09-11-2019, 11:38 AM | #1 |
Rep 266
Another snow tire/wheel fitment question
Hi does anyone know if I can run this set-up without any modifications or much sacrifice to ride performance?
Front rim size: 18x8" Rear rim size: 18x8.5" Bolt pattern: 5x120 Front offset: 29mm Rear offset: 40mm Tire size: 225/40R18 92V Extra Load M+S |
09-11-2019, 12:23 PM | #3 |
Rep 16,053
Agreed, 40 series tires is begging for pothole damage to tires and rims. Not that there are any potholes in NYC...
I specifically went with 225-55/17s to lessen the risk of tire and rim damage on my yearly NYC Broadway Show trip. The last thing I need is to be looking for tires and/or rims on a Sunday 300 miles from home. |
09-12-2019, 08:58 AM | #5 |
Rep 109
11-01-2019, 03:32 PM | #8 |
Rep 109
Enter your make/model into tirerack, they should be accurate: https://www.tirerack.com
Depends if you have the msport with standard brakes or the msport brakes... A 328 with single piston front brakes would max out with a 330mm rotor (~13") and should fit on 16's (per tirerack.) Unpainted/blue 4 pistons calipers up front are 340mm and tirerack says those can only handle 17" wheels as the smallest. Bigger than that msport brakes need 18" as the min |
