05-12-2021, 10:35 AM | #1 |
1296
Rep 3,533
Bootmod3 anti lag, multi-map flex fuel maps are out
yay right?
anyone else a little confused by the setup here? you can pick what maps you want? can't turn on anti lag on any map? so the are all predetermined, so you can't mix and match. I was planning on running my custom map as one. the 2+ e30 map, a stage 2h 93 and a 2h 91 map as my 4. nope.. wtf
05-12-2021, 11:00 AM | #2 |
Rep 90
I think it's great news! Further clarification is needed of course. Considering all maps are flex fuel enabled it's already a huge improvement. The way I interpret that is as follows;
Stage 1 91 ACN = The map will run like your conventional stage 1 ACN map but because it is flex fuel adding up to 30% ethanol will adjust ignition and perhaps boost control. Essentially it would be a stage 1 + Apply the same logic to the rest of the maps. I could be completely wrong of course. |
05-12-2021, 11:28 AM | #3 |
Rep 643
im not surprised. the thread over on m3/m4 S55 side had already found out you can't mix and match OTS maps. there was some chatter about it MAYBE coming in future updates.
as for antilag.. it is unclear because there is no visible option to turn it on or off, however, i am assuming that once you use a 'customrom' enabled map, then it is turned on. alternatively, you can convert one of your current maps to 'customrom' and i assume that enables antilag.
M235i rwd 6mt
05-12-2021, 01:28 PM | #4 | |
1296
Rep 3,533
05-12-2021, 03:34 PM | #5 | |
Rep 2,653
View post on imgur.com
05-12-2021, 04:34 PM | #6 | ||
1296
Rep 3,533
I was able to do it to my custom tune from caryjordan
05-12-2021, 04:41 PM | #7 |
1296
Rep 3,533
okay, converting an existing map enables antilag etc
05-13-2021, 04:16 PM | #8 | |
@_sunbish
282
Rep 611
05-13-2021, 08:43 PM | #12 | |
@_sunbish
282
Rep 611
'14 435i RWD - BM3 stage 2+ E30/bolt ons/stock turbo/full drag pack -- [10.9@125].....60 to 130 - 8.5
'16 340i RWD - BM3 stage 2+ E50/bolt ons/stock turbo/full drag pack -- [10.2@131]......60 to 130 - 7.5 |
n55david1295.50 |
