06-02-2019, 04:42 AM | #23 |
Rep 104
What is the difference when it comes to
Those steering wheel controls? I thought those already worked on the original Carplay MMI? Too bad the original did not drop in price |
06-02-2019, 02:16 PM | #24 |
Rep 832
Drives: 2019 G01 X3
How is the sound quality through the AUX input, and are there any issues with the factory microphone (for phone calls and Siri)? Also, have you tested out any videos via USB flash drive?
Does the factory rear camera automatically pop up on iDrive and then switch back to CarPlay? |
06-02-2019, 09:11 PM | #25 | ||
Rep 681
I think the factory camera and such switch automatically since I get a blank screen when I go into reverse. I'm still working with Bimmertech to get my iDrive menus working with the MMI at this time. Currently, I don't get any iDrive menus working over video through the MMI on NBT Evo ID4. They tell me that its only 2016 cars that are having this issue at the moment FWIW. Another annoyance that I've come across is that in android auto with my phone, night mode doesn't work so I'm blinded by daytime maps at night. My current workaround is to use satellite maps at night as they're darker but its rather annoying. I'm unsure if its the bimmertech module or android auto on my phone to blame for this. I've tried playing around in developer options on my phone to see if i can force this without much luck yet. I haven't tested carplay yet as I found carplay to be somewhat buggy since I'm not used to iOS as my primary device. One more gripe that I can live with is that directions don't feed to my HUD anymore which is def a bummer. It was really nice to see those on the HUD but given that its an addon unit, I can't fault it too much here.
2016 328ix F31 - SOLD!
2006 997.1 C4S |
jeffc83722.00 |
06-02-2019, 10:10 PM | #26 |
Rep 18
Drives: 2014 335i Sport Line
Can anyone else chime in on the audio quality for playing music and such? This will be a deciding factor for me, as I currently listen to audio via USB port and wouldn't want a too big drop from BT audio quality.
2014 335i
06-02-2019, 10:23 PM | #27 |
Rep 212
I'm not sure how BT is better than the USB dock connector.
In my case, using the USB dock connector via iDrive 4 is much better than BT. Let alone AUX in the case of this MMI. |
06-02-2019, 10:30 PM | #28 |
Rep 681
I agree, its very strange to me that audio quality sounds somewhat muddy especially when compared to BT.
Update to my iDrive not showing with the MMI. I was able to work with bimmertech support to get it resolved a little bit ago. Everything seems to be in order now so I'll give it a full shakedown this week as I drive more. My main experience will be with android auto but I'll try out the carplay side of things as well but it won't be nearly in depth as the android side of things.
2006 997.1 C4S |
MarkoSK121.50 |
06-03-2019, 05:34 AM | #29 |
Rep 18
This is how it is in my car - if I can't get at least BT quality with the MMI, its a no go for me.
2014 335i
06-03-2019, 05:59 AM | #30 | |
Rep 1,678
Drives: 2014 428i and 2018 X5
jeffc83722.00 |
06-04-2019, 12:31 PM | #32 |
Rep 394
06-04-2019, 07:54 PM | #34 |
Rep 681
Am told by bimmertech that the audio issue is isolated to Android phones and only some at that. They told me also that they have no plans to address is as "it's out of their control" or something. Sounds like poor development prioritization to me. Kind of like how they did do a version bump for the patch I applied for my mmi to work with my 2016 nbt Evo unit. Only way to "test" was to keep applying the update until it worked.
06-04-2019, 08:13 PM | #35 |
IT_GUY
Rep 3
Whats the safest and wisest bet right now considering below bullets?
1. Apple carplay (if possible wireless connectivity) 2. HUD integration 3. Steering wheel controls working 4. Preferably using OEM microphone Thanks in advance! |
06-05-2019, 05:57 AM | #37 | |
Rep 212
You can also use OEM mic to play music and make phone calls - Carplay mic, however, is the only option to use Siri |
06-05-2019, 08:31 AM | #39 |
Rep 61
What exactly does this do? I have a 2018 F36 which already has wireless Carplay from the factory, does this require additional hardware installed? Does it just enable Android Auto and full widescreen Carplay?
06-05-2019, 08:58 AM | #40 | |
Rep 212
There is no OEM Android Auto but this add-on device makes it possible with older head units (i.e. NBT) |
06-05-2019, 07:35 PM | #43 |
Rep 3
I am always curious as to how audio is being feed to iDrive, can anyone explain?
When playing music via Carplay (eg. Spotify or Apple Music), is the audio streaming sent through digital signal or analog? Keep seeing posts in the forum audio quality is somewhat different via AUX, is this refer to connecting the phone to the OEM AUX input, or through the Bimmertech MMI? What I want to clarify is if the audio quality connecting via Carplay is on par with connecting directly to iDrive through USB or bluetooth. Patrys@BimmerTech perhaps you can help answer this? Thanks. Last edited by cityhunter07; 06-05-2019 at 07:53 PM.. Reason: edited |
06-05-2019, 08:40 PM | #44 |
Rep 1,678
No. It's not. It's crappy AUX audio. This has already been established earlier in this thread.
