02-26-2016, 02:19 AM | #1 |
Fool
1857
Rep 3,542
A definitive answer on headlight brightness LED vs Xenon
I figured there was only really one way to find out a definite answer as to which chucked out more light and that was to ask BMW direct, so I did. Took a fair few weeks to get the answer but here it is. It confirms my suspicions that F30/31 LEDs aren't as bright as the pre LCI Xenons, but for low beam purposes they should be pretty. High beam, Xenon is clearly brighter, F32 LED even more so again which was a surprise. It also shows that for your cash on adaptive LED on the F30, you're getting more than just the adaptive features, they're brighter too (something I had a hunch about after having a loaner 330D with standard LEDs the other week).
Hopefully this clears up some confusion! Low Beam: F30/31 LCI Standard LED: 784 lm F30/31 LCI Adaptive LED: 1097 lm F32 Xenon: 1170 lm F32 Adaptive LED: 903 lm High Beam: F30/31 LCI Standard LED: 1226 lm F30/31 LCI Adaptive LED: 1498 lm F32 Xenon: 1702 lm F32 Adaptive LED: 1802 lm
02-26-2016, 02:24 AM | #2 | |
Rep 20,651
It depends on what the lm refers to? |
02-26-2016, 02:27 AM | #3 | ||
Fool
1857
Rep 3,542
02-26-2016, 05:57 AM | #4 |
Rep 19,982
Good investigative work!
That's a very interesting bit of information. I've very glad then that I went for the adaptive LEDs on the new 330e, as until late on I was going to have just the standard LEDs. Questions that came in to my mind were: Why is the Lumen rating for the standard LED lower than the adaptives? Is it just to help BMW justify the extra cost of the adaptives, or a regulation thing? Can this light level be adjusted through coding? Why is the F32 adaptive LED so different to the LCU F30/F31? It's quite significant in the high beam and the newer cars (LCI) seem to worse than the older (F32) version.
02-26-2016, 06:09 AM | #5 |
Rep 25,112
Wow this is a surprise, Xenons are brighter is that? Seems to back some users claims despite a US guy taking measurements showing LED's were better.
Confusing as heck. EDIT: Any rating for the Halogens ... ... .. ..
My car made front page of Bimmerpost
02-26-2016, 06:12 AM | #6 |
Rep 3,664
Good stuff indeed.
Did you get any figures for adaptive Xenon on the F32? I have them and I think they are pants. I would certainly go for non adaptive Xenon on my next F32 looking at those figures.
Current: M4 G82
Past: C43, X4 M40i, TTS, M4 CP, 440i, 435d, M235i, 220d, F30, E90, E87 |
02-26-2016, 06:13 AM | #7 |
Rep 3,664
Current: M4 G82
02-26-2016, 06:23 AM | #8 |
Rep 54
I don't think you'll ever get a definitive answer. The problem is that a lumen is a measure of how much light is emitted by the "bulb" and that light then has to be shaped and directed to where it is required so direct comparison between different headlights on lumen output isn't possible. The measurement of "how well you can see something" is the lux (lumens per sq metre) but for car headlights that isn't much help again because the lux measurement decreases as the beam spreads out - double the distance to the target and the lux halves. So a headlight needs to put less light on the road near the car to obtain a more even illumination.
The comparison problems don't end there the light output measurement is also adjusted to the perception of a standardised human eye i.e. the light output is weighted at various frequency bands so light near the infra red or ultra violet that the human eye doesn't see well doesn't score well. And just to make it more complicated the "standardised human eye" exists because perception of brightness at various wave lengths varies with individuals, sex and age. I've got adaptive headlights etc. and live in a rural area (Yorkshire Dales) with lots of left/rights and small crests/dips but I can't decide if I prefer them over my Subaru xenon dipped (on all the time) supplemented by the manual control halogen main beams. The issue is tightly controlled and directed beam leaving dark (black?) areas v overall illumination with less light where its needed. |
gfa325.50 |
02-26-2016, 06:29 AM | #9 |
Rep 11,291
The LCI Standard LEDs look crap (in terms of lumens) and probably about as good as halogens.
Current: Golf R Mk8Previous: Golf R Mk7.5 Mercedes AMG C63 S Coupe F80 M3 Competition Pack Last edited by dopper99; 02-26-2016 at 06:58 AM.. |
02-26-2016, 06:38 AM | #10 | |
Rep 20,651
Yep lumens and Lux is where I was heading. Neither being an accurate science for measuring efficient and effective headlight throw distance and what the driver can see. Probably Lux at say 30 meters, 60 meters etc over width of road lane. Lumens just falls in to yep they are bright. |
02-26-2016, 08:19 AM | #11 |
Live for today tomorrow never comes
1989
Rep 9,498
I just go by "how well I can see in the dark and the Adaptive LED's do it for me.
