12-23-2013, 11:27 AM | #1 |
Rep 680
F30 18" Tyre Pressures
Hi,
as it is freezing and i cannot find a touch does anybody know off the top of there heads the tyre pressures for the 19" M Sport Plus 403 Wheels? I think they should be 2.6 bar / 37.7psi all round can anybody confirm this before i go and set the pressures all wrong? |
12-23-2013, 12:43 PM | #2 |
Rep 680
am i missing something??? finally found a torch and the door tells the following:
3 people MAX: 2.6 bar all round (38psi) 4 people +load: 2.8 front, 3.1 rear (40psi, 45psi) am i reading that right? i always thought the rear needed more. As there is never more than two people in the car should i put the lower pressure in or the higher??? will the higher pressure be better for the RTF's?? |
