10-15-2019, 04:34 AM | #661 | |
Rep 44
I got this exact update from them (https://mega.nz/#!HE4S0KRS!OaAFeLvbE2h83ba70uCb8mzdKKcmM3WGrUnl8Uk 7NGo) which is for the snapdragon 4gb/64gb version. Bear in mind that I just got it today and have not installed it yet. Does anybody here know the last MCU version for these units? Is there a list from old to new? Or a way to check if mine is indeed the latest? |
10-15-2019, 05:58 AM | #662 | |
Rep 1,048
I also got 2.8.3 sent again from my vendor today, it seems this is now the latest overall software version. I also startet working on that MCU stuff, but wasn`t able to uncrypt the binary yet with free/open source tools. I don`t have access to IDA Pro, an honestly also don`t want to use a paid only software for this. I hop that there is some kind of version numbering within that files to generate a database with updates. but i`m quiet busy already with all that other stuff and work, it seems here are not alot other people who have the time/skills to work on such things ? Have you also got an MCU update for your unit ? Chri |
10-15-2019, 06:14 AM | #663 | |
Rep 44
10-15-2019, 09:35 AM | #664 | |
Rep 220
Drives: MINI Cooper, 2020 X1
mrsimes18.00 |
10-15-2019, 09:48 AM | #665 |
Rep 399
I also ordered from Coika, based on best pre-sale communication. Not perfect by any means, but still better than the 3-4 other sellers I contacted. Responsiveness after-sale has also been good enough. I got the 2.8.3 update just hours after requesting it.
10-15-2019, 11:29 AM | #666 |
Rep 1,048
As you get software updates, it would be great to also ask the vendors for MCU Updates so we can start a database
When providing them, please add the following information: * Your Car Type , production month/year * Navigation System (CIC/NBT/NBTEvo) * MCU ver: complete string, not only the date * CAN Protocol: which you have selected [1-4], since the last update there are four options * which Vendor/Seller Chri Last edited by Kri; 10-17-2019 at 07:13 AM.. |
DarkIrata9.00 |
10-15-2019, 02:05 PM | #667 |
Rep 44
Can anyone get their "ok google" function to work with the Google assistent app? Voice activation is disabled for me.
Also, did anyone install a custom car launcher? Not a big fan of the huge tiles with functions I never use, rather have a customizable one. Only thing I wonder is, how do you switch between launchers and do the default apps still work (settings app, reverse camera,.. ) those are not selectable in the apps menu by default. And last question, how can I access the Bluetooth settings for the device? I only have the useless interface from the unit itself, but the Android Bluetooth settings menu is empty. |
10-15-2019, 02:29 PM | #668 | |||
Rep 1,048
Chri |
10-15-2019, 02:39 PM | #669 | |
Rep 51
Also i use the Nova Launcher. Just install it, press HOME and it will ask which Launcher you want to go back to. Select your new Launcher and press on "use always" Everything else still works. I got a Icon to the original launcher so i can quickly open it if i need something, ooooooor to make it not so obvious that i use a different HU. |
10-15-2019, 03:04 PM | #670 | |
Rep 44
10-15-2019, 03:49 PM | #671 | |
Rep 47
Download google play service fix from play store. Use that application to update google play service to latest version. Make sure that you have google installed. Go into settings- application. Find google, clear cache and data. Start google - go into voice settings, enable voice match. " OK Google" should work after that. |
10-15-2019, 05:08 PM | #672 | ||
Rep 51
IDrive Controls doesn't work since they are implemented into the main launcher. Someone who understands android apps better, could take a look and MAYBE it could be possible to pipe it as keyboard commands with an extra app. But that is just a theory. Quote:
10-15-2019, 07:16 PM | #673 | |
Rep 3
Hi! I have an E92 with MULF2-HIGH. Without screen. What I need to coding to avoid using the cable in the armrest? I have Android 9 Snapdragon 4G. |
10-16-2019, 02:30 AM | #674 | |
Rep 55
So yesterday I pulled out the aux fly lead from the audio out on the harness and plugged my kindle in there. Audio out from the kindle into Aux-In using the same lead is perfect - crystal clear. I then plugged a pair of headphones into the audio out on the android harness and listened to audio from android - you can hear the distortion through the headphones. It seems that the audio output level is too high, not the volume, but the output. It sounds like everything is on overdrive/fuzz. With headphones plugged in, I've tried changing the media volume in android, but that just makes it louder or quieter, it doesn't change the level. I'm wondering if there's a daemon or app running that's doing some kind of default equalisation that I can't see.... or it's just bad hardware! If I try a PX6 unit will I lose any functionality? Does it also inject sat nav audio and do the same stuff underneath with idrive (ie lock it into split screen) etc. Last edited by mrsimes; 10-16-2019 at 02:44 AM.. |
10-16-2019, 07:16 AM | #675 |
Rep 87
Regarding the touchpad. I've googled the product and tried to contact all sellers that appeared in search results. I haven't got any response (email, skype, etc.) so far.
