10-24-2017, 05:02 AM | #1 |
Rep 1,235
Creaking when car has warmed up
Hi all,
Wondering if anyone else has experienced this with their 340i or 440i. So basically I've been having this creaking noise which only happens when the car is hot and being driven for 30 minutes plus. The noise is like a mettalic creak and you can hear it on uneven roads or when going over humps. It sounds like a suspension bush related noise but it isn't. It seems to come from the Right side of the car (UK drivers side) and it comes when the car is hot over uneven roads. This creaking is also heard when the car is idle and you shift from Park to Drive or Drive to Reverse or Reverse to Drive - inline with when the load changes. You can also hear it once, when the engine turns off or starts. For this reason I have ruled out it being suspension or bushes related. The dealer and I have both checked the trims and seals and its not from there. You can hear it inside the cabin but its not audible from outside (might be drowned out my engine noise). We have driven with all the doors open and it is not a door creak. It still sounds from inside the car. It sounds like its coming from the footwell, the door sill and the b pillar. All plastics and fixtures have been checked by the dealer. Anyone had this and can suggest anything else this might be. The car is quite new so both dealer and I are reluctant to remove/disturb factory fitted parts where possible. |
10-24-2017, 05:09 AM | #2 | |
Rep 369
Brand new vehicles are disrupted at port all the time They can simply drive the vehicle onto a drive on rack and try to replicate the noise by jouncing the vehicle (by hand) and using chassis ears. No parts will be disrupted |
10-24-2017, 06:52 AM | #3 | |
Rep 1,235
It is going back in but I've been told to monitor it again. I'm suspecting it may be a engine mount maybe heating up and softening up and resonating in cabin. Could that happen? Its coming from the same side where the exhaust manifold and CAT is but again, can't hear it when the engine cools down. |
10-24-2017, 08:38 AM | #4 | |
Rep 369
eluded3071.50 |
10-24-2017, 10:57 AM | #5 | |
Rep 1,235
10-24-2017, 11:17 AM | #6 | |
Rep 369
They might feel that it’s not a safety related issue so they let it go, or can’t verify it. Try and record it if possible or go to the dealer when it occurs. So they can verify the complaint |
10-24-2017, 11:39 AM | #7 |
Ridin' thru Atlanna
26
Rep 64
Drives: 2017 340i M Sport Dinan S1
Sometimes when I enter my garage, I give the car a quick rev up to about 2500 RPM (in Park) just to hear the glorious exhaust sound and subsequent burbles. I often hear a small creak right after I do that ... I wonder if we are experiencing the same thing? If you determine what it is, I'd love to know. So far it hasn't bothered me enough to pursue a fix.
Current: 2017 F30 340i Mineral Grey/Black Dakota - 8-sp AT - M Sport - Track Handling - Driver's Assistance - Technology - Adaptive M Suspension - Dinan ECU Flash - Dinan FreeFlow Exhaust
Past: 2007 E92 328i Space Grey/Black Leather - Sport - 6-sp Manual 2004 E46 325ci Grey/Grey Leather - Sport - 5-sp Manual |
10-26-2017, 01:21 PM | #8 |
Rep 79
Wow, I have actually the exact same problem. Were you able find or even fix the problem? It is definately coming from the outside of the car. However, I cant hear it when standing beside the car and some one else driving is driving it and reproducing the noise.
I thought it could be the suspension or engine holder. It starts at barely 120 degrees celcius. Below this temerature the noise is not there. |
10-27-2017, 03:22 AM | #9 | |
Rep 1,235
11-15-2017, 01:06 PM | #11 |
Rep 79
So... I have to make this public.
My car was at the dealer and they could reproduce the rattling noise from below when the car is warm. They said it is with 99% the cat. However, they wont change it, because it seems normal for a cat to make such annoying noises when the engine is warm... just below 120°C oil temp is a usual warm engine. So for everyone out there: that is premium service and a premium car! Besides all the interior rattling I had (center trim, steering column, dash, glove box, 3rd break light, center console around gear shift, center arm rest and passenger seat, squeaking breaks) this is so embarrassing for BMW. I cannot imagine that the quality of the other premium brands is so low as it is for BMW. |
11-16-2017, 11:19 PM | #12 | |
Save the manuals!
6035
Rep 6,754
The BMW we've all come to love and respect died in 2012/2013.
'16 M3 | '23 718 Spyder Past: E92 M3, F87 M2, E39 M5, etc |
B58 parts491.50 |
11-28-2017, 01:23 PM | #13 |
Rep 1,235
To update on my situation - the noise was indeed the catalytic convertor. Since the replacement, it has indeed been quiet *touch wood*
I do however still get a noise when changing from Park to Drive (only when the car has been running for a good while and upto temperature) however it is soo faint (sounds like 3 clicks) that I'm thinking it is to some degree within tolerance (dare I say). |
12-09-2017, 09:56 AM | #15 |
Rep 4,674
03-16-2018, 12:41 AM | #17 |
Rep 4
Hi bmwak and eraxy
bmwak - 5 mths since you had the CAT replaced. Is it still nice and quiet? eraxy - did you ever get it solved? My 428GCi will be 3 years old in May and so far two dealers have been unable to diagnose or fix the exact same problem which has been happening since the car was 6 months old. It's booked for service next week at a new dealer where I will show them the problem, as well as this thread! The trouble I found with these genuine BMW dealers is they don't want to spend the time or effort diagnosing. For example, I've explained the sound only starts once the engine is above 120c, but they take it for a road test after its been sitting idle for a few hours (i.e. cold engine), say they can't hear anything, and think they've fixed it! Keen to hear your updates Many thanks engelm |
04-04-2018, 03:06 AM | #18 |
Rep 4
Problem finally fixed. Turns out it was the engine mounts - both ended up being replaced under warranty. They told me they were able to diagnose the sounds using Chassis Ears while driving the car under warm engine conditions.
Hopefully this helps someone else in the future. |
kern4174464.00 fuzzyboat92394.50 |
04-10-2018, 02:22 AM | #20 |
Rep 79
Hello, they did change one of the engine mounts 2 month ago. However, the noise did start coming from the left side now.
Going to the dealer today to let change the left engine mount as well. This car is driving me nuts.... |
04-16-2018, 07:35 AM | #21 |
Rep 4
Good luck. I must say, once it is fixed, the driving experience is so much less stressful, not waiting to hear creaks and groans all the time. Much more enjoyable...
