BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N20, N26, B46, B48 Turbo Engine / Drivetrain / Exhaust Modifications > Clearing Up Timing Chain Inconsistencies
European Auto Source (EAS)
      08-01-2019, 03:38 PM   #155
Linc0909
Drives: 2013 328i,
I just came across this:
https://www.bmwblog.com/2013/09/29/b...20-n26-engine/
Wonder what happened? BMW informed NHTSA of initiating a recall but I haven't read anywhere where they actually issued one... hmm
      08-01-2019, 10:49 PM   #156
Billfitz
Billfitz's Avatar
Drives: '15 328iX GT
This happened:
https://www.bmwblog.com/2014/11/22/b...assist-issues/
      09-19-2019, 10:25 PM   #157
MattyBeams
Drives: 2016 BMW 328i x drive LCI
I have a 2016 F30 328i LCI built 09/2015 - my guide is orange af. Chain looks very clean and tight. I have a feeling they didn't fix sh*t.
      09-19-2019, 11:15 PM   #158
sspade
sspade's Avatar
2014 BMW 328i  [5.00]
The color of the guide has absolutely nothing to do with it being "new" or "old" design. This has been proved by the original video of the N20 being assembled in 2012. Guides were white. All guides new and old will turn orange/brown after saturation with oil and umpteen heat cycles.
You have the revised timing chain components. Period.
BMW 328i FBO, Bootmod3 Stage 1
      09-21-2019, 04:38 PM   #159
MattyBeams
It seems like that should be the case but I've just seen nothing definite on it - that LCI should of been the first line they fixed it on though.
No issues with the car so far, just passed 70k yesterday, no leaks, smells, sounds.
Looking into a m performance exhaust, idk yet though, with that in the back of my mind I'm afraid to boost performance in any way. Exhaust seems like a safe mod though even tho it won't really boost HP.
      10-15-2019, 08:29 AM   #160
h202h
Drives: E92 N52B30 2008-> F30 N20 2012
F30 timingchain
Hi, i just read every replies. Had couple strokes and anxieties, but after all, i think that this is not bad as i would think. I still have a lot of forums to read, but overall this seems to be a rare problem. Its bad if its happens. I thank everyone of you who replied to this thread. If you have anything to add to this thread i think you should say it. I am from Finland and i have 2012 F30 N20. Last owner changed oils after 30-40tkm twice, so thats why i am here.
After this i think i will change my oils after every 10tkm.
My question is, should i change the tensioner? is that an easy diy?
AMA.
      10-15-2019, 12:54 PM   #161
Vlyss
Drives: F30 n26 328xi
Okay so I read a lot about the problems with the chain.
I noticed that the chain is sometimes not tight, this is sometimes cold or if you turn off the engine. I read that people say this is normal cam shaft turns etc ..
I have ordered a new tensioner and tested it with oil, the old one does not remain on tension like the new one. The difference is not really big but certainly present.
I also see people saying that the two upper pieces are broken, that small piece where they click into each other at the top is only practical for assembly, it is fixed everywhere with bolts so it doesn't matter.
So if you have a bad tensioner and the car starts every time with a little slack in the chain, I don't think it's good for the whole chain.
After replacing, I always have a tight chain.
I am from the Netherlands and drive a 2012-12 model year 2013 328xi n26 93000km
      10-15-2019, 10:12 PM   #162
rjdnyy224
rjdnyy224's Avatar
Drives: 2013 328i xDrive
AMA.
Not an easy DIY at all, at least not for the average weekend mechanic like most of us are. That's one of the things I would leave to the pros.
2013 328i xDrive N20 8AT | Bootmod3 Stage 2 OTS 93oct | Bootmod3 8AT TCU flash | VRSF Street 5" HD Front-Mount Intercooler | VRSF Catless Downpipe | 2.5" custom exhaust cutout | M Performance Exhaust | NGK L/I Spark Plugs | Dinan 20" Wheels Wearing Michelin PS4S's | Dinan Springs and Bumpstops | F80 Style Decklid Spoiler | Debadged | F80 Style Grille | Various Interior Bits |
      10-16-2019, 10:28 AM   #163
Linc0909
Drives: 2013 328i,
I spoke to one of the parts counter guys at the dealer recently, he's worked there for over 25 yrs and has not seen one example of a N20 coming apart due to timing chain issue. I live not 10 miles from the Duncan assembly plant where all the X models are built so I'm sure with the abundance of BMW's in the area, if there was an issue we'd see it here.
      10-16-2019, 02:24 PM   #164
BettyFkinCrocker
Drives: 2012 328i
Considering the n20 has been in circulation for about 8 years, his "25 years" has little relevance. Furthermore, proximity to a manufacturing plant has nothing to do with frequency of failure.
The question of "is it a problem" was answered long ago. Proven not only by numerous reports we see here but by the action BMW has taken to avoid a recall by issuing an extended warranty.
1/4: 12.86@105 | 2012 328i RWD N20 8AT | VRSF Street 5" HD Front-Mount Intercooler | VRSF Catless Downpipe | JordanTuned E60
      10-17-2019, 09:11 PM   #165
f30nick
Drives: F30 2012 328i 6MT
2012 F30 328i  [0.00]
In the past few weeks had a "low oil pressure" warning. Turns out the timing chain guide was damaged and began floating around in the oil pan. No wine or anything coming from the timing chain.
