07-06-2023, 07:24 PM | #1 |
Rep 32
Wgdc high and stumped…
So I’m tuning my car and my wgdc is very high for this big turbo it’s off expecially when you compare it to another log from someone else running the exact same turbo. I pressure tested to 40psi (boost leak) all seems good and I don’t know what to do next could my wastegste not be calibrated properly even though my car isn’t throwing any codes. Reason I say that is mas flow is similar but my wgdc is higher ???
I dunno what the heck is going on my log : https://bootmod3.net/log?id=649f8336ae729bae22aa5e53 Someone else running e30 https://bootmod3.net/log?id=643b41eeae729b6e18f92d5d |
07-06-2023, 07:27 PM | #2 |
Rep 779
Recently, there has been a rash of bad exhaust housings being used for hybrid turbos. easiest check...
Remove the downpipe, try and wiggle the wastegate flap. If it moves around on the shaft, it's toast. New turbo required. |
07-07-2023, 12:10 AM | #3 |
Rep 32
I want to check with ista that the shop who installed this turbo did it right first. My car isn’t throwing codes which makes me think it’s done right but I dunno have to test to make sure.
07-07-2023, 11:41 AM | #4 | |
Rep 7,622
07-09-2023, 09:08 PM | #5 |
Rep 32
07-10-2023, 04:17 PM | #6 |
Rep 7,622
07-11-2023, 09:10 PM | #7 |
Rep 32
Cary jordan is tuning my car. But i will compare to confirm. OTS stage 2H made my car run horrible. The stage 2+ made it run good with my upgraded turbo...
07-12-2023, 08:11 AM | #8 | |
Rep 4,174
Mods: Yes.
VGSON220.50 |
07-12-2023, 10:10 AM | #9 |
Rep 7,622
Horrible as is not as fast or horrible as in there was actually a problem? The 2H map wont be as powerful as the 2+ map. And in theory a custom tune should be more power/"better" but that is not always the case.
07-13-2023, 01:44 AM | #10 |
Rep 315
See you're running the cts big boss correct? Like Ray pointed out-What is your exhaust and intake system like? Those can significantly effect wgdc as well. Need zero restriction on either end. 200 cell catted downpipe at a minimum. Catless if possible.
You're WGDC is a little high, but not that bad. The turbo hits close to target then starts to open. Which is showing the boost taper Cary and others put into the tune. |
07-13-2023, 09:36 PM | #11 | |
Rep 32
Im away at work right now. will be home soon will test. Another guy told me to test with downpipe off because that was his problem, and take a log in 5th gear to make sure boost is flat. He definatly knows what hes talking about so i hope hes right hahaha.... |
07-13-2023, 09:38 PM | #12 |
Rep 32
07-13-2023, 09:39 PM | #13 |
Rep 32
Horrible as in it ran like shit lol.......But the custom tune ran the best, more throttle response just all around way way better..
07-14-2023, 06:26 AM | #14 | |
Rep 315
07-14-2023, 07:57 AM | #15 | |
Rep 32
So when I get home Wednesday I’m going to check and make sure. My car isn’t throwing any codes so we’ll see, but Cary says it night be on the high end of the tolerance. |
07-14-2023, 02:46 PM | #16 | |
Rep 7,622
If your car didnt run right on the OTS map you might have another problem... the OTS map should run fine. |
07-14-2023, 09:49 PM | #17 | |
Rep 32
So Running no downpipe eliminates the idea of a restriction as that was his issue. He had the same symptoms as me. May sound stupid but always good to eliminate possible problems while trouble shooting so ill just check to see to make sure its not the problem stupid or not...... |
07-16-2023, 03:35 PM | #18 | |
Rep 7,622
No DP = no O2 sensors and you blasting exhaust out of the turbo right toward the firewall lol? But sure, go right ahead |
07-17-2023, 12:12 AM | #19 |
1297
Rep 3,536
Stock inlet will kill 30hp or more...
This thread is hilarious btw
2017 m240i xDrive 10.67@132.32mph w/bm3
07-17-2023, 08:09 AM | #20 |
Rep 32
07-17-2023, 08:17 AM | #22 |
1297
Rep 3,536
