10-08-2019, 01:43 AM | #1 |
Rep 170
LCI Tail Light Upgrade OEM vs Depo?
Thinking about doing a LCI tail light upgrade on my 2014 335i. Have seen the DIY's for OEM and Depo.
From everyone's experience what's the verdict? OEM or Depo? The Depo is marketed as PNP and the OEM seems like it needs a wiring harness. But with the harness does that make the OEM PNP? Thanks! |
10-08-2019, 08:26 PM | #2 |
Yoda of mods
1673
Rep 3,004
Drives: X5 RWD
F87 AW (retired) F30 SBM 316rwhp/440rwtq (retired) Follow me on Twitter: https://twitter.com/EdwyerCLT YT: https://www.youtube.com/@DWYERGARAGE/videos |
10-09-2019, 10:50 AM | #4 |
¯\_(ツ)_/¯
945
Rep 1,762
For lights I always go OEM
zamboni1127.50 |
10-09-2019, 10:55 AM | #5 |
Rep 3,752
+1
There was a thread here before BMW 3 series caught on fire.... according to the photo posted and by account of the owner/poster, the fire started on the headlights(aftermarket). I was going change few light bulbs for some LEDs but not anymore. |
Solidjake945.00 |
10-10-2019, 01:35 AM | #7 |
Rep 170
From the searches I've done looks like the Depo's have issues with leaking or fogging up. So it seems as though OEM is the way to go. But I'm trying to get advice on whether error codes come up. If not, then I don't really care about the flickering on start up caused by the self test.
10-10-2019, 06:43 AM | #8 | |
¯\_(ツ)_/¯
945
Rep 1,762
10-11-2019, 04:55 PM | #9 |
Rep 2,499
I did OEM in January and would definitely do it again. You have to code, though. You also have to be comfortable with very minor wiring and modifying the harnesses that go in the lights as well as one large harness that connects to the body module in the trunk. The BMW retrofit kit that you buy comes with everything you need to do the wiring. Make sure to get an OEM one as the first one I bought was some cheap aftermarket version with wrong cable lengths and cheap connectors.
If you're not comfortable coding and minor rewiring, then you shouldn't do OEM. You have to do DEPO if you just want pure plug and play. |
10-11-2019, 06:23 PM | #10 |
¯\_(ツ)_/¯
945
Rep 1,762
Here is my video to install OEM ones. Just read the video description on the youtube page as I ended up tapping the outer tail light wires to get the inner turn signals to light up
floridaorange10141.00 F36GC_NYC159.50 |
10-12-2019, 10:27 PM | #12 |
Rep 8
I purchased Depo tail lights two months ago. I can confirm I've found fogging. It was only on one occasion but still has me concerned about longevity. I've got headlights from Depo too and have yet to notice any fogging and no issues after about a year.
digistil53.00 |
10-14-2019, 10:17 AM | #13 |
Rep 20
Installed the DEPOs over the spring and haven't noticed any fogging so far. I'm gonna change the drip rails to the LCI versions to match the contours of the new lights and hopefully help keep moisture out
02-01-2020, 06:31 PM | #14 |
Rep 170
Just a follow up to this thread.
I went with OEM blackline's and the install went perfectly. However, I'm getting fogging whenever it rains. The main reason I went with the OEM was to avoid the fogging everyone mentioned about the Depo's. Seems as though the genuine ones fog up as well. Has anyone figured out a way to prevent the fogging? |
02-01-2020, 06:48 PM | #15 |
Rep 2,499
You're in Hawaii so we're worlds apart in terms of humidity, but my OEM blacklines have never fogged up on me. I don't think tail lights should have condensation on the inside, only headlights. Do you get fogging on both sides or just one? If it's just one, there may be a problem with the seal on one of them. Headlight condensation is normal since they're made to be vented to the air.
02-01-2020, 07:46 PM | #16 |
Rep 170
I'm getting condensation on both sides.
Quick question, did you really tighten down the two bolts that hold the lens in place? The top one is pretty snug but the bottom one I didn't tighten down full tight for fear of cracking the plastic tab. |
02-01-2020, 11:06 PM | #17 | |
Rep 2,499
Is there condensation on all four segments? Just the outers? Just the inners? |
02-01-2020, 11:26 PM | #18 |
Rep 170
Thanks, I'll probably take them off then reinstall them. Might clean up the seals and use a little vinyl conditioner on the seal to help better with the sealing.
The condensation is only happening on the outer lenses. |
02-02-2020, 08:54 PM | #19 |
Rep 288
Make sure the little weather strip trim piece is installed nice and flush and correctly; that's where all the water is getting in.
upsidedownfunnel1996.00 |
02-03-2020, 01:15 AM | #20 |
Rep 170
Just double checked my weather strips and they're seated properly. They are also the correct ones for these lenses.
Thanks Last edited by rennwerkes; 02-03-2020 at 01:30 AM.. |
02-03-2020, 02:05 AM | #21 |
Rep 2,499
The weather strips don't "seal" the tail lights. They just prevent water from running into the seam directly under the tail lights.
Now that I think about it though, I bet the tail lights are vented to some degree. I know headlights definitely are made to be vented. I bet the same is true for the tail lights. If the condensation is really light and goes away right away and doesn't form large drops, it's probably nothing to be too concerned about. Try remounting them to see how it goes. |
02-03-2020, 02:54 AM | #22 | |
Rep 170
Appreciate everyone's advice. |
