04-05-2023, 03:49 PM | #1 |
Rep 59
Need help diagnosing why my paddle shifters don't work
I recently installed the legendary M Sport steering wheel in my 2015 320i. Retrofitted paddle shifters, retrofitted the wire that goes from #5 FEM to #3 SZL. Coded in paddle shifting with Protool.
Nothing. I followed the video Brian from KIES Motorsports made about the wiring. The only difference in my particular wiring job, is that I had to splice a little extra wire in to make it long enough, so I've got two splices rather than just one. I followed every other step to the letter. Anyone ever had something like this? Im thinking that maybe the resistance isn't right because of the extra splice? If not, maybe I should try replacing the wiring harness for my paddles inside the steering wheel? Kinda hit a wall on this project. Any and all helpful advise would be GREATLY appreciated, as I have not found a definitive answer by searching. Thanks y'all! |
04-10-2023, 08:22 PM | #2 | |
Rep 118
And have you coded them in bimmercode? |
04-14-2023, 11:09 AM | #4 | |
Rep 883
Drives: 2018 F48 X1 xDrive 18D
I found the wiring loom in the steering wheel quite vulnerable as especially on the right side it was quite crammed |
05-15-2024, 03:19 PM | #5 |
Rep 59
About a month ago, I finally got around to taking the dash apart again to check my wiring job. I took the wire out, stripped, soldered, and heat shrink'd it. When I put it all back together and tested it out, to my surprise the left paddle was working, but it will only upshift. The right paddle does nothing. I coded the paddles in, and changed a few extra values that someone on this forum took from their own car that had F80 paddles installed and working. Still the same result. Upshifting from the left paddle, and nothing from the right.
Did I plug the paddles in backwards? Or do I have to VO code 2TB in and remove 205? Anyone know? |
