04-26-2021, 06:02 PM | #1 |
Rep 1,509
car feels quicker in sport vs sport+?
According to my butt dyno, the car consistently pulls harder in sport than sport+. I have my sport configured to chassis only to stiffen the dampers and steering so essentially in sport mode the engine is in comfort mode. Running MHD stage one 93oct. Did some searching and I'm not the only one feeling it.
I know the throttle is not linear in plus mode, maybe that's contributing to it. Thoughts? |
04-26-2021, 09:09 PM | #2 | |
Rep 3,406
I'm not expert, you asked for thoughts and I have one. The torque curve on the 340 starts to drop like a rock right after 5,000 RPM while the horsepower flattens out at that same RPM. My unscientific thought is you may be feeling the drop in torque since in Sport + you are spending much more time above 5,000 RPM. |
04-26-2021, 09:35 PM | #3 |
Rep 562
Drives: 2017 BMW 330i xDrive
I think you’re both on point. The turbo’s power curve is fat and relatively low. Gives it a good around town feel. In comfort mode, the revs are kept in this fat powerband as much as possible. Sport lets it wind out a bit, but still keeps things in the curve unless you’ve been winding it out recently. Sport+ seems to assume the car will be full out any second and is very reluctant to upshift, and lets the engine (B48 anyway) wind all the way to 7000 rpms. In these ranges, unless you’re giving the throttle enough air for the turbo to fill the sails, it doesn’t feel that gutsy.
2017 330i xDrive Imperial Blue Exterior / Venetian Beige Leather with Oyster Accent Interior / Anthracite Wood Trim |
04-27-2021, 12:08 AM | #5 |
Rep 1,509
I'm aware of this, which is why I'm surprised it feels quicker
04-27-2021, 02:25 AM | #6 | |
Rep 3,876
There are a number of differences between Sport and Sport+, at least for 40i / FCI. Sport+ there is more aggressive. This is for the older generation: There was another table for the 40i/FCI, I believe in German, which I can't find right now. It was visible there that Sport+ has more aggressive throttle response in addition to the above. What I have noticed which is inconsistent with the above is that manual shifting for me feels definitely slower than DS. In any mode....
04-27-2021, 07:57 AM | #7 |
Rep 849
Drives: BMW 435i
I'm surprised you leave the throttle in comfort mode and are happy with it.
I've found the throttle response to me far better in sport mode and it really makes the car more responsive and accelerates quicker due to needing less pedal input for the same level of acceleration. I've noticed loosing 1~2 seconds on an autocross course simply because I left it in comfort and not Sport/Sport + I'd do my daily commute most days in comfort because there are no opportunities to enjoy the benefits sport/sport+ offer, but when I do go into those modes I want the car to be fully alert. Comfort is rather sleepy...like I am when I drive to work.
ChuckP4936.50 |
04-27-2021, 08:10 AM | #8 | |
Rep 562
Throw some curves and harder stabs on the pedal into it, sport/sport+ is vastly preferred...
04-27-2021, 08:13 AM | #9 |
Rep 3,876
I may be one of the few who appreciates the pros and cons of ALL available modes. And by all, I mean even EcoPro. Works perfectly fine for me when cruising on a long-haul. It doesn't hamper my driving at all, even makes it easier if I want to drive in a way which will not wake sleeping people in the car or make cat throw up... and whilst I do that anyway - why not save some fuel as well
And also - after a few hours in EcoPro - Comfort feels like a real sports car I do 80% of my driving in Comfort, 10% Eco Pro, 10% Sport / Sport+
04-27-2021, 08:29 AM | #10 | |
Rep 1,509
Speaking of which, what configuration are y'all using for sport mode, engine only, chassis only or both. |
04-27-2021, 08:38 AM | #11 | |
Rep 562
04-27-2021, 09:40 AM | #12 |
Rep 3,876
I use both as well. Tried with either disabled, did not see a use for such a configuration. Comfort works great for me. Anything above that is for sporty driving, so Sport with all settings enabled is great. I lately tend to experiment more with Sport + as well.
04-27-2021, 09:42 AM | #13 | |
Rep 4,877
If you plant the gas, same engine, same torque, same power. Now, in sport+, DSC turns off so if you are encountering situations of slight wheel spin, you won't get a throttle cut, you will get wheel spin. With BM3 S2 + xHP it's VERY noticeable on my xDrive from Sport to Sport+ during gear changes. |
mbanks211267.50 |
04-27-2021, 09:53 AM | #14 |
Rep 180
Until last weekend I used to think traction control was the only difference between Sport and Sport+ in the 340i.....boy was a wrong! My perception of the car has completely changed for the better. On the highway Sport+ drops a gear when switching from Sport and rarely needs to downshift when passing aggressively.
04-27-2021, 10:55 AM | #15 | |
Rep 4,877
joesid80.00 |
04-27-2021, 02:32 PM | #16 | ||
Rep 3,876
It is limited in EcoPro though, unless you use kick-down
04-27-2021, 03:01 PM | #17 | |
Rep 849
Drives: BMW 435i
Even though I have the 6MT, I actually like the throttle responsiveness in Sport. it isn't very linear, but I do like the fact it is more responsive and responds quicker to inputs. Comfort seems a little sluggish, even though it is perfectly acceptable for daily driving needs...most of the time. Ideally, I'd like to either have the ability to independently set the steering, throttle, and suspension all the time, or be able to set up a bunch of different pre-set profiles with different combination of settings depending on what I'm doing. Like Skyhigh mentioned, each setting has it's place, I'd just like to change up a couple configurations vs being stuck with what BMW gave us.
04-27-2021, 04:41 PM | #18 |
Rep 1,641
One other benefit of eco mode - use it when your teen driver is learning to drive. I called it "nanny mode". When my teen was learning I would take her out and we would practice. Momma had no patience so it fell on me to take her out. First time she floored my 340 and we hit the road like a bat out of hell, I knew I needed to tame the car until she had better control. Two years later we are all good. She is a good driver. I bought a used X1 for us for her to drive or as she tells her friends "Mom and Dad bought this for me"!!! . It is also good since the X1 is an x drive - so I can keep my summer tires on year round and only park it when we have the few undrivable colds days a year.
04-27-2021, 05:29 PM | #19 | |
Rep 4,877
But heh, post some trap times proving otherwise. |
04-28-2021, 12:50 AM | #20 | ||
Rep 3,876
04-28-2021, 02:01 PM | #21 |
Rep 4,877
04-28-2021, 02:07 PM | #22 |
Rep 3,876
Definitely limiting power!!