Especially with HBA.
Live for now, life is too short.
2021 LCI M5 Marina Bay Blue/ Smoked White Leather |
02-26-2016, 08:52 AM | #12 | |||||
Fool
1857
Rep 3,542
Apparently so, but that could just be a US thing. Personally I wouldn't want to push it for fear of shortening the lifespan of the LEDs. Have you seen how expensive they are!? It's worth noting that the adaptive LEDs increase in brightness with speed or if you switch them to permanently on so in the UK with the full adaptive features, we probably already get the full brightness when driving at speed (or they're switched permanently on). Quote:
The reflector housing of the LEDs does mean more scatter above the cut-off which is handy for reading road signs, but I can't imagine it's too pleasant for oncoming traffic. The Xenons were very much on/off with their cutoff due to the shutters. Yeah I wasn't particularly impressed with them on the loaner I had. |
02-26-2016, 08:58 AM | #13 | |
Rep 162
F31 330d
gfa325.50 |
02-26-2016, 09:01 AM | #14 | |
Rep 32,881
It is literally night and day! I would say the same difference as between halogen and xenon! |
03-01-2016, 07:47 AM | #15 |
Rep 105
Adaptive LED S552A vs Adaptive Xenon S524A
For what its worth last night I took delivery of my 16-Plate F31 with Adaptive LED's (Iconic LED S552A) which has replaced my 63-Plate pre-LCI F31 with Adaptive Xenon's (S524A).
I drove it home the 30 or so miles from the dealer after midnight, on a mixture of A & B roads and country lanes. The weather was light to medium drizzle (light as in not very heavy rain). These are only my first impressions but so far I have to say I'm a little disappointed. I must stress this is my first impression and is only my opinion - the light spread on the LED certainly appears wider than the pre LCI xenon's, however the hots spots and lack of range on the adaptive LED's is poor. There is a lot of glare from reflective road signs, so much so that I had to manually drop to dipped beam to clearly read some of them. The pre-LCI xenon's were amazing, both colour rendition and range consistency. The LED's by comparison certainly appear very bright close to the vehicle but the range is not as good in full beam contrast, i.e. in full beam the far distance is very dark compared to over-saturated foreground. I would say that the beam on the LED's appears a little low on dipped beam too, pointing too low at the ground. As I say this is only my opinion and is based on my initial impressions, I'll update once I have a few more night time miles clocked up. The adaptive xenon's were one of the best features of my last F31, and I'm sad to say I'm disappointed with the new adaptive LED's. Over 80% of my year round driving is in the hours of darkness so it wont be long before I can post an update. I also believe that the lamp units themselves on the LCI also don't look as good at the pre-LCI assemblies. The projector units look a lot better, and more like a headlight. |
03-01-2016, 08:32 AM | #16 |
Rep 274
Thank god you've said that. I was getting a little worried for a bit as I hate dim lights!
F31 335d M Sport | Estoril Blue & CR | M Sport+ | Pro Nav | Comfort Pack | Adaptive M Sport suspension | Active Cruise
03-01-2016, 08:33 AM | #17 |
Rep 25,112
Yes it seems everyone is initially quite underwhelmed by the LED's. I think the difference in colour of Xenon makes it more obvious light? That doesn't even make sense but it is a difference kind of light.
03-01-2016, 08:44 AM | #18 |
Rep 8,081
Another thing, the non-adaptive LEDs look shite.
Ian
Current: 2021 G21 330i M-Sport Previous: 2018 A6 Avant S-Line MMI+, 2014 F31 320d M-Sport, 2013 F10 520d M-Sport, 2011 F10 530d M-Sport, 2008 320i M-Sport Coupe, 2002 325i, 2001 318i valvetronic, 1998 318i, 1996 525i, 1990 Porsche 944S2 |
03-01-2016, 04:05 PM | #19 | |
Rep 182
After that initial disappointment I became used to them as they still excellent headlights, way way better than any halogens out there and no doubt better than many xenons too. |
03-01-2016, 04:13 PM | #20 |
Rep 7,032
Drives: 335xd Msport +
So to throw a wild card in
I quite like my xenons with an osram night breaker upgrade. The light is a lot whiter and brighter than standard xenon bulbs. Would like to compare to led
03-02-2016, 01:45 AM | #22 |
Rep 8,081
The adaptive have the halos and eyebrows in DRL mode whereas the non-adaptive just have four lights?
Ian
