BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Suspension | Chassis | Brakes > Anti-roll (Sway) Bars Options study
      02-22-2019, 05:40 PM   #89
Insane435
Insane435's Avatar
Drives: 435ix M Sport EWG
Originally Posted by sspade View Post
Is it really a thousand dollar job to swap a rear bar on the F30 ?
Ive had an M240 rear bar in my garage for almost a year. Keep getting quoted stupid numbers to install so it keeps collecting dust.
It will be going on soon enough, just cant justify that money right now... especially not when Im in dire need of a Flash Tune
So it is impossible to get the rear bar out by just removing sway bar links and pulling it out the driver side?
2014 EBII 435ix - Armytrix Catback, Evolution Racewerks Downpipe - Chargepipe - Intercooler, Bootmod3, NGK 97506's, AFE Dry Filter, KW V1, Forgestar F14 19s, Potenza S-04's, M Performance Brakes, M Power Pads
2011 BSM 328ix
IG: @f32_rmacher
      02-22-2019, 07:46 PM   #90
sspade
sspade's Avatar
2014 BMW 328i  [5.00]
Yes. Impossible.
Trust me... equally surprised and frankly pissed.
Rear cradle must be lowered at least a few inches. Does not have to be completely removed... lines disconnected etc. Just lowered.
I have the 15mm bar in my garage. I just cant drop a grand on labor to have it installed!
Dealer actually quoted $9XX the first time and then $1,1XX this past time I asked.
It pays 5.5 hrs if I remember correctly. Im sure it can be done in 3 by the right guy with the right tools.
BMW 328i FBO, Bootmod3 Stage 1
      02-23-2019, 06:33 AM   #91
Littlebear
Major Major
Littlebear's Avatar
Drives: 2017 330i
Yes. Impossible.
$550. for the rear bar install here in Brklyn. Look around, someone might want your money!
Murf
sspade1513.00
      02-23-2019, 10:08 AM   #92
Insane435
Insane435's Avatar
Yes. Impossible.
The reality should be 3 hours. Removing end links and axle back exhaust plus setup time should be like 30 mins. Then lowering cradle would be another 30-60min. Remove sway bar and install new one would be 30 ish i bet. Then to reinstall stuff 60mins seems fair.
sspade1513.00
      02-23-2019, 05:50 PM   #93
sspade
sspade's Avatar
Yes. Impossible.
I think you're damn near spot on....
Id love to find an honest indy who'd like to put $100 an hour into his pocket.
I dont believe that's wishful think or asking too much either.
      09-13-2019, 11:34 AM   #94
dulantha
Drives: Bmw F30 335i
Originally Posted by Lancelot View Post
Same here, I got the M135i bars on now, and very happy with the result; good compromise between firm and compliant.
By the way my H&R bars are for sale
(shipping to the EU - ridiculous shipping costs elsewhere)
Hi, I would like to get your opinion for sway bars. I have a 2012 bmw 335i RWD. So far I have H&R sport springs, B8 Bilstein shocks and M performance LSD. My car still have body roll when takes sharp turns.
I already ordered a 15mm 235i rear sway bar. What do you recommend for the front sway bar? Im thinking about H&R 28mm or m sport 25/22.2? Do you think there will be significant different between my 25/21.2 vs m sport 25/22.2?
Or if i go with 28mm h&r will it make more under steering? What are the setup you are using now?
      09-17-2019, 03:32 PM   #95
BMW DIY Guy
Drives: 2014 435i
2014 BMW 435i  [0.00]
Definitely can add KC Design to the list as well, and I am now running their front and rear bars.
Check out my BMW DIY Channel on YouTube! F32, F80, E39, E46, E53, and E83 projects from Active Autowerke, TuningTechFS, Kies Motorsports, AvinUSA, Karbonius Composites and more!
** YouTube BMW DIY Guy ** ** Facebook BMW DIY Guy **
'Furiosa' F32 Build Thread
      10-28-2019, 10:59 AM   #96
pkiledj
Drives: '15 335i 6MT xDrive M-Adaptive
I have a noob question: I am about to order the 15mm bmw rear sway bar. I looked at real oem and it shows 1 rubber bushing in the middle of the bar. Is this right? Aside from the bar, the only other piece we need is only 1 rubber bushing? How about the bracket that holds the bushing in place, is that the same size as the 12mm rear bar?
This is going on a 335ix, Dinan springs/shockware.
      10-28-2019, 01:17 PM   #97
FaRKle!
Drives: '17 328d Sport Wagon
Each bar needs two bushings, one for each bracket. You can reuse the original brackets.
sspade1513.00
      10-29-2019, 08:45 AM   #98
floridaorange
floridaorange's Avatar
Drives: 2013 bmw 320i xdrive
I had a shop install a rear sway bar on my xdrive at $100/hour but they discovered it didn't fit when it came time to reconnect the subframe. Super embarrassing seeing as how they were going out of their way for me, but the catalog had marked it wrong - it was by Megan racing. After taking to them they discovered they don't make a rear sway for an xdrive, even though they clearly advertised one. They refunded and I sold the bar to a rwd owner.
these look sick
https://carbahnautoworks.com/product...435i-440i-rwd/
Stage 2 BM3
      12-02-2019, 11:22 PM   #99
52172
52172's Avatar
Drives: 2015 Bronze Metallic 335i
Anyone running superflex swaybar bushings and see an improvement?
2015 335i 6sp manual with MPK and sport pack
GPlus intercooler and CP. Stage 1. CG precision dp. Staggered 19?s. 275/35/19, 245/40/19 ps4s.
      12-03-2019, 12:01 AM   #100
pkiledj
I just got the 15mm bmw bar along with the stock bmw 15mm bushings. When I realized how squishy they are I started looking for poly bushings but I'm not willing to pay like $55 for the poly. I read some posts about poly vs rubber and from what I can gather the difference is minimal. This is my daily that's never tracked. I don't even drive hard.
By the way, can someone confirm the 15mm BMW bar works on an f30 335 xdrive with adaptive?