This occurred at 77k miles 2012 n26 6mt
Alpine White 12' F30 328i 6MT
Injen CAI | Bootmod3 Stage 2 | VRSF 5' Intercooler/Catless Downpipe | Mishimoto Catch Can | 335i M Performance Exhaust | H&R Super Sports | HRE FF01 w/Hankook Ventus Evo2 | M-Sport Retrofit
      10-18-2019, 10:09 PM   #166
sspade
sspade's Avatar
What are your plans for getting it repaired? Quotes?
What oil change intervals have you been running?
Has Auto Start/Stop been disabled?
      10-18-2019, 10:29 PM   #167
f30nick
Getting it repaired by a local indy shop known for working on European cars.
$2300 which included new revised timing chain/guides, new oil, labor ect.
Got the car CPO at 30k miles, was changing at around 10k intervals.
No start stop since my ownership.
sspade1553.50
      10-22-2019, 08:21 AM   #168
pierreye
Drives: F10 & G01
I don't think Auto Start Stop is the reason for premature wear of timing chain/guide. Myself and others that had program the Auto Start Stop off from day 1 of ownership have the problem plus I change my oil every 10000km.
      10-22-2019, 04:15 PM   #169
arsenal
Drives: S2000, Forester, 328iX Sport
Why isn't this covered under the extended warranty?
      10-22-2019, 10:39 PM   #170
f30nick
At 77k miles
Also had to get a new oil pump as there were fragments of plastic in it
      10-29-2019, 07:40 PM   #171
Linc0909
Drives: 2013 328i,
His 25 yrs is very relevant being that he has been with BMW a long time and has experience dealing directly with any issues that may be out here
Being in close proximity is very much to be considered, BMW offers special lease rates for ALL their employees and that being said there is a magnitude of BMWs in this area. So the large amount of the vehicles being in this area and this particular dealer being the ONLY dealer within 5 counties shows that this dealer would see a significant amount of cars with any 'common' issue. This wouldn't add to the frequency but the fact that if there was a problem then with the abundance of vehicles, more so than other market places, they would see an issue more so than a rural community if there was one.
The Duncan plant employs over 11,000 people, I understand that not every employee owns a BMW but even a decent percentage and the fact that that special lease rate is extended to family would build on the amount of purchases more so than a market without the plant.
It's the same for any manufacturer.
      10-30-2019, 05:30 AM   #172
MilanF30
Drives: BMW F30 328i
So what are you saying? There is no issue? Have you considered that he maybe lying
I mean, he works at dealership... why would you believe him, especially with such a claim?
      10-30-2019, 07:01 AM   #173
BettyFkinCrocker
Drives: 2012 328i
Wrong. 25 years has zero relevance in the context of a conversation regarding an engine that has been around for 8. Hypothetically, 8 years of his experience is relevant...and that's assuming he isn't just an oil changer etc. In the context of the data we have here and elsewhere, his 8 years becomes even less relevant.
No. Not only is the information being filtered through you're perspective (which has historically been inaccurate at best), it is dissolved when looking at the data from all other sources. Your small region (assuming your input is accurate at all) still does not represent a real statistic.
As with 99.99% of this guys posts, it can be ignored. He speaks as if he is the head engineer at BMW because he worked on his neighbors lawn mower once. Look through his post history, it's pretty comical.
rjdnyy2241548.00
      10-30-2019, 11:02 AM   #174
Linc0909
Drives: 2013 328i,
No I speak with over 16 yrs of working experience IN the automotive field. I am a certified Engine Builder, I hold a certification from Mid Florida Technical Institute for Engine assembly and performance, I am also ASE certified in engine performance and repair (among other certifications) Unlike YOU who barely has enough knowledge or dexterity to start your neighbors lawn mower, respectively go fuck your self 😁🖕🏼
      10-31-2019, 06:43 AM   #175
BettyFkinCrocker
Drives: 2012 328i
AKA, worked on your neighbors lawn mower. Let's even assume everything you say is 100% true, it only serves to discredit the validity and legitimacy of those "certifications" due to the willful ignorance and misinformation you spew on this forum.
Unlike YOU who barely has enough knowledge or dexterity to start your neighbors lawn mower, respectively go fuck your self ������
And every line you type only proves my points further. Zero relevance or substance to your claims followed by a toddler like reaction. In an effort to maintain the subject at hand and not allow you to derail, our bullets so far are -
Timing chain/guide failure IS a verified issue. No debate considering BMW has confirmed this themselves.
  • Chicken or egg - whether the chain stretching or guides failing are the root cause is yet to be 100% determined
  • Slack in the chain doesn't really indicate anything
  • Cost for a shop to replace is pretty significant, roughly $2000-$3000 usd.
  • Some have distinct symptoms before failure, some see/hear nothing at all
  • Lincs anecdotal inaccurate misinformed opinions can be ignored
I think I've covered most if not all the important points...
rjdnyy2241548.00
      10-31-2019, 09:13 AM   #176
MilanF30
Haha you definitely did cover everything, even Linc0909
