike and praying. |
