BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Navigation, iDrive, Audio, Video, Bluetooth, Phone, Cameras, Electronics > 10.25" Android 9.0 HU discussion
      11-20-2019, 07:36 AM   #1189
Gidimba
Drives: BMW 320i (F30) 11/2013
Originally Posted by Mirjam View Post
That surely must be daytime running lights (DRL), not the full headlights?
actually in my country the law requires full driving lights in winter time.
DRL are not enough
this is why its annoying that I cannot use the dimmer settings on the HU based on if i turn on the lights or not.
      11-20-2019, 12:49 PM   #1190
Spanielgita
Drives: BMW 335D F31 2015
Idrive resolution not correct
I am currently pulling my hair out with the Idrive screen in association with my snapdragon android unit.
My car is a 2015 F30 with ENTRYNAV so afaik it should display the idrive side in full widescreen and not stretched etc.
I have Bimmercode on my phone and have programmed the screen in expert mode to 8.8 1280x480.
DISPLAY VARIENTE - Brites mode
I have then changed the android side to 8.8,10.25 and I get the fullscreen but the right third is cut off (pictured)
The 6.5" fullscreen is extremely stretched but works as the 6.5" with overlay.
I have then tried changing the bimmercode to the 10.25 1280x480 setting and still have no success having tried all the android settings for display res.
Is there something I am missing here? Has this happened to anyone else here?
Any tips or advice would be greatly appreciated.
      11-20-2019, 02:45 PM   #1191
-pascal-
Drives: 1 series/F20 (2019)
Originally Posted by Shrazy View Post
Everytime first start integrated music app close it and then start radio. Voice will turn normal.
I started at first music player and closed it. Then switched to navigation an radio. Same problem.
      11-20-2019, 03:25 PM   #1192
nurif20
Drives: BMW F20
Is there any nice setting or app to get better sound quality?
I have a F20 with standard Soundsystem.
In high volume it sounds litte bit bad/unclear
      11-20-2019, 04:04 PM   #1193
marakeh
Drives: BMW 118D
if you have a px6 rk3399 unit, remove the aux plug under the armrest.
makes a big difference, does apparently nothing for the snapdragon devices.
Originally Posted by nobuno View Post
As shown in the image, pull out the AUX4P coupler at this location. For SA 6FL.
Armrest AUX does not go directly to HU, but goes to combox once. So in the Android harness, the AUX is bypassed, the audio runs backwards, enters the BOX and comes to the armrest. Therefore, I guess that resistance is born and the sound becomes muddy.
      11-20-2019, 05:11 PM   #1194
Spanielgita
I found the treble was awful at louder volumes with my snapgradon unit.
I discovered that my android media volume was at 40 (highest level) so turned it down to 20 and that fixed the harsh treble. I have the HK system and the aux cable is connected in the wiring harness.
      11-20-2019, 06:52 PM   #1195
Gabrielisimous
Gabrielisimous's Avatar
Drives: F30 328i 2013, E46 325i 2005
I have a PX6 10.25 9.0 and I fix my sound problems when I disconnect the Bluetooth dongle i was using to stream music since my HU is an entry and no capable to stream just have the phone option so I disconnect the dongle from the aux/usb port under the center arm rest and "voila" ... my guessing is that the steaming at some point is having conflicts if is connected through the Bluetooth device and the Android display, now I have a very nice and loud sound including deep bass the way you cannot make comparison between your "original sound" and "the Android sound" also here are my sound setups
Gabo
      11-21-2019, 12:18 AM   #1196
seaman5705
Drives: BMW F10
It does in my case . Disconnecting AUX in armrest makes a big difference - before, sound was muffled .
Snapdragon unit in F10 with HIFI audio system.
      11-21-2019, 01:05 AM   #1197
nurif20
Drives: BMW F20
I have a snapdragon and my aux cable is connected in my armrest. So i cant disconnect it, right ?
      11-21-2019, 06:30 AM   #1198
Mjam
Drives: E87, i3, Taycan Cross Turismo
https://f30.bimmerpost.com/forums/sh...postcount=1046
      11-21-2019, 09:10 AM   #1199
nurif20
Drives: BMW F20
Thanks i will try it later
      11-21-2019, 10:30 AM   #1200
koutsouk
Greece
31
Drives: BMW E60
Originally Posted by RaceX58 View Post
I need some guys to do a test. Just install the app and start the dimming service. Then tell me if it connects to the MCU or not.
Thank you guys for your support contribution !
I installed and i am using your app !
it works ok for now !
