06-05-2021, 06:14 PM | #1 |
Rep 145
Drives: 2016 F30 340i
Recommendations 340i RWD slight drop
I was looking at the Bilstien B4 tourings and pairing them with H&R Sport Springs. I have a 2016 340i RWD. Just looking for to eliminate fender gap and not get a compressed vertebra disk on the raggedy roads. Anyone have and other recommendations? Thanks!
06-06-2021, 12:24 AM | #3 | |
Rep 5,393
Definitely go with Eibach springs and Koni Yellows. Replace your stock bump stops with shorter F80 bump stops. See photo. |
alohasurftoad3076.50 LRW7075.50 |
06-09-2021, 10:44 PM | #4 | |
Rep 145
johnung4528.00 |
06-22-2021, 11:43 PM | #5 |
Rep 42
You may consider me partial because I have a set for sale but I really like my Bilstein B12 kit. It provides the upgraded b8 struts/shocks that are made for lowering springs and the eibach pro springs. The bump stops that everyone always talks about are built in to this model sho you avoid having to buy then separately. Ride height is lowered approx. 1-2 inches and totally changes the boat feeling the stock suspension gives us.
06-23-2021, 07:24 AM | #7 |
Rep 1,909
I wouldn't say cheaply made, but they are indeed stiffer compared to oem bmw struts. I think they pair well with eibach springs but because they are stiffer than the oem strut, they wont lower the car as much if used with lowering springs per my experience currently using both the b4s + eibach 05-22s.
Current: 2017 F30 340i xdrive
Previous: 2008 e92 335i coupe: RB turbos, mach 116 race fuel, methanol, alot of boost. Previous: 2003 Honda Accord V6 coupe: AEM V2, zex 75 wet shot (sold) |
sspade2464.50 |
06-23-2021, 07:34 AM | #8 |
Rep 5,457
Drives: F30
If going with the B4's... you'll want to aim for the Sport model since you are lowering a bit. As said above, these are replacement shocks but I wouldnt say junky?
For a better quality damper go with the B6 or B8 depending on desired lowering. They are identical except for the actual length (B8 being slightly shorter obviously). I personally had B8 with AC Schnitzer springs and really loved the setup. Was definitely firm but not too low at all (pic in garage). This time around, I may go with the B6 and BMW M Sport springs. |
06-23-2021, 08:32 AM | #9 | |
Rep 5,393
07-04-2021, 11:08 PM | #10 |
Rep 145
So I just received my Eibachs, Koni yellows, bump stops, and since my car has 81k miles I am changing all the mounts and bolts. Hope to install everything this week, this should be fun!
alohasurftoad3076.50 johnung4528.00 |
07-05-2021, 09:55 AM | #11 |
Rep 233
If you don't mind me asking, when did you order? I ordered mine on June 20th and Im just trying to estimate when I can expect them since both the Konis and the Eibachs are on backorder...
07-09-2021, 01:58 PM | #12 |
Rep 145
I ordered them from Bimmerworld on 6/25, I received them about 5 days later I just installed them on Wednesday this week. So it took about 7 days for order to delivery.
alohasurftoad3076.50 oksymoroni249.50 |
07-10-2021, 11:27 AM | #14 | |
Rep 233
07-11-2021, 06:40 PM | #15 |
Rep 145
To me the ride quality and feel is on par with the feeling I get when I drive my wife’s 328 M Sport. I love the feel, it feels planted and I am more confident. The stance is wonderful to it looks awesome. Unfortunately the front of my car was damaged by an exploding tire on the freeway so I won’t be able to provide any pics for a week or so.
12-25-2021, 05:47 PM | #17 |
Rep 145
No I don’t have adaptive. But I will make sure to check that box next time.
