BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > ASD retrofit?
proTUNING Freaks
      12-27-2017, 10:03 AM   #133
Sanko
United Arab Emirates
Drives: BMW 428i Gran Coupe
There should be a walkthrough on here on how to flash, let me know if you need help....
That's what I was trying to find (maybe not hard enough
Could anyone point me there?
      12-29-2017, 09:33 PM   #134
silencer2008
Australia
37
Drives: 2014 328i MSport
http://www.bmwesys.com/guides/E-Sys%...CU%20Guide.pdf
This is for flashing up. Same procedure applied for flashing down, but just select the lower Istep level from the earlier psdz.
2014 328i MG , BM3 Stage 2, Injen Intake, M Performance Brakes+ Exhaust, CP + BP, FMIC, High Flow DP, NBT ID6
      12-29-2017, 09:40 PM   #135
Sanko
Thank you!
      02-19-2018, 11:56 AM   #136
Justin Gang
Justin Gang's Avatar
Austria
Drives: F30 320i 2013
Originally Posted by joq3 View Post
Thank you, but do you know what psdzdata version I should use to be able to change the engine type.
Mine is a bit special as it is an ASD from an F10 so the only setting working is F10 and N20B20 (my engine), everything else shuts it off.
I thought I could change the engine type as long as I used F10, but did not remember correctly.
I would like to flash it to enable switching to B48.
Please check the F10 psdzdata and F30, don't remember which I would need.
Thank you very much!
Hi,
I love yours.
but i have a few question.
What is your the ASD Part Number?
Thanks in advance.
      03-25-2018, 04:05 AM   #137
pahatik
Drives: BMW F15 2015.07
Originally Posted by mhhforyou View Post
ASD is always on in every rpm. ASD is independent from drive mode. In sport mode its only more noticeable than in comfort.
Hello, I've the same issue. My asd comes from f10 and has swfl from f10. How can I change swfl to f30 ?
      06-23-2018, 12:01 PM   #138
uhg
Drives: f30
Hello. I have a problem with retrofited ASD on 320xdrive f30, it does not switch the sound.
ASD only works with f80, s55b30 settings. Powerclass, audiolevel can be changed, everything works. But I can't change ASD sound to 335 (n55b30) or 328 (n20b20) ASD turns off and an error appears in Rheingold on ASD 8053A5 - incorrect encoding
ASD updated Psdzdata 55.0
HWEL_00000F94_003_000_000
SWFL_0000111D_002_007_004
SWFL_000021D4_001_011_000
Does any can help make it so that I can choose sound of the engine in ASD? The sound of f80 m3 is too loud. Thanks
      06-23-2018, 03:39 PM   #139
Jhnblckwood
Drives: F30 2014 320i xdrive
You have to flash to lower istep. Like mentioned above with later istep they don’t let u change sound
      06-24-2018, 10:04 AM   #140
VVlasy
Drives: 2016 440i xDrive GC with MPPSK
If I am on 2018-03. Can i downgrade just the ASD unit, or are there now dependencies and incompatibility?
      06-24-2018, 10:38 AM   #141
uhg
Drives: f30
Thanks.
The problem is that Asd was retrofitted.
What version of psdzdata is suitable? Now I have v55, v54 will work?
Date of manufacture ASD - 07/13, date of production of the car - 03/14. What I-step shipment I need to chose, production date of the car or production date of the asd?
Do I need to change the production code typekey on typekey ('Typschlüssel') from car with asd (for example 3C17) or do I need to put 'Typschlüssel' on the original car (320xdrive)? Or I need to edit something else in FA (VO) . The native FA (VO) did not have ASD, because it's 320, ASD started to be installed from 328 and older.
      08-29-2018, 10:48 AM   #142
deneyer
Belgium
35
Help did an asd retrofit in my f34 from 2014 and when i do detcet cafd i get this error. Who can help me fix this?
      08-29-2018, 12:12 PM   #143
atzebmw
Drives: Tesla Model 3
This message appears when you try to install an ecu from another series.
There are now 2 options.
You can flash the ASD with your VO and after that you can assign a new cafd and code it.
Or if you know from which vehicle the ASD has been removed, then you can connect with Fake VO according to this series and it should be possible to assign the CAFD.
But after you assigned the cafd you may not code the ASD.
Don't close E-Sys and connect new and normal with your own VO and then code the ASD.
