11-17-2022, 05:14 AM | #89 |
Rep 190
Oh right, I was told it was done via the USB cable that I had routed in the glove box.
Sure I tried it wirelessly at first and it either wouldn't start or wasn't supported. Do you have an app to start it all? |
11-21-2022, 07:54 AM | #90 |
Rep 25
My headunit came with zlink app installed now as soon as I start the car it opened straight away and connects
11-22-2022, 12:27 PM | #92 |
Rep 190
I could only connect if the car had the hotspot enabled and even then android auto doesn't load.
Tbh if I can't get google maps working as it should, other than having a larger screen than standard 8.8" I wouldn't use it for much else. |
11-22-2022, 12:40 PM | #93 |
Rep 190
11-23-2022, 07:53 AM | #94 |
Rep 2,047
Why not just get a sim card for the android unit? It works perfectly and no longer relies on your phone
440i GC with MPPSK, AP intake, 20" 624 M wheels, Wagner downpipe, Xhp stg 3, BM3 stg 2
instagram: f36_garage |
11-23-2022, 09:55 AM | #95 |
Rep 190
I think it's an issue with my unit, to be honest. Waze doesn't work either when I just tested it and showed no navigation/signal just like google maps over Wifi, sim card, and hot-spotting.
Standard idrive navigation works as it should. I've just sent a video of it all to droiduk showing I can update all apps & access the internet but something is off/weird on the navigation side of things. |
12-05-2022, 06:04 AM | #96 | |
Rep 12
now android11, not only android screen, but also has digital cluster
12-05-2022, 07:04 AM | #97 |
Rep 190
I disconnected my screen and idrive to see if adding a gps splitter would help the situation.
Turns out i don't have the input for the splitter on my idrive unit and presume all the gps side of things must be in with all the cables in the harness. Reseated the gps cable going into the android screen and retried and it, does take a minute or two to track down satellites but Google maps seems to be working on the 2 occasions I tried it. |
