09-28-2021, 10:20 PM | #45 |
Rep 9
Hello steve@codemybimmer
Can you help me ? If you can could you send me a mail with instruction on how to be able to activate the map again that would be fantastic. Thank you so much !! |
09-29-2021, 04:04 AM | #46 |
Rep 1,980
Drives: 2020 G20 320i M Sport
PM'd
Vehicle Diagnostics | CarPlay Solutions | Retrofit & Repair Consulting/Programming steve.ma@cmbsolutionsltd.com | www.codemybimmer.ca Online Store | Remote Coding Package| ID6 Retrofit for almost all F Chassis BMWs |
11-22-2021, 11:32 AM | #47 |
Rep 4
Hi steve@codemybimmer
I also have the navigation greyed out. I would really appreciate if you could pm me and help me activate the map. Thanks in advance! |
12-28-2021, 08:55 AM | #49 |
Rep 68
12-29-2021, 10:10 PM | #50 |
Rep 1,980
PM'd.
12-29-2021, 10:11 PM | #51 | |
Rep 1,980
The donor vehicle's FSC codes will need to be wiped and replaced with the ones that were issued to your VIN at the time of manufacture. We can help with that if needed.
09-04-2022, 08:43 AM | #53 | |
Rep 3
Thanks a lot! |
09-06-2022, 09:37 PM | #55 | |
Rep 1,980
If you replace the screen however, the head unit will still need to be coded in order for it to work.
09-07-2022, 04:12 AM | #56 |
Rep 14
Ah brilliant, was getting confused. So much informs to consider with Themis screen/CarPlay stuff. Thanks!
09-07-2022, 05:16 AM | #57 |
Rep 11
Dear All,
I got a problem with my HU and maybe someone can help me out? I've used Feature Installer in the Past for Carplay activation. Now BMW has swapped my HU since it had an HW issue and did reboot very often. Before I brought my F87 to BMW I have restored the factory FSC with Feature Installer. BMW messed something up because the HU is new now but they can't get the Navigation to work. They have installed the FSC repair Pack but can't install the Navigation FSC. Some expert from Munich should get it done, but most probably my DME would be reprogrammed also and i refused that because it would remove my tuning. So i thought i just use Feature Installer again and get Navigation working again. But Feature Installer says the Code has been used with a different Vehicle before and stops. I guess its because a different SN# of the swapped HU? I contacted the one I bought the activation from (bimmerdoc), but he does not answer. Can anyone here help me out? Thanks! |
09-07-2022, 10:38 AM | #58 | |
Rep 1,980
09-07-2022, 10:40 AM | #59 | |
Rep 1,980
11-02-2022, 09:12 AM | #60 |
Rep 3
I've got the same problem as other guys, the navi is greyed out, probably the head unit was replaced before me, can you pm me with solution and how to sort it out everything, many thanks for that |
11-09-2022, 10:51 AM | #61 |
Rep 1,980
PM sent.
01-05-2023, 06:52 AM | #62 |
Rep 6
04-25-2023, 12:54 AM | #63 | |
Rep 4
05-26-2023, 09:48 PM | #64 |
Rep 9
I’m having the same issue as everyone else, although mine is a CIC from 2010. I was wondering if you’d be able to help restore my Nav. I bought this car a few months back from a BMW dealer but the car came like this and a unknowing salesman told me all I needed was a new nav disc. Little did I know that this iDrive doesn’t have nav disks anymore. Last 7 of vin are: P124214. I kindly ask that you email me at oscarhiller67@outlook.com as I don’t have PM privileges yet on here. Many thanks in advance. |