      10-05-2018, 07:03 AM   #144
deneyer
Belgium
35
I cant get my asd working. Before it was coded to the car it worked but i got error in ista that it was not correct and could iject cafd. The i got someone to help coding it to my car, but since then it stopped working.
Whats the cause of this? Cause i tried when it was coded to my car didn't work, tried coding the car to m3 settings and it doesn't work.
Then ive downgraded the asd and now i get error ASD: Invalid coding data for equalising, i tried it on m3 setting and on my car setting and same reslut still doesn't work. and the fault code appeared on the downgraded asd.
So is this fault cause the asd is coded to low and i need to upgrade it again, or whats the problem?
      10-05-2018, 07:18 AM   #145
mhhforyou
mhhforyou's Avatar
62
Drives: F36 420da
2014 BMW 420da  [0.00]
Do you have teamviewer?
      10-12-2018, 06:12 AM   #146
deneyer
Belgium
35
Anyone else has the same problem or know how to fix it? Cause mhhforyou is no help at all
      10-20-2018, 05:46 AM   #147
deneyer
Belgium
35
Tried coding it to f30 f34 f36 to motor type 328i 335i 340i and 440i and m3 m4 fault stays the same. I contacted the seller of the asd to figure out from witch car it came, now i know its from an f10. So i tried to set model to f10 and motor to n20 nothing tried 535i, 550i setting tried f11 and the error stays the same and it wont work
My asd info is as followed
cafd is
cafd_00000F9B_001_017_001
hwel is
hwel_00000F94_003_001_000
swfl is
swfl_0000111D_002_007_004
swfl_00Q021D4_001_019_000
      08-22-2019, 05:35 AM   #148
AFGauci90
AFGauci90's Avatar
Drives: 62 F30 320i XDrive
Can anyone help?
I have a 62' F30 320i with an N20 engine. For the time being, I am stuck with this god awful noisy engine so I have been looking for the cheapest way to drown out the sound, as even in the cabin with the windows closed, it's pretty annoying.
Yes, I can just turn my music up...but I don't always want to. So I figured I will look at retrofitting the ASD module to my car.
Being as mine is the base stereo, it seems I need a different connection. As per the top diagram in the below image, it seems pretty straight forward.
Now I have got myself the ASD unit for my F30 off ebay for £50. What I need help with next is the correct connection from this to the head unit. It states a K-CAN2 but I don't know where to source of if that's just all I need.
If anyone has knowledge of this and can help me or even point me towards a BMW specialist who can do this kind of retrofit, it would be greatly appreciated.
Thanks in advance
      08-22-2019, 05:39 AM   #149
mhhforyou
mhhforyou's Avatar
62
Drives: F36 420da
With this comments no one will help you.. Good luck.
      08-22-2019, 05:44 AM   #150
mhhforyou
mhhforyou's Avatar
62
Drives: F36 420da
Originally Posted by AFGauci90 View Post
Can anyone help?
Thanks in advance
If you retrofit ASD Modul in the left side of the Trunk as it normally is from factory next Position you can get KCAN2 is from REM Ecu in the right side of the trunk. If you retrofit it under dash near steering Wheel for example, next KCAN2 is from FEM at the Right side of driver footwell.
      08-22-2019, 05:49 AM   #151
AFGauci90
AFGauci90's Avatar
Thank you for the fast reply, really appreciate any help I can get on this.
So do I need to buy a cable? all I have is the ASD box at the moment.
Sorry, I am such a novice at this. I haven't got a clue where to connect it into the stereo head unit either.
Thanks
      08-22-2019, 05:54 AM   #152
mhhforyou
mhhforyou's Avatar
62
Drives: F36 420da
Thanks
You have to splice the ASD into the OEM Stereo System. This isnt easy and you need connectors, Pins, cables and special coding. If you never done this before think its better you took the car to a specialist in your town because if something went wrong you dmage the headunit or FEM Ecu.
      08-22-2019, 06:12 AM   #153
AFGauci90
AFGauci90's Avatar
Okay, I will locate a specialist in my area then, to make sure it's done right.
Thank you for the advice
      11-06-2019, 11:12 AM   #154
hsk1610
Drives: 2013 328i xDrive
difference in number of wires
Hi, I bought a cut ASD/Hi-FI AMP wiring harness from a donor vehicle, but that has 30 wires that need to be spliced into the harness from the headunit into the asd/ Hi-Fi Amp in the trunk. However, the current wiring harness in the Hi-Fi amp from the head unit only has 25 wires. Trying to determine why the difference in the number of wires.