10-16-2019, 09:11 AM | #676 | |
Rep 29
You can have the IDrive controls to work in any apps but it required some skills. When you make an action with the Idrive (rotate, click, etc...) it sends an android broadcast to the unit. You just have to intecerpet this broadcast and assign a function to it. For example I'm using the custom launcher called "CarWebGuru Launcher". I can swipe between the different screens by faking a swipe when I rotate the Idrive. I also can play/pause the current song when clicking the Idrive. Last I can play next song by right pushing the Idrive. The broadcast action to intercept is : com.choiceway.eventcenter.EventUtils.ZXW_ORIGINAL_ MCU_KEY_FOCUS_MOVE_EVT The broadcast sends an integer corresponding to the control pressed : 2 = Right pushing 8 = Rotate right 7 = Rotate left 5 = Idrive click In my case I've used the application "Automate" to listen to these broadcast and call the android functions. It also can be done using Tasker or directly by creating an apk. I hope it helps someones.. Sorry for my english. |
10-16-2019, 09:24 AM | #677 | |
Rep 280
I was searching through the code of KswLauncher and found all sorts of listeners but never the source for the event. I fully expected broadcasts but I am still waiting for my unit to arrive so I couldn't check. With this I will save myself a lot of time. Thanks again! |
10-16-2019, 09:40 AM | #678 | |
Rep 29
Another thing that can interest you. If you send the following action it will switch to the original BMW display : com.szchoiceway.eventcenter.EventUtils.ACTION_SWIT CH_ORIGINACAR I made a small apk that sends that action so I can use it as a shortcut in a custom launcher. |
10-16-2019, 09:43 AM | #679 | |
Rep 1,048
Would it be possible to upload a flowchart for us ? this way it would be easier for us to start with own script. maybe we then can make a database (at github) with ready made Flowcharts Chri |
10-16-2019, 09:55 AM | #680 | |
Rep 29
Your idea of a centralized database is good. I'm currently trying to interact with the dimming but I would need some infos from __fred__ but he doesn't seems to be here anymore... I will upload my flow later today. Last edited by RaceX58; 10-16-2019 at 10:03 AM.. |
10-16-2019, 10:23 AM | #681 | |
Rep 280
I will also build myself something that reacts on these broadcasts and send the respective KeyEvents to the system. Not sure yet in what way though (own apk, Tasker, etc...). And, of course, my unit needs to arrive ^^ Last edited by Firefly1337; 10-16-2019 at 10:35 AM.. |
10-16-2019, 10:43 AM | #682 |
Rep 29
Guys,
You will find my flow at this link in the apps folder : https://drive.google.com/folderview?...2K_rtRS0Q_soKd I also share the apk I made to switch to the original display. Feel free to use it. RaceX58 |
