BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N55 Turbo Engine / Drivetrain / Exhaust Modifications > Oil filter housing gasket
      09-01-2019, 04:40 PM   #1
oma3710
oma3710's Avatar
83
Drives: 435i vert
I noticed oil on my garage floor. I saw oil on my oil filter housing so cleaned it. Turned the car on and I heard an air sound. The oil was back and the bottom of my engine was full of it.
Bootmod3 E30 & transmission tune//XDI-35//3.5 T-map sensor//VRSF HD FMIC//VRSF Chargepipe//VRSF Catless Downpipe//CTS Intake//FTP boost pipe//20" TSW Rotary Forged Wheels//BMS Tips//Dual Slat Kidney Grills//M4 Mirror Caps//M4 spoiler//M-Tech E style lip//M-Tech diffuser//GFB DV+//Eibach Pro Kit//Resonator delete//
      09-01-2019, 05:31 PM   #2
jcordier
jcordier's Avatar
Drives: 2013 black F30 N55
Try tightening the oil filter down to 18.4 lbs of tq. That seems like a lot of oil for it to be the gasket. Especially if you cleaned it up and that happened instantly. If that doesn't work. Then replace the ofhg and oil cooler gasket at the same time. Good luck
J. D. Cordier
      09-02-2019, 10:29 AM   #3
F32Fleet
F32Fleet's Avatar
Drives: 2015 435i
Wow!
Looks like catastrophic failure of the gasket to the oil cooler.
"Drive more, worry less. "
435i, MPPK, MPE, M-Sport Line
      09-02-2019, 10:45 AM   #4
oma3710
oma3710's Avatar
83
Drives: 435i vert
I know the gasket is like $30-$40. How much do you guys think for labor?
      09-02-2019, 11:20 AM   #5
Polo08816
Drives: 2014 335i M Sport
The labor will require removal of the intake manifold.
      09-02-2019, 11:49 AM   #6
Kefka
Mexico
24
Drives: Z4 35i MSport,435i F32 MSport
also a new O-ring...
      09-02-2019, 02:28 PM   #7
jh_f30
jh_f30's Avatar
810
From a dealer, I'd expect it to be in the range of $1000-1200 (based on my recollection of the quote I got a while back). How many miles on the car?
Also, if the oil cooler gasket has also failed, you might need a coolant flush as well. Check your coolant expansion tank to see if there's any oil/sludge floating in there.
~Remus Sport Axleback~VRSF Chargepipe~VRSF Catless Downpipe~HR Sport Springs~CF Rear Lip Spoiler~Active Autowerke OBD Flash Tune Stage 2~
      09-03-2019, 04:25 AM   #8
mihail.b
Drives: 335i F30
If you're getting the oil filter housing gasket done, do the oil cooler one at the same time.
      09-03-2019, 08:13 AM   #9
Polo08816
By oil cooler one, you're referring to both gaskets, right?
      09-03-2019, 08:35 AM   #10
mihail.b
Drives: 335i F30
Yep. Do both gaskets.
- between oil filter housing and engine
- between oil filter housing and oil cooler
You'll have the oil filter housing out anyway, so will be quick and easy to do the oil cooler gasket while you're there.
Polo088161134.00
      09-03-2019, 09:31 AM   #11
Alpine_F30
Alpine_F30's Avatar
Drives: 2015 335i
Curious to see if this ends up being the oil cooler gasket or just the oil filter cap not tightened down/installed correctly...seems like too much oil for a leaky gasket.
That oil buildup is definitely NOT just your OFHG leaking though, although it probably needs replacing too, ya know, bc BMW.
      09-03-2019, 09:44 AM   #12
oma3710
oma3710's Avatar
83
Drives: 435i vert
Dropped car off this morning. Hopefully will know something soon. If it's the oil filter housing gasket they told me they would change the oil cooler gasket as well for $300. Plus they would do an oil change for $70. Total $370.
      09-03-2019, 10:37 AM   #13
Kefka
Mexico
24
Agree with you...
by the way, How many miles/km does your car have ,oma3710?
      09-03-2019, 10:44 AM   #14
XxThe_RemedyXx
Greece
587
Drives: 2014 335i XDrive
Did this job in about 3 hours. OEM gaskets were like $50. Easy peasey job and learned a lot.
'14 335 xDrive EWG FBO - VRSF Chargepipe - VRSF Catless Downpipe - AA Intercooler - MPE - BM3 Custom Tune by Cary Jordan - R1 Concepts Front/Rear Geomet Cross Drilled and Slotted Rotors - xHP Stage 3 8AT
BurrNinja184.00
ali820213.50
      09-03-2019, 10:45 AM   #15
oma3710
oma3710's Avatar
83
Drives: 435i vert
Agree with you...
53k miles
      09-03-2019, 11:23 AM   #16
Kefka
Mexico
24
53k miles
= 85,XXXKm. (-> thanks Ali820)
wow , mine failed at 29-30Km (aprox) , very similar if the issue is OFHG/cooler like yours.
Here in Monterrey-Mexico, dealership has these items aprox in USD :
11428637821 and 11428637820 - $798 pesos - 39.88 USD each one = 79.76 USD (both - tax included)
and labor (not in dealership ) aprox 100USD.
      09-03-2019, 01:46 PM   #17
ali820
ali820's Avatar
214
Drives: '15 335i MPE 6sp Suzuka Grey
53k miles
= 32,XXXKm.
53k miles = 85k kms
      09-03-2019, 10:12 PM   #18
jh_f30
jh_f30's Avatar
810
Those are dealer rates?? Very reasonable.
      09-04-2019, 04:17 PM   #19
oma3710
oma3710's Avatar
83
Drives: 435i vert
No, they are not dealer rates. I am friends with a master mechanic at the bmw perfomance center. He does side work for me. He replaced the oil cooler gasket and oil filter housing gasket. We ended up having to replace the belt and pulley as well because oil was all over it. The pulley was making a hissing sound. He charged me $500 for parts and labor.
      09-05-2019, 01:49 PM   #20
jellyfishlicker
Drives: 14' f32 n55
That's a really good price. I paid my mechanic to do just the oil housing gaskets and an oil change for $700. I called the dealer to see how much they wanted and they wanted $2400 just to replace the gaskets.
      09-05-2019, 06:34 PM   #21
XutvJet
Drives: 2016 M235 6MT
That picture sure seems to make it appear that the leak was coming from the filter cap. It wouldn't make sense for the oil to fill those voids if the OFHG was leaking. If the OFHG was leaking that badly, oil would be everywhere and creating pools under the car.
There are two OFHGs. The OFHG between the housing and engine block is the one that tends to leak the worst and there's NO WAY it would pool oil there. It's physically impossible. The other OFHG is between the main oil filter housing and the front oil filter housing plate. In order for that gasket to leak into that area would require a pretty obvious leak and at the top of the gasket, not the bottom. For that amount oil depicted, it seems very very unlikely.
When you saw this oil accumulation, how long had it been since your last own change? It sure looks to me like the oil filter cap was leaking and dumping oil into the depicted areas, especially since you were hearing a vacuum leak.
Country over party
      09-06-2019, 03:20 PM   #22
oma3710
oma3710's Avatar
83
Drives: 435i vert
The oil was all over the place.
