06-10-2021, 09:25 PM | #1 |
Rep 159
Chasing 2 noises in the car. Dealer guessed it was adaptive suspension. Changed both front struts, but noises still present. I am on adaptive suspension !!! I thought sounds were caused by the rack, dealer was adamant it's not the rack.
First sound is a really loud chatter that happens sometimes when turning, can't consistently recreate. https://youtube.com/shorts/vmbaKaQzD8s?feature=share The second noise is a warble sound that you have to listen for. it's somewhat faint on video, but pretty noticeable, due to its pitch, in person. https://youtube.com/shorts/n_HKx2zt_OM?feature=share "Could it even be the same noise at dif intensities ????" |
06-16-2021, 03:16 PM | #2 |
Rep 10,249
So the dealer suspected that the two front M Adaptive struts were at fault?
The price of the "guess" is at least $1500. Not trivial. Why did the dealer suspect the front struts? How many miles does your car have? |
06-16-2021, 03:18 PM | #3 |
Rep 10,249
So the dealer suspected / guessed that the two front M Adaptive struts were at fault?
06-16-2021, 08:36 PM | #4 | |
Rep 3,940
If it's not the struts and top hats, and the control arms are in good condition, I'd be inclined to look at the thrust bearing on the steering rack. |
06-16-2021, 11:40 PM | #5 | |
Rep 159
I just did both fronts myself , have also done the sway bar end links on both sides and the top mounts. Steering rack is noisy in two spots but they just refused to look at it saying it a a 3,000k part. Anyone remember how long the steering rack is covered for mileage wise Am at 98k First time I took to dealer about the noise was at about 85k and under pre owned warranty. The did fix my belt actuator at that visits . Gfs been driving the car and she doesn't notice it lolol hence the mileage gap. Hers is about to be fixed so I'll get her back soon and trynna fix this ASAP |
06-17-2021, 03:34 PM | #6 |
Rep 47
I have a similar noise coming from the front left. I'm bringing my car in next week to have some maintenance done and to have this checked out.
Keep us posted on what you find. |
06-20-2021, 07:01 AM | #7 | |
Rep 11
I got the noise short after I've replaced the lower control arms and thrust arms but I'm not sure if it's related... |
06-20-2021, 07:26 AM | #8 | ||
Rep 5,391
When replaced, control arm bolts aren't supposed to be torqued down until the car is back on the ground under full load. Wonder if it could make that noise if they had been tightened too much while in the air? |
06-21-2021, 09:27 AM | #9 | ||||||
Rep 99
06-21-2021, 09:52 AM | #10 | |||||||
Rep 5,391
06-25-2021, 09:43 PM | #11 | |||||||
Rep 159
so if It is the rack and it gets fixed for free I'd rather go that route. Plus if it is the rack an Indy may or may not have the ability of coding the new rack for you. It's the faint noises yes not the bangs. The bangs were just harsh bumps on shitty neighborhood road ! I never had my control arms done, just the struts the mounts and the sway bar end links (this was the Indys guess) The sway bar end links did move the sound. In terms that I used to be able to recreate the sound while turning into my neighborhood every time, but after the sway bar end links, the sound no longer occurs when entering the neighborhood. So if that helps/makes sense the sway bar end link replacement did alter the sounds occurrence |
06-25-2021, 11:32 PM | #12 | ||||||||
Rep 99
06-26-2021, 04:34 PM | #13 | |||||||||
Rep 159
I am no longer under warranty and won't be throwing anymore money at the noises until someone has a suggestion lol. I did end up doing springs whenever I replaced the struts mounts and bump stops , which is what those bangs were from, the slightly sportier suspension set up lol |
06-27-2021, 05:01 AM | #14 | |
Rep 3,940
06-27-2021, 11:09 AM | #15 | ||
Rep 159
Sound was harder to recreate and didn't occur at its usual roads/turns . It has now established new regular occurrences in different parts of roads / different types of turns |
06-29-2021, 09:03 PM | #16 |
Rep 1,363
I've got a front end rattle as well. I've been spending time chasing down issues with parts rattling against the splash guard, including air con hoses, missing c-clamps and screws. Endlinks are fine. It seems like plastic parts are rattling against the splash shield since when I pull down the bumper and tap on the shield, no rattle.
Maybe I'll drive around without the shield and see if the problem goes away.
07-01-2021, 06:02 PM | #17 | |
Rep 159
07-01-2021, 07:53 PM | #18 |
Rep 1,363
I found a few of the problems that have helped a lot but not 100%
1) the left brake duct rattles. It goes from the bumper to an outlet in the front wheel liner. The duct snakes around a large aluminum bracket, which it then rattles against. I stuck a large wad of two sided tape between the bracket and duct, one rattle gone 2) missing c-clips on the undertray. Replaced. Fewer rattles 3) Air con hoses sag over time and end up rattling on the splash guard. Use cable ties to pull them back up again. One hose had no bracket so I secured it with cable tie to a neighbour hose. It helps 4) plastic within the m-sport bumper rattles like hell. Hush tape + 2-sided tape have reduced rattles 5) the final and most frustrating rattle was the result of one of the 8mm screws of the splash shield rattling against plastic from the inter cooler. Back the screw out, rattle gone. Tighten it, rattle back. I put a piece of two sided tape between the screw head and c-clip and that fixed another rattle A final clunk remains. Haven’t found it’s origin but may wait until I swap struts and springs. Good luck |
07-05-2021, 02:49 AM | #19 |
Rep 7
07-05-2021, 03:09 AM | #20 |
Rep 7
07-06-2021, 08:32 AM | #21 | |
Rep 159
07-06-2021, 08:33 AM | #22 | |
Rep 159
