BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > Regional Forums > UK > SOS call system failure
      11-27-2021, 01:55 PM   #1
sensible
sensible's Avatar
810
Drives: BMW 420i M-Sport Gran Coupe
I have this message on my drive and dashboard.
Car is still under 3 year warranty so will have to book it into the dealer.
Anyone had this problem and what is the likely cause.
One thing to mention is that it snowed last night and the car has a light covering.
2019 420i B48 LCI M-Sport Gran Coupe | Sapphire Black | Black Dakota leather | Sports auto | M-Sport plus pack |
      11-27-2021, 02:10 PM   #2
Spangle
Drives: '14 F31 Touring
There was a thread a bit back think it pointed at backup battery starting to fail with the cold
https://f30.bimmerpost.com/forums/sh....php?t=1877527
      11-27-2021, 02:22 PM   #3
chris-c
Drives: F31 340i RWD
You could also have a loose cable under the dashboard. One of the plugs for a light or speaker above the drivers feet causes this to pop up if the cable is unplugged.
Europe's fastest (stock block) F31 340i RWD | MPPSK | XHP 3 | Pure800 | Port Meth | Dorch 2 HPFP | MG Flasher
      11-27-2021, 02:28 PM   #4
pjkbrit
pjkbrit's Avatar
128
Drives: 2018 340i 6MT ZHP
Backup battery on mine failed. It was one month out of warranty but easy to replace. Search the threads. $115 from the dealer for a new battery.
      11-27-2021, 03:03 PM   #5
sensible
sensible's Avatar
810
I am 4 months in my 3 year warranty so will let BMW sort it. Hopefully, it is just the battery. Car has been standing for about 4 days without being used and now has snow on the roof. Maybe that is enough to weaken the battery in the headliner.
      11-28-2021, 10:16 AM   #6
sensible
sensible's Avatar
810
Got in the car today and there was no warning message. I must have put enough charge back into it with a short drive and it has now reset itself.
Will still get BMW to check whilst in warranty.
      12-03-2021, 01:48 AM   #7
f30paul
f30paul's Avatar
52
Drives: F30 330e
Sounds familiar. Mine disappeared, popped back last night when I started the car at around 2 degrees, so definitely failing battery combined with the cold temperatures. I’ve got the insured warranty but my excess isn’t worth it for this, so at some point I’ll buy a replacement battery, easy enough to fit.
Funny that the warning just disappears, would thought it would be a code reset. Im tempted to replace the battery at a time where there’s no yellow message
      12-03-2021, 04:59 PM   #8
sensible
sensible's Avatar
810
Looked up the parts for the telematics set up and it looks like there are two batteries, one in the headliner under the shark fin and one in the boot under the boot floor. Booked the car in at the dealers for 8th December so see what they say.
      12-08-2021, 08:19 AM   #9
f30paul
f30paul's Avatar
52
Drives: F30 330e
It's the 8th today! Let us know what they said, you either have a battery in the boot OR in the headliner under the sharkfin (most likely the latter).
___________
F30 330e SE 2017
Previously Audi A3 S Line Cab, F30 320d Luxury, E90 318d SE
      12-08-2021, 09:48 AM   #10
sensible
sensible's Avatar
810
Just got the car back from the dealers, telematics back up battery replaced under the roof liner, under the shark fin. Covered under warranty, so all good.
They also checked that the car battery was functioning/charging properly, plus the standard car health check.
      12-10-2021, 12:00 PM   #11
Rhino at Work
Rhino at Work's Avatar
Drives: G21 330i Portimao Blue
I had this problem last winter due, I suspect, to a combination of low usage in lockdown and the cold. Once my usage picked up it disappeared.
Current: Portimao Blue G21 330i
Previous: EB F30 340i Shadow Edition
Previous: EB F30 330d xdrive
      12-10-2021, 02:03 PM   #12
scousefly
scousefly's Avatar
England
36
Drives: BMW G30 5 Series & G01 X3 M
Battery
100%
