BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > Photo, Video, Media Gallery, Journals > _das_bae_ "Betty" Sparkling Brown Metallic Build/Gallery Thread
      04-01-2021, 12:38 PM   #45
_das_bae_
_das_bae_'s Avatar
Drives: 2015 435i Coupe
Originally Posted by saga boy View Post
Your pictures are superb! What glass are you shooting with? Car is very clean man!
Thank you! The top couple pictures are shot with my lens a cinematography 25mm 1.4 and the lower pics are my buddies L glass, I believe a 24-70/105.
IG:@_das_bae_
2015 435i Sparkling Brown Metallic (B53) OEM+
https://f30.bimmerpost.com/forums/sh....php?t=1705873
      04-05-2021, 12:33 PM   #46
_das_bae_
_das_bae_'s Avatar
Morning SF Cruise
IG:@_das_bae_
      04-05-2021, 12:37 PM   #47
sgovind
Member
sgovind's Avatar
Drives: 2014 328i xdrive
Definitely "Tempting"
Great Color!!
2014 328i xdrive | Black Dakota Leather w/ DIY Blue Stitching | EB Interior trim | M Sport | Lighting | Premium | Driver Assistance | Cold Weather | LCI Tail Lights | M Performance Brakes (Blue)
_das_bae_189.00
      04-06-2021, 05:51 AM   #48
momo_
England
Drives: BMW F30 330D saphire black
Lovely build
That brown paintwork is something else. Probably of the nicest OEM paintworks.
_das_bae_189.00
      04-06-2021, 01:00 PM   #49
_das_bae_
_das_bae_'s Avatar
Great Color!!
Thank you!
Originally Posted by momo_ View Post
Lovely build
Yes it always amazes me how much the color can change under different lighting. I feel like its almost 4 colors in one!
IG:@_das_bae_
      04-11-2021, 11:19 PM   #50
_das_bae_
_das_bae_'s Avatar
My 1 of 1 Headlights
The car has recently undergone a big change I've been wanting to do since I upgraded to LCI tails... it took me about 30hrs total but I think it was worth it so I could customize all the components I wanted to while keeping the chrome non-blacked out OEM look. I'll be posting more pictures from behind the scenes of the headlight mods.
IG:@_das_bae_
      04-19-2021, 10:43 PM   #51
_das_bae_
_das_bae_'s Avatar
Headlight Build Photos
Last year in October I made some renders of upgrading the lights and wanted to try something different. Pairing the Euro LCI Blackline tails with a modified set of angel eyes. This isn't my first retrofit, but its the first in which I didn't do a blackout...meaning you have to be super careful working with the chrome otherwise it will scuff/flake off the plastics. I felt that with the car being a darker color, I wanted some contrast against the paint rather than the blacked out look. Ultimately I was able to keep the etched BMW on the eyebrows in chrome while also painting the lower half of the brow to give the headlights a little more dimension/flare. I also modified the projector shield to have a sharper cutoff and painted it black so it matches the inner dummy projector. To complete the "chrome-out" look, I swapped out the turn signal bulb with an all silver casing amber led one to eliminate the egg-yolk look in photos.
As promised here are some pictures that show just how involving the whole process is.
The low beam output with the bulb and lens swap
Before and After
IG:@_das_bae_
Sigge151.50
      04-20-2021, 05:16 AM   #52
SuperHamz
Drives: F31 328i M Sport
Wow, that is some epic work you've put in there for the headlight retrofit!
_das_bae_189.00
      04-20-2021, 11:23 AM   #53
Sigge
Sigge's Avatar
152
Drives: BMW 420d xDrive 2016
Intense! Wish I had the confident to pull something like that off. Knowing how expensive they are I would be terrified of accidentally damaging them.
I removed the lenses from a aftermarket pair of headlights on one of my older cars, so I know what a pain in the ass that is. But how many hours did this take you?
How hard would you say it is just to install the different angel eyes? Cause that looks dope and I would love to have those on mine!
Good job! 👏🏻👏🏻
_das_bae_189.00
      04-23-2021, 12:56 PM   #54
_das_bae_
_das_bae_'s Avatar
Thanks, I would say it was worth it given the price/performance of LCI LED assemblies, plus the light output at night is a massive improvement!
Good job! 👏🏻👏🏻
It's not too bad if you're patient with it! My hands were sore after getting the casings open The overall project took around 30 hours, split over a weekend...with about 10hrs dedicated to splitting the housing. It wasn't too hard to dissemble the inner components as long as you have the right tools and use gloves to not scuff the chrome. To remove the old rings requires unclipping them from each "projector" shroud as well as sliding the base of the rings out (you can see where from under the headlight housing that has the 2 LED bulbs). If you plan to use the same style rings it might require trimming the bottom of the low beam projector so that the rings can be mounted flush.
Honestly all headlight housings are similar on the inside, it's just seeing if it's a screw, glue, or clip holding the pieces in. I'd done similar retrofits on E9x platform so it was interesting seeing the revised components over the old design. I wasn't too worried about damaging them and made sure to measure/mock fit things up before committing, the main thing is being careful to separate/clean the housing of the old permaseal and reseal it correctly with thick/evenly filled fresh butyl.
IG:@_das_bae_
      05-05-2021, 12:40 AM   #55
_das_bae_
_das_bae_'s Avatar
Eclipse
IG:@_das_bae_
e90Nate155.50
      07-17-2021, 09:18 PM   #56
_das_bae_
_das_bae_'s Avatar
SF Evening Cruise
These were taken by another photographer IG:"ohkeanu"
These were taken by me
Graphic made by IG:"motorprints"
IG:@_das_bae_
Sigge151.50