My system is from UGODE Android 8.1 PX6 for BMW E60 CCC
I have a question for you,
What is the time that triggers the change between day and night ?
RaceX5854.00
      11-21-2019, 10:35 AM   #1201
koutsouk
Greece
31
Drives: BMW E60
On these head unit you can't control the brightness under Android. Just have a look to the Android settings and you'll see there is no option to control the brightness
Why you say that ?
There is an option to control brightness in camera settings with a bar from 0 to 100. Or you say something else and i am missunderstanding you ?
      11-21-2019, 01:30 PM   #1202
Gabrielisimous
Why you say that ?
Yup this is right and also as soon your headlights turn on on the dusk the screen dims itself no settings needed for this
Gabo
      11-22-2019, 01:26 AM   #1203
Svenson
Svenson's Avatar
Drives: F11 530d
Why you say that ?
You can control the brightness manual in the camera settings from launcher, thats right.
But you have no possibility on the side of the android. You can not do it with a program about sunrise/sunset, timer, scheduler or whatever.
You can do it with your fingers, that's all.
RaceX5854.00
      11-22-2019, 02:01 AM   #1204
koutsouk
Greece
31
Drives: BMW E60
Yes i understand that.
That for we are greatfull for RACE`S work.
By the way the app in the morning did not enable Day mode at least on 9:00 AM Greece time.
That for i asked about what time your app is set to change the modes .
      11-22-2019, 02:10 AM   #1205
RaceX58
Drives: BMW F20
Thanks for your feedback !
At the moment it doesn't switch automatically.
I'm working on a new version that switch day/night mode automatically based on offical sunrise/sunset of your location.
I'm also adding custom presets so you can switch between brightness using a button.
It's almost done with it so I will release it soon.
Why you say that ?
As Svenson said, you must go to the default settings, go to the right menu on change the value by hand. It can't be hard while driving and pretty frustating. My app add some automation to the brightness control.
RaceX58
      11-22-2019, 02:12 AM   #1206
koutsouk
Greece
31
Drives: BMW E60
RaceX58
Thank you very much for that !
If you need beta tester PM me !
Location based on GPS ?
That would be better instead of network because will use gps antenna !
      11-22-2019, 02:16 AM   #1207
RaceX58
Drives: BMW F20
Yes location is based on GPS and time takes care of timezone
I'll PM you if I need beta tester, thanks
      11-22-2019, 11:30 AM   #1208
-pascal-
Originally Posted by Kri View Post
Thank you Mirjam for sharing the latest Version
So New version is 3.0.8, i reuploaded it to wetransfer you can download it HERE for the next couple days. (link update, valid until 11.11.2019)
Edit 12.11.19: someone did a reupload at Mega.nz
But be warned this seems to be a Beta version, alot of internal changes have been made and not fully implemented yet.
What i found out so far
* Changeable MUSIC APP
* Aux in Position Selection, when "Other" AUX is selected, no function at CIC ?
* Text Updates to a lot of languages, german update just wrong
* change BOOTLOGO Support is coming back, the one which is before the bootanimation, not completely implemented
* new SevenColor Dashboard, now with distance left display, (wtf why 330km/h (205mp/h )
* Heavy internal update to GS UI, seems to be programmed for AVINUSA
* AHD Camera Support ?
* Better Support for 1920*720 Displays ?
* km / milage change option at source code - no function yet.
* Phone Button Behaviour has been changed
So far it seems they are working hard on updating the System again.
Changing the Music button is very cool, now you can select your Favorite Music app !
There is just one note, with ID5 ID6 and GS UI, you completley loose functionality of internal Music player.
With ID7 you can have both, while the Large music button stays the old one, the small Music Button at the top left corner only will be changed to your desired music app !.
The AHD and 7Dashboard requires new lines at factory_config.xml, so i added an updated here.
Bootscreen selection is also coming back, the function is not working at the GUI at the moment, but when moving a correct "splash.img" to the oem folder it will be updated.
At the moment no own images can be made as the .img file format is very special and has not been reverse engineered yet.
There was also an MCU Update with this package for E Series CIC, i updated it (had update from 245 before) , but did not see any difference in behaviour.
As always Update at your own risk !
Chri
Can I use the factory_config.xml from Chri's post for my head unit?
      11-22-2019, 12:03 PM   #1209
seaman5705
Drives: BMW F10
NO - you have PX6 unit .
      11-22-2019, 02:31 PM   #1210
-pascal-
And where I can find the right xml for my px6 system?
